hours per year
/ hours per year #41
Carl,
Its a mechanical hour meter connected to the tachometer found on many brands versus the electric meters. I dont know about the B26 setup but if you have a cable running from the engine to the back of the panel its likely mechanical.
For instance, on my Cub Cadet when the switch is on the timer will tick along and thats "real time" my Ferris its digital and runs off the PTO switch for the blades, so thats "partial real time" meaning when hauling wood or not cutting grass no hours are logged.
Clock it next time you are running your tractor when you start it and when you finish w/o turning off the engine. I bet its mechanical too.
So if you like me run 40 hrs per year at less than 540 PTO speed (or around 22-2400 RPM) it will log less time. Let me know your results.
Carl
/ hours per year #42
What exactly does that mean? The B21 registers hours based on RPM and not on actual time? Do all Kubotas do the same? This is the first I have ever heard of this. If this is true, then at what RPM does it register real time?
As far as I'm concerned, an hour meter should always work on real time and nothing else.
Most tractors and construction machinery register hours at 1500 rpm - therefore never assume the hour meter is showing actual hours worked. For example, a tractor that does a lot of yard work will almost certainly have worked longer than the hours shown, while a tractor working in the field (especially using the pto) will have worked less actual hours than shown on the clock...
On larger self propelled machines (combines / forage harvesters etc), there are normally two hour meters - one for the engine, and one for the drum / chopper (pto).
/ hours per year #43
I originally thought that the CUTs hour meters were on a time basis. However over the past year I was suspicious that the was not the case for my Kubota B3200 so I timed it. Running at PTO RPMs one tenth of an hour goes by in around 6 minutes. At idle, it is nearer 15 minutes. Therefore the hours on my machine appear to be the hours at PTO rpm so when I am at lower revs for say loader work, I record slower hours.
Craig
/ hours per year #44
I originally thought that the CUTs hour meters were on a time basis. However over the past year I was suspicious that the was not the case for my Kubota B3200 so I timed it. Running at PTO RPMs one tenth of an hour goes by in around 6 minutes. At idle, it is nearer 15 minutes. Therefor the hours on my machine appear the hours at PTO rpm so when I am at lower revs foe say loader work, I record slower hours.
Craig
Both my CUTs are that way. Hours are based on engine RPM.
/ hours per year #45
Bought 2000 TC29 in April,30 hrs so far by me,total 350,but it's been extremely dry,haven't mowed since first of June.
/ hours per year #47
oldnslo said:
When I still farmed we put over 500 hrs/year on three different tractors. The oldest we had was a 1966 5000 Ford that showed over 6000 hrs on the third hour meter tach assembly. Now that I don't farm anymore it depends on the weather, no rain or snow means no hours...
If it showed over 6000 hours on the third hour meter tach assembly, how many total hours did it actually have?
/ hours per year #48
Carl_NH said:
Carl,
Carl
Ok so if I just turn the key on, without starting the engine, and the meter is moving, then it's electronic and calculates actual time. If I turn the key on and after let's say 10 hours nothing moves, then it's mechanical correct? Thanks
/ hours per year #49
Carl_NH said:
Carl,
Carl
So if you used your Ferris primarily for hauling wood, how would you determine when to do oil changes or other maintenance, which is what I thought was the main reason for having an hour meter. That and resale.
/ hours per year #50
Hauling wood and other non mowing activitites maybe 5 hours a year so in the overall scheme of things isnt a factor since I tend to do engine oil and filters every 16-18 months or 50 hours on all the equipment. It has worked for my Cub Cadet for 22 years so no reason to change now.
/ hours per year #51
I justified buying my used Kubota to finish clearing, grading and seeding a 3-acre pasture, as well as to install approx. 1500 feet of fencing. I put close to 125 hours her first 9 months, but since then I use it only maybe 3 hours a month (mowing pastures, breaking up poop piles, moving manure, moving lawn clippings, any other job that could be done with a wheelbarrow:).
Even though my use has gone down, I love having her waiting and ready (she came in handing cleaning up after the thunderstorms last month).
/ hours per year #52
Carl_NH said:
Carl,
Carl
Ok I checked my John Deere X595. I started it up and let it run at idle. The hour meter was running and seemed to be calculating real time. I then tried shutting it off, but turning the key on. The digital hour meter was lit up, but it was not running. I was happy about that, because I have heard others talk about how they accidentally left the key on and ran up the hours. Anyway I will check the B26 next.
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
UNUSED ATSPOWER ATS-SP50 50 TON HYD SHOP PRESS (A64281)
UNUSED ATSPOWER...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
UNUSED RANCH HAND BRUSH GUARD (A64280)
UNUSED RANCH HAND...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
