M59 hydraulics got slow and weak.
   / M59 hydraulics got slow and weak. #121
......... So the foaming has to be bad. I am running the new synthetic Kubota fluid. Maybe change to new fluid?
You might be thinking of the posts we had on that subject earlier. (posts #56 & #107...I think....)
At 200 hrs changed to SUDT. It didn't work well in my tractor and one of the problems was it foamed easily and took a long time to clear up. I did the same sort of test that you did. My hoe worked OK even with the foaming but the hydraulic pump developed a whine. Since the SUDT foamed so much I complained to the dealer and also wrote a letter to Kubota telling them about the foaming problem and asking them to check their oil themselves. Long story short: I never heard back from either one.
After not hearing any response for a couple of months I played a hunch and went back to using the New Holland Multi-G 134. That fixed my hydraulic problems.
BTW, my tractor came from the dealer with a mix of standard Kubota hydraulic oil and New Holland Multi-G-134. The Kubota oil simply because that is what was in it when new, and the G-134 because the mechanic spilled about half the original tranny/hydraulic oil when he changed the filter G-134 is what that particular Kubota shop carries as their bulk oil in drums, so that's what they put in mine. It worked fine for almost 200 hours until I decided I just had to try the SUDT.
rScotty
   / M59 hydraulics got slow and weak. #122
Is there anyway to keep the m59 hydro oil from being infused with air? I think its a big problem of mine. My tractor starts off digging good but loses power after it is worked(still!) So I took a small sample of fluid after being used and put it in a clear plastic container. It was milky with air. After it set a couple of days it was normal looking, no air. So the foaming has to be bad. I am running the new synthetic Kubota fluid. Maybe change to new fluid?
A cloudy appearance could also indicate water contamination, however the symptoms you report sound more like air entrainment. You can test for water contamination by putting several drops on a hot plate; if water is present it will sizzle.
Possible causes of air getting to the system are 1) reservoir level too low (probably ruled out), 2) a leak in the suction line anywhere from the tank to the hydraulic pump, 3) a damaged return line with fluid pouring into the top of the reservoir instead of discharging below the top level. The first thing I would check for would be 2). All it would take is a pinhole to get air entering the system during operation. A small leak would result is air entrainment and spongy oil; a large leak could cause pump cavitation and eventual destruction of your hydraulic pump. If there is any sign of static leakage around the suction line (when the machine is turned off) that would indicate a possible problem. Conversely if oil is placed on a clean joint or connection in the suction line, and it disappears during operation, that would indicate a point where air could be drawn into the system.
   / M59 hydraulics got slow and weak. #123
rScotty
I don't question this, but I just wonder if there wasn't more going on here beyond just changing the type of oil used. It is hard to believe that the manufacturer specified oil would not work for the tractor, nor is hydraulic oil all that complicated, so there may be some other explanation. Probably any high quality oil that meets UDT or preferably SUDT specs would work. Changing the hydro oil and filters is a pretty significant change to the system. Perhaps in the second oil change something happened in the input (suction) line - a loose fitting or maybe the oil filter in the suction line had a small air leak at the O-ring? If so, just replacing the oil and filter with anything else within spec could very well have "fixed" the problem. A good test would be to go back to SUDT2 the next time you change out the hydro oil and see if the problems recur! (consider it for the benefit of science :))
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=277104"/>
I'm sure it's air,mill take a pic tomorrow and post. You would think with all the testing they did they would find it. The oil clears air after it sits, that makes sense that it starts off strong but gets slow. Thanks
   / M59 hydraulics got slow and weak. #125
Yes, I can't disagree with what you are saying. In fact I completely agree. It makes sense that all hydraulic oils are basically similar and able to be mixed. After all, the tractor is designed to power hydraulic attachments.....and that means that whatever oil is already in the attachment will be mixed with the tractor's oil. Kubota's SUDT synthetic specs offered a slight improvement at low temperature and I thought of it as an upgrade so made the change.
Even as I filled it, I could see that the SUDT had entrained bubbles just from being poured in the funnel...and that they persisted longer than expected. As you say, there might be some other explanation for what I was seeing. For my part, I was more intrigued than concerned; just made a mental note of the fact and didn't think more about it until the louder pump noise began to bother me. In retrospect, it took me way too long to figure out that the oil itself might be the problem. And I still don't know that the oil was the reason. As you say, it could have been something else.
I didn't do any tests on my SUDT oil - just drained it into the original buckets and contacted Kubota. No response to that so far. I also don't know if Kubota makes or monitors that oil. The labels on my containers say that the country of origin is the US. It is date stamped Aug, 2008. A few months later after I got to wondering if the pump noise might be connected to the oil I went back to the dealer to ask for more information. I was told that Kubota no longer sold the SUDT. They had pulled it all and changed to a new formulation called SUDT2. That's when I decided to change back to the New Holland.
rScotty
That is after changing front bucket to pallet forks, maybe ran it 15 min.
That is Sitting in jar for 1 hour. You can actually watch the bubbles coming to the top like carbonation. This has to be my problem.
as of now i have smeared grease all over the pumps and suction lines, atleast all i could reach. this is what dealer said to do. no help. has anyone else ever noticed thier fluid when changing it? could this be normal for the M59? im trying to get it in the shop but absolutly need it every other day but will get it in befor 11/20 when warranty is up.
   / M59 hydraulics got slow and weak. #128
The old fluid in mine was perfectly clear when I changed it out; looked the same as the new fluid (the filters however had picked up metal bits and definitely needed to be changed). But it had been sitting for a while so it is not a conclusive test. I haven't had a chance to draw some fluid out after having used it hard for a while, which would be the thing to do to check air entrainment. From your pictures and symptoms it definitely looks like this is your problem however. In addition to the suction lines and pumps, the filter for the suction line (one of the two on the right side) is also a potential source of the problem, as air could be drawn in if there were any leakage around the o-ring.
   / M59 hydraulics got slow and weak. #129
Was your dealer being serious? Or just being cute? I hope you don't mind, but that mental image of you crawling around that smearing grease all over the tractor is definitely worth a grin.
I keep re-reading what TBarD wrote back on 8/16 and agree that it looks like air entrainment. No, I haven't checked my own M59. But my first reaction is that any air entrainment in a hydraulic systems is not right. But is that correct? Anyone know?
Here's an experiment that is lots less messy: Somehow extract or drain a quart or less of your hydraulic fluid into a mason jar and then buy a quart of some other brand hydraulic fluid and put in a similar jar. Now shake them both up good or see how the foaming compares. You might even get your dealer to sacrifice a $20 blender from BB&B to the cause....You gotta admit it sure would be nice if the foaming could be fixed so easily.
Hmmm.....I wonder if it's possible to get a sample by running a catheter-sized tube down the oil filling port and pulling some oil out with a big syringe? If you have livestock then things like catheters and syringes are probably in the barn there somewhere.
rscotty.
Thats where I get my samples, from the oil fill. I use a fluid extractor that looks like the tail end of a grease gun and extended the clear tube on it with 3/8" pex. It reaches the bottom of sump. if my tractor is sitting and i draw some out it is clear. start it and let it run for 5 min and the oil is entrained. with 20-30gpm and such a small sump on these things maybe this is normal.
12' CONTAINER (A52706)
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2017 Ford Escape SUV (A59231)
2017 Ford Escape...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
