Ford 3000???? Problems
/ Ford 3000???? Problems #21
well.. she ain't a 3000.
gear reduction rear ... and wet brakes.
heavy front bolster.. and that front axle ain't the 1939 design.. looks like some sort of industrial. I'm not up on all the 4 digit and 3 digit industrial variants.. but could be some sort of 3 digit industrial. front axle is deffinately not the ld fixed.. or the adjustable hd of a 4000 or a adjustable ld on a 39-65 00/01/2000/3000
a 445 is what really comes to mind... especially looking at front and back axle.
might want to bring in whodat and rickb on this.
Looks like a 4500 to me. Hard grille shell, straight axle, planetary finals with wet brakes. Factory alternator and CCW tach dial might make it a 445 except they had fully hydrostatic steering which this doesn't. Thinking a little more, it could be a 3550.
/ Ford 3000???? Problems #22
i missed the steering.. and I should have known it.. after i looked at some industrials last year.
So I cleaned out the transmission and it was filled to the top it looked like baileys Irish cream, kind of a tan so I opened the bottom drain and about two gallons of water came out followed by the tan mixture I started playing with the shift pattern and it is a 6 forward speeds and 4 reverse speeds with a high and low. So far all the parts I have gotten for the tractor have matched up when i ask for a ford 3000 part. The fuel pump, injectors and starter so far.
Semper Fidelis - Freedom isn't free, to see the cost visit your local VA
/ Ford 3000???? Problems #24
Everything you have asked for would probably bolt up to 30 different models of Ford tractors. Some might even be correct. That isn't a 3000 and you can take that to the bank.
/ Ford 3000???? Problems #25
you had lots of oil/water emulsion in the trans.
i'd dump in some diesel and atf fluid and cheap flush utf oil plus a quart of 90% rubbing alcohol.. do a victory pass around the yard... just a short ride to slosh the mixture... then drain and refill with clean utf.
Can anyone decode the serial numbers and tell me what I have I would like five true appropriate manuals
Thanks
Craig
Also what is a gear reduction rear end? I am guessing I am missing out on something that I have and don't realize or know how to use...
Thanks again,
Craig
/ Ford 3000???? Problems #29
Someone else will have to help you with the serial numbers. (may have to go to a dealer with that question)
As far as the gear reduction rear axle, some of the industrial tractors had those for very low speed (creeper) work, like trenching. Don't worry about it.
Definitely not a 3000. I agree it's an industrial tractor. Looks like a 4400 to me. Do a web search for "ford 4400 pics" and look for yourself.
/ Ford 3000???? Problems #30
that could be part of your hard starting problem the injectors for a 3000 is set at a different pressure than a 4500 because a 3000 has a 4.2 bore piston and a 4500 has a 4.4 bore they have different tips in the bottom of the injectors but the injector shells are the same and will interchange
/ Ford 3000???? Problems #31
Upon further review...... I took charcoal and rubbed it on top of the tabs the numbers are as follows
5C 315
5021G
C138473 6E10
I've been trying to decode the numbers you provided but the model number doesn't seem to match anything I've been able to locate. If you take a clear picture of the numbers it might be helpful.
/ Ford 3000???? Problems #32
the gear reduction rear is simply the bulge you see at the axle trumpets... just the design.. inboard wet brakes and all.
3000 would have smaller trumpets and dry brakes outboard..
/ Ford 3000???? Problems #33
i agree.. he's mising a number or so inthere...
/ Ford 3000???? Problems #34
I eventually sand blasted the numbers on mine.
Boy did the numbers change.
DS
/ Ford 3000???? Problems #35
he really should continue to id this machine rather than keep buying parts for a 3000
he's eventually gonna pay cash for something that won't bolt up.. or if it does bolt up.. won't be correct..
can't wait for him to order a brake kit for a 3000 :)
/ Ford 3000???? Problems #36
I agree, I'd like to see the write up on that installation.:laughing:
Ok so I sanded the number plate it appears to be 45012G and it is a 4forward 4reverse transmission
The 4 is added to the 5012G
I called new holland this afternoon and got confirmation it is a 4500 industrial 1966. I confirmed also that the starter I bought for a 3000 will also work in a 4500 it actually works in 43 different ford/nh engines. I looked at tractordata.com and they only show a 63hp rating for the 4500 does anyone know what the drawbar rating is?
/ Ford 3000???? Problems #40
That would be 50 hp at the drawbar.
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2022 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
2022 USA...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
x (A68191)
x (A68191)
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
