Box Scraper Box blade or Scraper Blade
/ Box blade or Scraper Blade #1
Booyeah
Kubota Bx2200
Have a Bx 2200 with FEL that I plan on using mostly for driveway maintenance in both summer and winter. I have a mostly TRG driveway ( some dirt areas) that is starting to show some runoff . I want to put some more material down and regrade/ recrown the trouble areas and/or the whole(600') drive. What is the preferred 3ph implement for this job?
/ Box blade or Scraper Blade #2
If you have to deal with snow and you are only going to get 1 implement, then a scraper blade is going to be the way to go. If no snow, then I would suggest a land plane grader blade would be the best single implement for your drive. If you have other chores to be done around the yard, then a box blade is a very versatile implement that may actually suit you better.
But to solely deal with your question, then the rear scraper blade. There are many other things to consider though. Ideally several implements would get you the best-fastest results. All depends on what you are willing to do-have for implements.
Good luck
Thanks! I'm kind of new to tractors I bought mine used last fall and didn't know about a land planer. As far as snow removal I have a front mounted snow blower which served me well last winter I'll look into all of these to see which is most versatile vs. cost effective for my needs.
/ Box blade or Scraper Blade #4
Well...rear blades are usually less expensive than box blades. Box blades have teeth that need to be replaced when they bend (not exactly cheap, I've bent a few). So, the rear blade is definitely more economical. However, you can only scrape/push with it, whereas the teeth on the box blade have more of a ripping affect. It sort of depends on how far down you have to go on your driveway as to which implement would work better. If you're planning on basically ripping up the whole thing you the box blade would come in handy, but if you can get away with scraping it down and throwing some new stone on it, I'd go with the rear blade.
/ Box blade or Scraper Blade #5
We owned a BX2200 first and now a BX2660. I got a box blade and scraper blade. Maybe it's just me, but I could never do much with the scraper/back blade and used the box blade much more often.
I now just use the BX for mowing and got a bigger tractor to work on roads etc.
/ Box blade or Scraper Blade #6
I say get a scraper blade since you want to move snow then get a box blade later.
/ Box blade or Scraper Blade #7
If the snow blower has worked well for you, then I would get the LPGB. but that is just me.;)
/ Box blade or Scraper Blade #8
If I could only have one implement and the choice was between box or blade, I'd take the box. It can move dirt/gravel from here to there very efficiently. Harder to crown a road with it for sure, but it can be done. Blade is not as versatile. I have never weighed the two comparitively but I believe the BB will offer better ballast as well. My opinion.
/ Box blade or Scraper Blade #10
you have a "land plane" MtnViewRanch shows in a picture. in idea it sifts the dirt and gravel. letting dirt fall down and bring rock up to the surface. suggest getting one that has adjustable blade heights
you have box blade. with scraficers / teeth. used for filling in holes and getting a nice finish smoothness across areas. the teeth also help break things to make it easier to smooth out. get one that allows you to adjust teeth up and down. there are different types for the cutting edge on them
you have a rear blade, good for snow removal, and can help bring rocks on sides of driveway back into the drive way. as you angle the blade. get something that can cover rear tires when angled.
you have a york rake, think metal garden rack, but 3pt hitch version. and look much like a rear blade, but has tines instead of a blade. you might consider gauge wheels for this.
you also have "ratchet rake" they fit onto cutting edge of FEL. and can be used to help break up rocks/hard compacted dirt. and then removed to easily back drag with FEL.
you also have tooth bar for FEL. it is like a "ratchet rake" but more geared for just digging. pending on how the teeth are made and attached to bucket, you might be able to use it like a ratchet rake.
you also have "FEL" front end loader. and scooping and back dragging.
they all have there con's and pro's and what they do best in certain scenarios.
EverythingAttachments.com has good descriptions and should have video's of all the above showing what they can do / how to operate them.
with you having FEL, i would say a min of 2 implements above.
a FEL goes a long ways in back dragging, but it can be a pain to get a real nice smooth finish just using a FEL, and with that either land plane or box blade. would help get that real nice finish touch. all other implements can be a pain, in trying to feather the control of 3pt hitch or FEL. to remove any small little dips/bumps in the total length of the driveway. granted only 600' of driveway, and a little extra work with something else. would most likely be very acceptable to many.
scraficers/teeth on box blade, york rake, ratchet rake, tooth bar. having one of them to help break up the inital couple inches of hard compated dirt / rock. makes life much more easier to smooth out driveway and place a crown on it. vs having FEL and 3pt hitch implements, skipping across rocks and dirt creating mini speed bumps. the box blade scraficer/teeth will be most likely strongest thing out of the above. and more likely be able to break through compact rock/dirt the quickest. and less likely to break / bend.
rear blade and york rake shine. in bring rock on sides of the driveway back into the drive way. ya you can drive at 45 degree angle. and go clear around the drive (both sides), going back and forth every few feet using some other implement. but WOW talk about a time consuming, and you may not have room to get tractor turned enough to use FEL or other 3pt implement. and you will most likely taking chunks out of the yard / dirt on side of the driveway bring in more dirt into the driveway. vs rear blade or york rake, were you just drive down one side, and back up other side, and your done and no forward / backing up 100 plus times.
TNT (top and tilt) instead of getting off tractor to adjust the top link or side link for 3pt hitch, to adjust tilt and angle of 3pt hitch. the top link and/or side link turn buckles get replaced with a hyd cylinder. a TNT setup can really make all the above 3pt hitch implements shine in how long it takes you to deal with driveway maintenance, and result you get. if you have a curved and/or hilly drive way. were the crown for the drive differs a lot. the TILT (side link hyd cylinder) will come in very handy.
/ Box blade or Scraper Blade #11
Just my thoughts? I have a BB. Although it took me some time to use the BB proficiently, once I learned through trial and error, it's the "Cat's Meow". I also regard the BB to be a more versatile implement. Best wishes.
/ Box blade or Scraper Blade #12
Don't know everyone on the thread but I do know the people who have all of the aformentioned implements are suggesting a landplane. I can see and understand a discussion such as landplane vs. boxblade but the boxblade vs. rearblade is comparing two differnt tools with different uses.
/ Box blade or Scraper Blade #13
As I said in another similar thread, in my experience, a tractor like yours won't pull a rear blade, much less a box blade.
Years ago, I had a Kubota B7200, 17 hp, 2WD. I bought a rear blade and the results were completely unsatisfactory. 2WD and the light weight didn't even pull more than a 3" snowfall and was stopped dead by a rough spot in the yard I was trying to smooth out.
Sorry, but my advice is if you need to get a blade, you need a bigger 4WD tractor ... and don't waste your $$ on a rear blade, get a box blade for that larger tractor. My .02, for whatever it's worth.
(Even my 55 hp 4WD with the box blade rippers down and loaded tires has been stopped dead by a big root.)
/ Box blade or Scraper Blade #14
Love the box blade but never used one on a tractor with less than 45 HP. A box full of any material requires some rear traction for sure.
SERVICE BED FOR TRUCK (A67714)
SERVICE BED FOR...
2010 . TRIAXLE LOWBOY (A67714)
2010 . TRIAXLE...
2006 7X12 Lark S/A Enclosed Cargo Trailer (A66738)
2006 7X12 Lark S/A...
CAT D5N Straight Blade / C-Frame (A68134)
CAT D5N Straight...
2007 REINKE TRAILER Combo Spread Axle Flatbed (A67714)
2007 REINKE...
2012 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2012 CHANDLER TRI...
