YM2000 revs uncontrollably
/ YM2000 revs uncontrollably #1
yanmardoug
Laurel, MS
2 YM2000s and 1 YM1500
New to me YM2000. Was running ok, but some white smoke. Pulled the head. No observable problems. No gouging, scratches, or lands in the cylinders. Poured deisel in the cylinders. One held overnight, the other drained into the pan within 20 minutes or so. Reinstalled the head and changed the oil.. Got it started by pulling it and it ran fine for a minute or two before revving to high rpm. Took several seconds after closing the throttle before it finally idled back and died. Haven't been brave enough to try it again. Any ideas as to what is going on here?
/ YM2000 revs uncontrollably #3
Could it be self-fueling from oil or diesel spilled in the manifold, or oil getting past the rings?
/ YM2000 revs uncontrollably #4
I have seen the old 2 stroke Detroit diesels, do that when one jug losses compression and the crank case oil gets sucked in. That's why they have a flap under the blower that you can flop down to shut down the air.
/ YM2000 revs uncontrollably #5
I was thinking of approximately the same thing. Somebody posted that working construction, he had seen old worn out diesels in forklifts etc self destruct if the unit got flopped on its side. Oil coming up past the rings fueled the engine same as full throttle and there was no way to shut it off as it over-revved.
Thanks all for your thoughts. I was afraid that it was burning engine oil coming up past the rings in the cylinder which drained fuel quickly. Guess I'll have to pull the pistons out and check the rings though I can't really figure out how the engine could be getting lubricating oil into the combustion chamber in sufficient quantity to run the engine at full throttle and still have enough compression to ignite the oil.
/ YM2000 revs uncontrollably #7
Have you checked for the more basic issues, like throttle sticking? You be kind of red faced if it was just the foot throttle getting jammed a bit. ;)
Domush,
Being more familiar with the YM1500, which has no foot throttle; the possibility that the foot throttle might be overiding the throttle lever did not occur to me. Thanks for the suggestion; I'll check that out. Though I never used the foot throttle, I do now recall that there was some kind of issue with the foot/lever throttle operation. Therefore, an idea well worth considering.
/ YM2000 revs uncontrollably #10
Im thinking injector pump as well. The Hand throttle and foot throttle are connected. If the foot petal is depressed i think the lever is weded open as well, may be wrong on this as mine functions correctly, but when i pull the hand throttle open the foot depresses and then the reverse to slow it.
/ YM2000 revs uncontrollably #11
Mine works where the foot throttle will override the hand throttle. I know because sometimes it will not shut off and I have to lift my big fat foot off of it. :laughing:
/ YM2000 revs uncontrollably #12
I never paid close enough attention? I know you can rev it with foot throttle past the set hand throttle position as i do that when i get to a thick spot.
Checked the throttles and linkages, everything seems fine with that. It will be a while, but I'll open it up and check the rings when I get the chance. Thanks to all for your replies. When I discover more about this situation, I'll post an update. Meanwhile, I have more pressing issues with 2 other yanmars.
/ YM2000 revs uncontrollably #14
Might want to consider pulling off the injector pump first. it's really easy (4 bolts and a cotter pin) and then you can tell if it's an injector pump/governor issue. When it's off, slide the governor slide back and forth, seeing if it's free and press in the injector pumps to see if the resistance is the same for each one. They should be really hard to depress by hand and spring back immediately.
The piston rings hypothesis sounds dubious, as if it were the rings and burning oil.. how would you ever shut it down as long as there was still oil in the pan and air to burn it with? You couldn't. It has hours of fuel in the oil pan and you didn't mention killing the air supply, so it should have grenaded, not come back under control on it's own.
Something to think about.
/ YM2000 revs uncontrollably #15
Domush makes good points. :thumbsup: I could tell you in 2 seconds if it had a bad cylinder simply by listening to it turn over. You can too if you know what to listen for you have another one just compare them throttle OFF cranking and listen for the "hitch" in its getalong or not if they crank the same its probably pump. hth.
Id look at the pump 95% chance imho thats where it is since the linkage is ok, might tap on it see if it will free up.
I have my doubts its a down cyl you yourself pegged the reason - compression to fire it that and only 1 other cyl to run it on. 2 cycle engines are a different animal thats just my professional opinion known to be wrong a time or two.
Thanks Domush:
It has been a while since I worked on this toy last and so I had forgotten a couple of things. I agree that the rings theory is dubious but I couldn't think of anything more plausible until I went back out and looked at the tracor. Then I remembered that when I did have it running before I pulled the head, the crank vent was venting air and what appeared to be atomized oil and pretty high pressure was building in the crank case (unscrewing the filler plug allowed a very forceful release of pressure). So, while I had the head off, I also removed the crank vent cover (just above the injector pump), inspected that cavity and replaced the cover. It seems to me that I recall having seen somewhere that there is some kind of governor linkage behind that cover. I don't believe that I even inserted so much as a finger inside that cavity. Is it conceivable that removing and replacing that cover could have created this problem.
/ YM2000 revs uncontrollably #17
The high pressure in the pan may be a blown head gasket. Do you have an overflow bottle on the radiator? That is the easiest way to look for blown head gasket, as it will blow bubbles in the overflow liquid. (sadly, I know this from experience)
Maybe car doc has a theory on this one, as I don't see any alternative beyond a blown gasket or a seriously worn set of valve guides. Worn rings would push a decent amount of smoke out the exhaust at all times and you haven't mentioned any.
Sent from my SCH-I500 using TractorByNet
/ YM2000 revs uncontrollably #18
Broken/worn compression rings or damaged/severely worn piston or deep scratches in cylinder wall is the only things capable of creating such pressure in the crankcase that I can think of.
The head gasket could be installed wrong possibly and a oil drain passage was uncovered near a combustion chamber. I believe these can be installed front to backasswards at least mine could be elifino?
Domush and Car Doc: Thanks guys.
Given that I almost exploded this engine the last time I had it running, I am hesitant to try any diagnostics which involve turning the engine over; despite the fact that I doubt that it would start. The only way I got it started the most recent time was by pulling it. I don't believe that there should be nearly as much pressure build up in the crankcase as I was experiencing. I'm not certain (I was kind of in panic mode trying to get it to shut down) but I think that it was putting out a significant amount of black (or maybe blue?) smoke the whole time it was running on the occassion when it revved uncontrollably. When I get a chance I will check the pump and governor as that should be a pretty quick job. However, I've pretty much resigned myself to the idea that the safest approach to diagnosing this problem beyond that is going to be to take a look at the rings, especially the ones in the cylinder in which the diesel ran through into the pan most quickly. I assume that if diesel under no pressure will leak past the rings that quickly then compression could cause air to leak past them to create the pressure I was having in the crankcase.
Since there are no discernable lands in the tops of the cylinders and no apparent scratches or gouges in the cylinder walls, the only explanation for the difference in the leak down time between the two cylinders is that the rings in the more leaky cylinder are stuck or significantly more worn than those in the other cylinder (and why would the rings in one cylinder wear dramatically more quickly than those in the other?). Obviously, as I tear into it, I'll closely inspect the head, head gasket, and the top surface of the block.
All of that, of course, unless one or more of you can give me a better approach.
/ YM2000 revs uncontrollably #20
If it could suck the oil past that one bad set of rings, you would sound like you were running on one cyl once you shut your fuel lever down, It would only run on the one cyl oil was getting in. So if it sounded smooth your gov linkage must be stuck.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2014 Freightliner Cascadia Semi Truck (A66285)
2014 Freightliner...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
213098 (A64276)
213098 (A64276)
