CK30 Tach Trouble
/ CK30 Tach Trouble
VictorW,
Thanks so much for the post there! I took apart my dash and put it all back tonight. I was looking to see if the connection wasen't good. It was fine and I dabbed a spot of dielectric grease on the one pin. Did that to the pickup sensor as well. Yes, grasping at straws I know. There was no change. But I was starting to question the pickup sensor as I never measured 481hz which is 850rpm. But you're confirming for my it does idle at 1000rpm which sounds right then because mine was around 560 and Kioti says 1000rpm is 560hz so it must be working. Dang! :)
The dealer is going to let me return that DU though so that's good.
/ CK30 Tach Trouble #22
Well, wished I'd read this earlier............let me know if you go for that complete dash unit 'cause I bought one a few years ago just to replace the fuel and temp gages! So I have the tach/hour meter (brand new 0 hours) cluster just sitting here which I may be willing to sell far cheaper than the price of a whole new assembly. What year is your kioti?
/ CK30 Tach Trouble #23
All manuals (workshop and service) are available free at pfgaustralia.com.au I downloaded the whole lot for my CK30.
Tacho faults are at the end of the workshop manual.
Possible Cause
• Trouble in eletronic pick-up sensor,
display unit or wrong wiring.
• Gear in combination meter defective
Condition
Engine tachometer
does not
function when
engine is
running
Remedy
Replace if necessary
Check the connection
Check the gear and replace if necessary
/ CK30 Tach Trouble
Thanks Alien. I have the paper manual now as well. I did see that in there. My dash is all electronic no cables. Since my tractor is in fact idling at 560hz that is 1000rpm. I verified those numbers right up to the DU. Out of the DU it halves the numbers which is right after all. I think in the future this thread is going to save someone a lot of trouble. Try 2-3 weeks of trouble. haha
I started having thoughts about that PS. But I think Victor silenced those. Even if the PS didn't work right above idle speed then the tach should still read 1000 at idle at it doesn稚. Just reads a dumb 0. It'll slowly rev up to 500 and that's it. What a bummer!
Possible Cause
Condition
Engine tachometer
does not
function when
engine is
running
Remedy
/ CK30 Tach Trouble
DirtHauler,
Heck your post is the best one so far! lol I'm going to send you a PM with my email and phone number.
Thanks,
Brandon
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
