Hot Tranny
/ Hot Tranny #1
Mark Page
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
How hot is too hot for a synchroshift geared tranny with 10 wt. hydraulic/transmission fluid? Mine is getting hot enough to burn me if I touch the transmission cover, brake pedals, clutch pedal ot the transmission casing itself.
/ Hot Tranny #2
Is that the correct fluid?
/ Hot Tranny #3
Normally 180 - 200 degrees F is considered the max temperature before the oil or seals are compromised. 130-140 degrees is where it is so hot you will get burns from touching something.
Do you have some thing in the hydraulic system adding heat? Like 3PH control stuck in the raised position, Directional valve lever being held partially shifted, etc..
/ Hot Tranny #4
Modern hydraulics are designed for somewhat higher operating temps. Even temps of 210 for short periods will not damage the seals. That is the big issue with transmissions, having the seals begin to deteriorate due to heat. If you think it is running too hot see if you can find someone with one of those laser reading infrared thermometers, greatest thing since tachometers for assurance and troubleshooting.
/ Hot Tranny #5
If you can find the right size seals in Viton it will handle more heat and still seal
/ Hot Tranny #6
Sometimes the most simple little phrase or innocuous couple of words takes you to places you just don't want to go when you Google them....:eek:
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2019 Bobcat T650 (A64126)
2019 Bobcat T650...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2019 CHEVROLET SILVERADO 2500HD (A65643)
2019 CHEVROLET...
KUHN KNIGHT SLINGER 8118 SPREADER (A63276)
KUHN KNIGHT...
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
