Dump trailer to haul tractor?
/ Dump trailer to haul tractor? #21
Methinks that Hawk used SLIGHTLY heavier cables so as to eliminate the battery on the trailer as it wasn't charging fast enough through the 7 pin plug.
Aaron Z
Yea if he eliminated the battery you would need something to handle 150-200 amps. But it is so nice just to be able to plug in a standard plug to charge the battery and have lights. I hauled about 100 yards of sand with mine back to back loads about 10 miles and it kept up the charge with only a 20 amp resettable breaker. It never popped the breaker either, I was curious because of it being a new to me trailer and every time I tested the battery it was at 13.6or better. CJ
/ Dump trailer to haul tractor? #22
Yes, the charge coming out of the 7-pin plug just wasn't cutting it. Here is the kit the I used. It is Warn Part Number 32966 and 32963. I ordered it through NAPA, part number BK 3354624, BK7453148. One is a 20' cable. The other is 24' cable. It comes with all the necessary parts. As soon as I get my trailer back from my cousin's place tomorrow, I will post some pics of my installation. I also use it to power the winches on my other trailer.
Warn Industries - Rear Quick Connector Kit
Hawk
/ Dump trailer to haul tractor? #23
I'm no expert here, but I didn't see a mention of the tow vehicle from the OP
I just went through the same decision process - already have an 18' 7K trailer to haul my BX and wanted a dump trailer. My 03 RAM 2500 CTD is rated at 10-11K lbs on the bumper (sad I know) - so figured I should stick with a 10K trailer to stay in the safe range and to avoid any CDL/DOT issues (not that I fully understand all of it). I also wanted to maximize the payload I could haul. With a 6x10 10K trailer I could get a full 4 ton of payload. With the larger trailers, the empty weight cut in quite a bit to what I could haul
Not sure this applies to the OP's situation, but thought I would share my perspective - which, of course, could be completely flawed !
/ Dump trailer to haul tractor? #24
Thanks for the input guys and for the video Hawk. Dump trailer it is! I'll make sure to get some of those D rings for ties down points.
GL,
Here are some pictures of the D-rings I had the dealer install.
You can't see the ones at the top all that well, but there are two at the top, two in the in middle, and two at the rear of the trailer.
Hawk
Hawk,
Thanks for the pics! Thats a nice size dump you have there. I'll definitely have the dealer install some of those rings.
I ordered my JD 3320 yesterday! Dealer said it should be here in about 3 weeks. So I figure I have three weeks to get the trailer. I went to the dealer today and measured a rental 3320 from loader to 3 point hitch and came up with about 13.5 feet. I would like to be able to haul with ballast box so I'll be too short.
What do you guys think? Should I go with the 14 footer and hang the bucket over the front or shell out another 1k (roughly) for a 16 footer? I talked to my JD dealer who said go with the 14 footer. He said a 16 is a huge dump trailer and probably overkill.
My tow vehicle is a Ford F-150, 5.4L, Supercrew. I went through my manual and I believe I can tow about 10000lbs. The 14 and 16 foot dump trailer gvwr is 14000. The 14 footer weighs in at 3780 while the 16 footer weighs in at 4000, according to the Becks Trailer website located in St. Johns, MI. If my math is right (which isn't that often), the tractor (including loader and ballast) will weigh in around 5500 lbs, plus the trailer weight of 4000 lbs, will put me right there at 9500 lbs. Sound right?
/ Dump trailer to haul tractor? #27
GL, oh yea - you're in great shape in that case - basically same boat as me - in my case I fretted over loosing the extra ton of "safe" payload when hauling material. So I weighed the extra trips with two trailers against the ability to move a larger payload. Luckily, my property is only 5 miles from my house, so that was a factor. I need the dump mainly for hauling gravel for the 1/4 mile of driveway and moving dirt around the property (pond project). And, of course, projects around the house where the tractor is located. The shorter length is also a benefit for the tight areas I need to manuver. Also, my driveway is so narrow I went with a deckover. My landscape trailer is wider and I had serious pucker symptoms the first time I brought the utility trailer (with tractor) to the property - tight turns cut through hills - the trailer tires would ride up the embankment on the turns - seeing my tractor at a 30 degree angle in the rear view caused a little consternation!
Anyway - no right or wrong answer - just trying to think out (overthink actually) all of the scenarios.
BTW - congratulations on both of your planned purchases - very nice setup!
/ Dump trailer to haul tractor? #28
10,000# sounds a little high for a 5.4L F-150
I am a part time trailer dealer and have access to tons of towing info. If you give me your year of truck, cab type, bed length, gear ratio, 4x4 or not, and we know the motor is a 5.4L I can look it up for you.
Chris
Chris
Chris,
That would be great. Its a 2010 F-150 4x4 Supercrew, Lariat edition 157" WB style side. 5.4 FFV V8 engine, electronic 6 SPD AUTO, trailer tow package and trailer sway control, 3.55 ratio limited slip axle, 7350# GVWR package. Thanks!
/ Dump trailer to haul tractor? #30
View attachment Ford F150 guide.pdf
According to the 2010 Ford towing guide I have, a Supercrew with a 3.55 axle has a 9500 lb towing capacity. With a 3.73 it goes to 11,100. So you are going to be right at the max, if the numbers are accurate.
