Oil & Fuel bobcats spendy hyd fluid
/ bobcats spendy hyd fluid #21
Hey gumshu, I also have an 09 Bobcat 235 and have similar problems...my oil cooler leaks(have to spray wash it after 5-10 hours) Did you say Bobcat has changed them and is it a warranty issue. If not I suppose I should just buy one and install it as I'm nearing my 400 hours service. I have also had nothing but problems with the loader hydraulic hoses leaking, had to replace all four...now the female receiver hydraulic couplers(under the tractor) are leaking...very poor design to have them in one of the dirtiest places on a tractor. I also had the battery acid issue...guess I'll get a sealed one, sounds like that fixed your problem . Shifting is a bit sticky, but workable. Now I need to replace the hydro fluid and you're saying there is other fluid that will work for less money? Guess I'll wait for the 400 hour change as I'm only down between 'full' and 'add'. Great forum...nice to know the problems I'm having aren't just with my tractor. Great unit even with the little problems. Only thing else I find had to find and the belly mower blades for the 66" cutting deck!
Hi Retaf. According to some of the posts on this forum, some owners have the newly designed oil cooler. I imagine that if leaks occur within the warrantee time frame, there should not be an issue. However, I'm surprised that Bobcat hasn't issued a recall on this.
I'm using the Super tech Heavy duty universal fluid sold at Wal Mart... I paid about 90 bucks for two five gallon containers with easy pour spouts. I poured the fluid into a 1 gallon juice container and then into the tractor using a funnel.
I also had a battery acid leak. I replaced the battery with a sealed Sears Die Hard. If your hoses are leaking you may want to try using reusable hose fittings from this site DiscountHydraulicHose.com
/ bobcats spendy hyd fluid #23
I believe he is referring to the fluid available from Tractor Supply Co. It's $40/5gl.
So the real question is, if I go with the cheaper TSC or Wal-Mart stuff, am I going to regret it later? Is the OEM stuff really that much better, or is it just marked up because it's from a dealer? If it is better, is it better "enough" to matter, or is it going to be the (arguably negligible?) difference between 10000 hours and 10500 hours on the engine?
/ bobcats spendy hyd fluid #25
Hi pwright,
Thanks for the information and the link,
Jim
I was going to use the Travelers Brand, but Tractor Supply was closed at the time, so I bought the Wal Mart brand for a little more. I haven't heard any negative reviews about either.
/ bobcats spendy hyd fluid #26
So here is the back label where it indicates what it is recommended for with the equivalent manufacturer part numbers. Sorry about the wonky focus.
/ bobcats spendy hyd fluid #27
I don't remember the specs on the Phillips 66, but I bought it from a oil guy I trust who said he sells it to all the rental places in town. He said it was great stuff. I was not super cheap as I remember. I think it was about $65 for 5 gal. That being said, I think it is all OK. Some hydraulic systems work just fine on motor oil. That is how they were designed. I just don't think it is rocket science.
/ bobcats spendy hyd fluid #28
Yeah... the specs on the Wal-Mart Super tech look the same. I'm not buying the Bobcat brand for twice the money.
/ bobcats spendy hyd fluid #29
Hi messmaker,
Thanks for the information. I agree it is not rocket science, I remember on a D2 cat we used for cultivating our orchards when I was you all we used was motor oil and it worked just fine.
/ bobcats spendy hyd fluid #30
I have very little difficulty shifting ranges, its not as smooth as a automobile gear tranny, but rocking the treadle does the trick for me
/ bobcats spendy hyd fluid #31
Thanks Gumshu...I'll check out those hydraulic fittings. I'm also going to see about a replacement battery....unfortunately the oil cooler is out of warranty...oh well, just replace it and move on. I do think I'll talk with Bobcat and see if they will do something....sounds like a common problem on these tractors..09 and older!!
/ bobcats spendy hyd fluid #32
Here is my .02 worth... I changed all my fluids, I paid the higher cost for the Bobcat brand. Reason being, if I need warranty work, I dont want them to question the fluids I used. After the warranty period is up, well thats when I would consider a different brand. I am sure there is not any difference in the oils, but its the fine print on the warranty card that would be the issue.
