shed slab
/ shed slab #22
is it worth the up grade or is it not needed
Is your question about floor thickness? I think for a small shed like this that a 4 inch floor is fine, just don't make a grading mistake and have some 3 inch spots. But if your base isn't compacted well you may be best served with a 6 inch floor.
/ shed slab #24
Hey: I jacked up a 16 x 20 shed on my place and put a floor UNDER it and set it back down. turned out well other than when my nephew pulled out the screed he drug it and left a big hump in it and a low spot. used some old fence and pen fence for rebar had fiber added to 3 yards but I think they cheated me some as it did not cover all the area I wanted the figuring I did came out with it being about 4 full inches but was probably only 3 in the center.
more pics here shed raise pictures by WPSPIKER - Photobucket
mark
/ shed slab
i started today been out of work since dec now i have a project they call me back (****) wellim now down to weekends .i started digging footing 12x8 when thats done i will level the rest of the pad .so far its going to be 6" .time will tell . also i had some one clear trees (soft maple ) ,now it give me a new project .20x30 or 30x30 area with rail road ties and crusher run to fill th area and maybe a gazelle who knows
/ shed slab #26
Dont forget to snap a few pics along the way.:thumbsup:
/ shed slab #27
what are the major advantages to go 6 " then 4" 4"pad with a 8"x12"perimiter=4.5 yards an 6" pad with a 8"x12" perimeter 6 yard which isn't a big leap in price
Check with your concrete supplier to see if they have a minimum load charge. You might find out that 6 CY is the same cost as 4 Cy and you can thicken the slab or footings.
/ shed slab #28
Always remember that Fiber mesh is a secondary reinforcement. When using fibers put your rerod at 2' on center with a bar in your rat barrier (perimeter) Fiber + Rerob = darn near bullet proof. Don't forget to cut control joints in the slab. Here in Iowa most of the plants have a 3 yard minimum without a small load charge. I'm Not sure what they are out east ,
/ shed slab
update shed has grown ,its now going to be 14x24 .permit is 71 dollars.im digging down 3 feet for footing .footing are 8 height x12 wide .on top of that 8 inch block.im looking at 6 inches above grade .walls 2x4 roof 2x6 with 4 if not 6 inch slab 1/2 rebar every 16 inches with fiber
/ shed slab #30
Good stuff!
but:
Rafters will be 2x6? What is your snow load like in NY?
Wrooster
/ shed slab #32
Might as well build a barn.
/ shed slab
as per the building inspector 2x6 was fine .i think we have 50 lb rating in new york state.i guess murphy it is a barn for toys
/ shed slab
the other garage that was here when i brought the house has 2x4 rough lumber for roof truss and it is at least 14 wide.it been stand up since 1976
/ shed slab
took the weekend off to spend time with the wife in NYC.im going to call to see how many yard i need to order before i have to pay a short fee .i think they have a small truck that hold 5 yard ,so i might increase the footing from 8hx12w =1.89 yards to 10x16=3.11 yards
/ shed slab #36
Like I mentioned earlier in the thread, lay out a small "sidewalk-width" skirt area adjacent to one wall -- and if you have extra ready-mix pour the skirt.
Wrooster
/ shed slab #37
I did something similar on one of my sheds, I laid out an apron, 8' long, but left the low end board unpegged until we poured, so I could move it over to wherever it looked like the screed would run out, then peg it there. As it happened, though, there was extra on the truck from another delivery so I filled all of that space, plus a few 4'x18" forms I'd also made up which I set in front of various walk-through doors later.
I've also grabbed a bunch of eye bolts, or even just pieces of rebar bent into a "U", and five gallon pails. Fill the buckets about half full, then jam in the eye. Once it sets, you get the bucket back and you can use the weights for tarps and such.
/ shed slab #38
Ah, you just reminded me of another good idea. :)
In the slab in the shed, and in the slab adjacent to the shed, sink a hefty eye bolt (or rebar bent into a "U" per above) in a couple of convenient locations. Then, when you want to secure something expensive but portable -- like a generator for example -- you can simply use a hefty aircraft cable lock looped through the eyebolt.
Wrooster
/ shed slab
going up this weekend to finish digging .spoke to cement company 92.50 a yard i need 2 yards so there is a 100 short charge which isnt bad .one bad thing it only reaches 16 feet and in 24 feet deep so i guess i will be using wheel barrels
/ shed slab #40
You get 3 yards for the same price...so use it up!
Wrooster
