2 phase electrical motor not running, help please
   / 2 phase electrical motor not running, help please #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
The motor for the table saw stopped running.
Well that's not correct. it starts, flips the breaker and stops. From the sound of it, seems it runs on one phase only. I did the obvious - got new capacitors and swapped them - with zero effect.
The motor is little bit over a year old and it never even flipped the heat protection - because it is 6.5HP at 10" table saw :D
Please, advise. Next thing I will check is the centrifugal switch, but I am open to suggestions.
I checked the field resistance, checked each field against the ground, the outlet is putting out the correct voltage, I am stumped.
   / 2 phase electrical motor not running, help please #2
It is a single phase motor,check the armature. and cord.
No, it runs on 2 phases - 240V - and the cord is ok - gives 240 on the motor. The armature I checked and it is ok too.
   / 2 phase electrical motor not running, help please #4
Are you sure it is not 240v single phase? I thought the next step up from single phase is 3 phase.
   / 2 phase electrical motor not running, help please #5
Hi Prokop,
220 / 240 Volt motors are run off of 3 wires ( some have a forth ) You have 2 hot wires and 1 neutral. 4TH is a additional ground. The 2 hot wires switch back & forth (In the motor.) as to which 1 is supplying power.
6.5 HP requires a lot of amps, very few circuits can handle that many amps.
Not an electrician, but have never heard of it being called 2 phase.
3 Phase is the next step and a whole new ball game.
OK, my bad. Overseas we have 3 phases as residential grid and in a brain fart I called this one two phases since it connects to two phases. You guys are right, single phase wired to 240VAC.
The motor was running fine for a year and the breaker never flipped before - lot of power for the mid size saw - but I like it that way.
BTW 3 phase asynchronous motor is one of the best technical solutions out there, simple, strong and foolproof. Too bad it is not available in USA - it is effective and also good for the grid. No capacitors, just goes from star connection to triangle and that's it.
   / 2 phase electrical motor not running, help please #7
3 Phase is available in the US, but not on very many house hold type circuits.
Most large commercial motors use 3 phase. One leg always pushing or pulling. And most of them use 440 Volt power.
There are Inverters (not sure what the real name is.) that will convert your current to 3 phase. No idea how good they are, but do think costly and not worth the trouble.
I would change or replace the breaker. If it has been working at or near capacity heat may have caused it begin failing.
Check motor amps and add 20% for the correct breaker size.
   / 2 phase electrical motor not running, help please #8
If you replaced the capacitors, the start switch is probably not making good connection. Usually tapping or jarring the motor will do the trick. My table saw occassionally requires a tap or 3 on the motor if it has been a while since I used it. Once it starts the first time, it starts fine until it sets a few months.
Start switch - would you mean the centrifugal switch by that? Because I already bypassed my Start/Stop switch.
   / 2 phase electrical motor not running, help please #10
Yes, I meant to say the centrifugal switch.
...I just reread your original post and you say it starts, then trips the breaker. If it is turning for a few seconds, then tripping the breaker, the centrifugal switch may be stuck closed, keeping the start winding energized longer than it should. See if you can move the weights and make the switch open. It may need a shot of WD-40.
2015 Jeep Compass SUV (A56859)
2015 Jeep Compass...
2016 Husqvarna YTA22V46 46in Riding Mower (A56859)
2016 Husqvarna...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A52709)
2018 CATERPILLAR...
1605 (A57192)
1605 (A57192)
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
skeleton / rock bucket (A56857)
skeleton / rock...