/ bobcats spendy hyd fluid #33
+1, I too used the fluid and filters from Bobcat, have no idea if their fluid is better than others. I do know that for every repair somebody gets charged for it, so if I do have a failure the tractor, fluid in it, and filters carry the same name so Bobcat would approve the repair and I get my tractor back working and then they can try to decide if it was component, fluid, or filter that caused it. If the fluid or filter carries another name, then the manufacturer (Bobcat, Kubota, John Deere, whatever) will take time to find the cause of failure or rule out fluid and filters before approving repair.
Fedral law prohibits any company from denying warranty if maintenance items are not purchased from them, but on same note they are not obligated to pay for a repair caused by something that they did not make or sell.
/ bobcats spendy hyd fluid #34
If your tractor is under warranty then most definitely go with their fluid. That's the wise thing to do. I'd do the same. For me... my warranty is up. I still buy their filters, but I'll use another brand for fluid. Mobil fluid 424 and Shell Donax are other popular alternatives, but pricy. If there was a problem associated with a particular brand of fluid, that company would be liable for damages. I doubt if major stores like TSC and Wally Mart would not stand behind their product. So far so good and coming up on another change soon.
/ bobcats spendy hyd fluid #35
I agree 100%. On my next change of fluids, I will be looking at alternative brands of fluids...I honestly believe its all the same stuff, just in different colored bottles :)
/ bobcats spendy hyd fluid #36
My take on hyd. oil is that Kubota or JD or any of the tractor brands specs listed on the buckets don't actually test the oil, you are simply trusting that the hyd. oil manufacturer makes sure their product meets those specs. If Shell or Chevron or Mobil could meet the specs and sell the oil for the prices that that the "no-name" ones go for, wouldn't they under-cut their major competitors, to gain market share?
It would be nice to see some official testing by the API like they do for motor oils, but in the absence of that, I'm going to stick with name brands.
/ bobcats spendy hyd fluid #37
according to daedong, the real manuf of this tractor, here is what they call out, this comes out of the Kioti service manual
how many of you actually do this service work yourself, is it pretty easy to do?
/ bobcats spendy hyd fluid #38
I didn't have a problem with it and thought it was simple.
/ bobcats spendy hyd fluid #39
Good THFs should state brand-name equivalences in their specs.
I look for the JD J20 and the Kubota UDT equivalences stated. I was
buying Chevron 1000 THF for a long time, but now have converted to
the UnoCal 76 THF. Some Kubota dealers have decent prices on
UDT in 5-gal bkts, too. All were never over $10/gal and look/smell the same.
Nowadays, I have been able to have my empty 5-gal bkts refilled for
about $8/gal.
There are some THFs I have seen at Walmart and TSC that state no
such equivalences on the labels. Steer away from those and the
straight hyd fluids.
Note that Bobcat/Kioti has some generic clear hyd fluid in their tractors
when imported from Korea. Go to a THF soon in the first service (not
more than 50 hrs.).
DFKRUG... The Wal-Mart brand does provide specs and claims to be a UDT equivalent. That's what I used for my last replacement and still have the bkts in my garage. I checked the specs before buying. I believe TSC's specs to be the same as I've seen other posts of people claiming to use it for their Kubotas. I was actually looking for Shell Donax or Mobilfluid 424, but those are hard to find around here.:)
/ bobcats spendy hyd fluid #40
:)DFKRUG... The Wal-Mart brand does provide specs and claims to be a
UDT equivalent.
Yes, I have heard they are carrying deluxe THF now, but I have not seen it. I would have
no problem using that, or the good stuff at TractorSupply. Both places have sold fluids in the
past that do not list branded equivalences on the label.
To add to the Acceptable list, I have recently bought 5-gal bkts of ServicePro THF, which is
listed as J20 and UDT equivalents. I got mine at a oil wholesaler, but I see that the local
NAPA carries it, too. Looks/smells exactly like the other THFs I have bought.
More info coming soon (A61569)
More info coming...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
SHOPBUILT 500 GALLON PULL TYPE SPRAYER (A63290)
SHOPBUILT 500...
