Work lamp
/ Work lamp #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Any you fellow pack members hook up the optional rear work light on a dK ? How, What switch? Is wiring there?
/ Work lamp
Noone here has ever wanted a rear work lamp?
/ Work lamp #3
I put a rear work light on mine back in Jan. can't remember the hook up method thinking was very simple wires were there on my DK40 SE
/ Work lamp #4
Mine (2006 model bought used in 2009) came with the rear work light already installed behind the seat. So I can't comment on installation. I can say the light comes on via a toggle switch on the light housing and also when tractor is in reverse. I have the somewhat odd DK45S configuration with the new-style engine control linkages and the old style (planetary final drive) transmission and chassis.
/ Work lamp
Well, I talked to Bob at MIE and he informed me the switch is on the light and the wiring is in the fender. He also threw in free hardware. As cheap as this light is you would think it would be included on the machine along with the trailer pin set-up. And there isn't any power jacks. I have one on my Simplicity.
/ Work lamp #6
More technically the wiring is under the U channel crossbar between the fenders (or at least it is on my DK35se). Also the trailer connector end wiring is there too. I used the wiring to feed my sprayer.
James K0UA
/ Work lamp
James K0UA
Thanks james I could not find it without your help.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2022 EZ-GO ELITE...
Frac Manifold T/A Trailer (A64194)
Frac Manifold T/A...
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2021 Ford F-150...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
