Pull behind sprayer for BX2360
/ Pull behind sprayer for BX2360 #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I've been volunteering my tractor for field maintenance on three little league fields around town. They'd like me to get a sprayer, for which I will be reimbursed, and manage weed control as well.
I don't want a 3 point because if I sell the tractor they won't be able to use it. I'd like something reasonably priced and have been looking at Fimco and Countryline at TSC but online reviews point to quality issues. Any thought and opinions are appreciated.
/ Pull behind sprayer for BX2360 #2
Check out Northern Tool. I just bought a 16 gallon sprayer from them based on others reviews. I don't have it yet, so can't give any feedback. I also read not so good reviews about the Fimco's.
/ Pull behind sprayer for BX2360 #3
I have th 25 gallon Fimco and have only used it four times but so far it seems to work well. Biggest problem was extending the drawbar out far enough that the sprayer did not hit the 3PH arms while turning. I installed a 2" receiver and then made my own drawbar extension. This was on my BX1850.
Roy
/ Pull behind sprayer for BX2360 #4
Unless the sale of the current tractor is a given, I would buy a three point sprayer. Spraying three different fields "around town" will get old about the second time you use a "tag along sprayer". A three point will use a PTO pump and not a 12 volt pump and in my opinion a better system. Three point sprayers also have good filtering systems. Most tag alongs have a filter on the end of the pick up hose in the tank. Ever sprayed liquid 7 with a tag along. Be prepared to get seven up to your elbows removing and cleaning the pick up screen in the tank. External filters, remove filter, clean re-install and start spraying again all in minutes.
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
FIFTH WHEEL PLATE AND MOUNT (A65643)
FIFTH WHEEL PLATE...
Landhonor 24" Semi-Automatic Tire Changer (A62679)
Landhonor 24"...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
