Oil & Fuel Pump to transfer diesel, 5 gallons at a time
/ Pump to transfer diesel, 5 gallons at a time #1
sandybeach
Whidbey Island,WA
Branson 3510H
Those 5 gallon fuel cans are heavy. The new style are incredibly awkward. I'm getting old.
I need an easy way to transfer fuel from can to the tractor's tank. What I think I need is a small, inexpensive 12V pump that can deliver 1-2 gpm 3' vertical ... or a big dumb guy who works cheap and on short notice.
Even a siphon would be OK, if it can do the 1-2 gpm, 3' vertical.
However, I'm open to advice.
/ Pump to transfer diesel, 5 gallons at a time #5
Take about 2.5 minutes for 5 gal
/ Pump to transfer diesel, 5 gallons at a time #6
I feel your pain (literally). Climbing up on the tractor to fill through the hood with a 5 gal can gets old in a hurry.
This pump from Harbor Freight does a great job. Hook it to a battery and it pumps like a buck in rut. 10 gpm and has decent reviews unlike the Amazon one.
Diesel Transfer Pump - Save on this 12 Volt Transfer Pump
I got mine with coupon for $70. You can also use the ever-present 20% off coupon. Neighbor has one too and loves it.
It will also pump hydraulic fluid. I hate to fill the hydraulics on the L48 and BX2200. Haven't done it yet but will use it next time.
/ Pump to transfer diesel, 5 gallons at a time #7
I put a piece of tubing over the nozzle of the fuel can, put the fuel can in the loader, raise the loader higher than the tractors fuel tank. Stick the other end of the tubing into the fuel tank, then tip the fuel can on its side so the tubing covered nozzle is facing down and let gravity fill the tank with fuel.
It's not fancy, but it works without spilling or having to hold the fuel can.
I love it! It's worth a trip to the hardware store and couple bucks for the tubing. Even if it doesn't work, the photograph would be priceless.
Now the downside.
1) The only fuel cans you can buy nowadays have that !@#$%^ spout that you have to hold in position the whole time you're emptying the can. Oh well, at least you don't have to shake the spout when you're finished :eek:)
2) It seems more likely that you'd dump water and crud from the bottom of the can into the fuel tank.
Where can I get one of those coupons?
/ Pump to transfer diesel, 5 gallons at a time #10
There is usually an advertisement in the Sunday paper - either in one of the "all-ads" inserts or separately.
In the meantime, here is the most recent coupon.
Display
/ Pump to transfer diesel, 5 gallons at a time #11
I know how you feel. Didn't bother me to much until I started clearing my land then I was filling 2 tractors and a dozer at least once or twice a day. Went to the local TSC and picked up a 15gpm barrel pump. Now of takes under a minute to fill up. When barrel is empty I load it up into the truck and go fill it. Then I use the FEL to unload it. To easy.
/ Pump to transfer diesel, 5 gallons at a time #12
I use the same system.. Works great, almost too fast. No auto shut off so you need to really watch the fuel tank level. I added an inline filter from TSC and mounted the whole thing on a poly 30 gal drum attached to a hand cart.
GE WASHER & DRYER (A60432)
GE WASHER & DRYER...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
2014 Acura MDX SUV (A59231)
2014 Acura MDX SUV...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2013 Ford E-350 Cargo Van (A59230)
2013 Ford E-350...
