L4330 Turf Tires
/ L4330 Turf Tires #1
LindyT
Does anyone know the appropriate size for turf tires on an L4330? Tractor data only shows AG tires, which I already have.
Thanks for any help!
/ L4330 Turf Tires #2
there were two sizes, 29x12.50-15 and 44x18-20 and galaxy tires 27/10.50LLX15 and 41/18LLx16.1
Just happened to have the price book out!
/ L4330 Turf Tires
Thanks for the quick reply, Art!
Are there any advantages to one size over the other? I found a set of new takeoffs in the Galaxy 27/10.50LLX15 and 41/18LLx16.1.
Thanks again!
/ L4330 Turf Tires #4
I think the galaxy tires are smaller diameter, super wide, minimum tread, thin ply golf course mowing tires. Here are my 44x18-20's. Philip.
/ L4330 Turf Tires #5
less tread depth = minimal turf damage. If you found a set of take-off galaxys, you're lucky. New gets pretty expensive.
Brian
/ L4330 Turf Tires #6
hey art...do you know which ply those are?? Titan® Tire catalog
thanks! Mike
/ L4330 Turf Tires #7
The first set are 6 ply fronts and 4 ply rears. Don't know about the galaxy tires
/ L4330 Turf Tires #8
/ L4330 Turf Tires #11
Hey i am fixing to change the tires on my L 4330 does anyone know the lug nut size i don't have a socket for the rear
Thanks
Mike Henry
/ L4330 Turf Tires #12
Mike, Rear is 24mm, 15/16" is also good fit. Front is 22mm, 7/8" is a little loose. FYI, this is on L3940. Philip.
/ L4330 Turf Tires #13
24mm and/or 15/16" seem to be best fit, although both are a tad loose...but 23mm is definitely too small ...they do make 29/32" and 59/64" (for Chrysler ball joints) but I don't have either one to try
/ L4330 Turf Tires #14
Thank you Phillip and Joe !!! Now the fun part!!! Again Thank you!!!
