IH 140 chokes down
/ IH 140 chokes down #1
w12kpm0w40
McColl, SC
1963 IH 140
:mad:
After teradown and replace 2x the carbeurator on 52-63 IH 140 w/ zenith carbeurator
The tractor cranks right up!
It runs wel. As soon as I engage pot, it stalls and will choke down unless I stop pto.
The tank has ben drained and is clean; the filter screen is clean, fuel is arriving to the neck of the carbeurator. Why does it stop/choke down when pto engaged??
My grass is growing by leaps and bounds.
Al
/ IH 140 chokes down #3
Have you tried adjusting the main jet..?? If I'm understanding right, this is a new, or rebuilt carb..??
Gently run the main jet screw in, until it bottoms out. Back out 1-1/2 turns, and see how it runs then. If somewhat better, but not to suit you, you can tweek it in or out from there to get the final adjustment.
/ IH 140 chokes down #5
w12kpm0w40 said:
thank you
Does it stall out only when you use the pto, or does it also stall when you drive it? Could be your pto is frozen up.
only stalls when pto runs cutting with bushhog after a short distance symptom is like choking down than torque from pto strain or lockup
/ IH 140 chokes down #7
After re-reading your original post, about the filter screen... Is that the one above the sediment bowl..?? If so, did you check the internal one in the carb.? Where the fuel line attaches to the carb., that el has a filter screen on it.
Sounds like lack of fuel, or you've got a vacuum leak.
Or, possibly the governor is not activating like it should, when under load asking for more fuel.
/ IH 140 chokes down #10
My fuel line is steel, but I suspect, it could happen with either. Good luck.i
/ IH 140 chokes down #11
I believe this was a problem even before ethanol was introduced, ethanol just makes it worse... I've seen more then several older Ford tractors with spring type clothes pins on the fuel lines, for a heat sink. We had a 4000 at work with a belly mower that our mechanic put a couple on it, and solved the problem.
/ IH 140 chokes down #12
And could be that rubber fuel line has collapsed somewhat inside, restricting fuel flow.
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
2005 John Deere 7420 (A60462)
2005 John Deere...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
HYDRO TEK PRESSURE WASHER (A65643)
HYDRO TEK PRESSURE...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