/ Dump trailer to haul tractor? #31
Since you're going be using class IIII hitch, I would highly recommend anti swaybar+weight distributing hitch being added. (anti-swaybar on the hitch itself.)
When I use my Silverado pulling about 3 tons of gravel on my six x ten dump trailer, if they load the gravel on the rear a bit heavy. Mine can get pretty sway happy under load, even with the weight distribution hitch with anti sway bar attached. My 1/2 ton struggles with getting back under control at times. ( because of the z71 suspension).
Also make sure you have trailer brake control.
/ Dump trailer to haul tractor? #32
Chris,
According to my book your 9,500# number is correct for that truck. If it was the 145" WB it would be 9,600# but in my opinion, the longer trucks tow better because they track better.
You have a kind of odd truck. You dont see many F-150 Supercrew F-150's with a 6.5' bed. Most have the 5.5' bed so they will fit in a standard 20' deep garage. My BIL has had two just like yours and I have always liked the way they look with those proportions. I have had 6 F-150's since 1997, all with the 5.4 and all were great trucks. I traded my last one in 2008 but miss it many times.
Chris
/ Dump trailer to haul tractor? #33
Thanks for starting this. Would love having a dump trailer that can also be used to haul the tractor.
Chris
This is my 3rd F-150. I lease mine because I live close to work, so gas and miles are not a concern. Nothing like getting a new truck every 3 years. My last 2 trucks had 5.5' beds. I went with the 6.5' bed this time to see the difference. The longer WB does ride nice. I agree with you about the proportions too. The shorter bed trucks look like too much cab. Mine is tougher to park though. Sometimes I have to do a 3 point turn to get into a regular parking space. I find myself parking out at the far end of the lot with the big trucks. Mine looks little then...
What do you guys think of this one?
GENERAL INFORMATION
Insurance Check Insurance Rates
Manufacturer
Model Year 2012
Model 80 wide x 16' Legend Dump Trailer
Price Request Quote
Color Black
Stock Number: OXC1317523
DIMENSIONS
Deck Length 192"
Deck Height 24"
Deck Width 80"
WEIGHTS
Weight 3990#
Gross Vehicle Weight Rating (GVWR) 14,000#
BODY
Gate Type Greaseable Dump Gate
Lift Gear Hydraulic Piston Up/Down With 20' Remote Control
Chassis Construction All Steel Tube Frame
Paint/Finish Extra Durable Powder Coat Finish
Ramp Heavy Duty Ramps
ELECTRICAL
Electrical Sealed Wiring Harness, Solar Panel Charger
OPERATIONAL
Suspension Spring Axle With EZ Lube Hubs
Brakes Brakes On Both Axles
Axles Tandem 7000# Axles
Coupler 2-5/16"
Safety Features Pivoting Safety Bar Under Dump Bed
Jack Heavy Duty Top Crank Jack
/ Dump trailer to haul tractor? #36
That is a nice looking F-150. I have always been partial although I do not own one now, last was a 07 Supercrew FX4 I sold in 08 to get my Nissan Titan. Titan pulls a little better and is a better off road machine but thats it. The F-150 was so much more spacious, better riding, and just overall refined.
As for the dump trailer that looks like a nice one but on major issue I see with any dump used to haul equipment also is the weight. 4,000# off the payload is quite a hit for a 1/2 ton truck. Not a big deal if you have a diesel 1 ton but with only 5,500# of legal payload I could not get my 28HP Jinma with the FEL and a implement on the 3 point on legally. It weighs 5,600# like that and is not that big of a tractor but I do have rear wheel weights and the tires filled. In comparison my 18' car hauler is only 1,400# empty.
Chris
/ Dump trailer to haul tractor? #37
View attachment 274498View attachment 274499
GENERAL INFORMATION
Manufacturer
Model Year 2012
Price Request Quote
Color Black
DIMENSIONS
Deck Length 192"
Deck Height 24"
Deck Width 80"
WEIGHTS
Weight 3990#
BODY
ELECTRICAL
OPERATIONAL
Coupler 2-5/16"
This is the same trailer I have, so far a good unit. I have pulled it with my super crew, same truck as yours and it did good. DO NOT try to pull it with out brakes. Also do not load it to capacity and try to use the f-150, it gave my F250 diesel a work out, so just a FYI. CJ
Thanks guys for all the help in making my decision. I picked this 16 footer up yesterday. Here are some pics...
IMG_0480.jpgIMG_0481.jpgIMG_0482.jpgIMG_0488.jpgIMG_0489.jpgIMG_0490.jpgIMG_0491.jpgIMG_0492.jpgIMG_0493.jpgIMG_0494.jpg
/ Dump trailer to haul tractor? #40
Nice. You'll appreciate the D-rings. :)
How much of a dump angle do you get with a low profile trailer? Mine isn't low profile, but I could use another degrees, especially when hauling moist mulch and manure.
Sent from my iPod touch using TractorByNet
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
40ft Six Section Heavy Duty Metal Storage Shelf (A64047)
40ft Six Section...
2004 International 7400 C&C 017797 (A62613)
2004 International...
Teledyne Princeton Sod Forklift (A64047)
Teledyne Princeton...
2001 Chevrolet 2500 Service Truck (A63116)
2001 Chevrolet...
2013 KENWORTH T800 MID ROOF SLEEPER (A63569)
2013 KENWORTH T800...
