Tractor batteries - any recommendations?
/ Tractor batteries - any recommendations? #1
djw250
Hurricane alley (South Louisiana)
Mahindra 3510
Well after 7 years my grandson finally killed the battery in my Mahindra 3510 by leaving the key switch on. I am now in the market for a new battery, and figured I'd tap into the collective experience of TBN. Anybody have any recommendations for a new battery? Any experience with the brand that TSC carries? Thanks in advance.
Dave
/ Tractor batteries - any recommendations? #3
I have bought all brands and dont find that any one brand last longer or works better than any other premium battery. I dont care for the Sears Die-hard as I think they are way overpriced for the warranty provided and dont last any longer. I had one on my ZTR and it went bad in a year and it is a big battery not like the little rinky dink ones normally found on lawnmowers.
Walmart batteries last about as long as any other including Autozone which I have in my boat and Napa which I have in my Kubota RTV that replaces an Optima that went bad in 2 years. Closest dealer was Napa and the guy didnt even keep them in stock as he said most folks dont want to spent the $200+ for one and I didnt either.
Just get one (any brand)with the maximum cold cranking amps that will fit in the battery box and go for it.
/ Tractor batteries - any recommendations? #4
I've always bought middle of the road Die Hards. In the tractor they last about 6 years. The last one I bought for my last pickup was 4 years old and going strong. When you think about it a battery is a pretty good deal. You drop 80 bucks and it gives 6 years of service. That's about $13/yr.
I like Sears as they always have what I need in stock, it's one stop shopping.
The boat gets a new one every other spring whether it needs it or not. Unfortunately the boat's batteries are too big to fit anything else.
Just get one (any brand)with the maximum cold cranking amps that will fit in the battery box and go for it.- Good advice from Gary
Not sure the normal automotive battery retailers will have a battery this size. It is about 15 inches long.
/ Tractor batteries - any recommendations? #6
Google Battery Group size chart and you will find dimensions of various battery size groups. Find the ones that fit your battery compartment. Go to auto parts store of your choice and find the batteries with at least same CCA as your existing battery in the applicable size groups and correct terminal type/orientation. Choose the price/performance combination you want.
/ Tractor batteries - any recommendations? #7
After decades of having battery acid rot the metal battery area on my tractors I, switched to those Optima red top and yellow top sealed batteries they sell at Sam's Club. Probably costs a little more but it is worth it to me. No leaks.
/ Tractor batteries - any recommendations? #8
I personally like Interstate Batteries. They have a store close by and seem to have anything needed for our business or pleasure
/ Tractor batteries - any recommendations? #9
My tractor has a battery that is about that size. It turns out the battery also fits some Mercedes (or Volvos?), and I have always been able to find replacements at auto parts stores.
Steve
/ Tractor batteries - any recommendations? #10
Sam's Club and Costco sell a lot of batteries. Their warranty is first rate as well.
If you don't know the group size then just measure the L, W, H, take the measurements to the store, use a tape measure to find what fits.
As others have said, make sure the + and - terminals are lined up correctly. If you have very long cables it really doesn't matter.
Well, I found myself near my local Mahindra dealer, and thought I'd just support them. Got a battery at a reasonable price. I just hope it lasts as long as the original.
/ Tractor batteries - any recommendations? #12
I think the advantage of the dry cells (i.e. optima) is that they take the vibration better. I know that a lot of off-road trucks use them and they would do well in a tractor I think with all of the bouncing it does. I think that vibration and heat/ hold are what really kill a battery fast. I have never personally forked out the cash for one so I can't say. As far as other batteries go there aren't many manufacturers that make the batteries for everyone (I think there are 2) so I don't think there is a lot of difference between brands though there is definitely a difference between the different series' from the same brand. I have had luck with diehard gold and most everyone I know that knows anything recommends interstate but I really don't think it matters much.
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
(10) Free Standing 24' Cow Panels w/1 Gate (A64119)
(10) Free Standing...
2000 Jeep Wrangler 4x4 SUV (A61574)
2000 Jeep Wrangler...
2017 International HX620 Quint Dump (A62613)
2017 International...
