shed slab
   / shed slab #22
is it worth the up grade or is it not needed
Is your question about floor thickness? I think for a small shed like this that a 4 inch floor is fine, just don't make a grading mistake and have some 3 inch spots. But if your base isn't compacted well you may be best served with a 6 inch floor.
   / shed slab #24
Hey: I jacked up a 16 x 20 shed on my place and put a floor UNDER it and set it back down. turned out well other than when my nephew pulled out the screed he drug it and left a big hump in it and a low spot. used some old fence and pen fence for rebar had fiber added to 3 yards but I think they cheated me some as it did not cover all the area I wanted the figuring I did came out with it being about 4 full inches but was probably only 3 in the center.
more pics here shed raise pictures by WPSPIKER - Photobucket
mark
   / shed slab
i started today been out of work since dec now i have a project they call me back (****) wellim now down to weekends .i started digging footing 12x8 when thats done i will level the rest of the pad .so far its going to be 6" .time will tell . also i had some one clear trees (soft maple ) ,now it give me a new project .20x30 or 30x30 area with rail road ties and crusher run to fill th area and maybe a gazelle who knows
   / shed slab #26
Dont forget to snap a few pics along the way.:thumbsup:
   / shed slab #27
what are the major advantages to go 6 " then 4" 4"pad with a 8"x12"perimiter=4.5 yards an 6" pad with a 8"x12" perimeter 6 yard which isn't a big leap in price
Check with your concrete supplier to see if they have a minimum load charge. You might find out that 6 CY is the same cost as 4 Cy and you can thicken the slab or footings.
   / shed slab #28
Always remember that Fiber mesh is a secondary reinforcement. When using fibers put your rerod at 2' on center with a bar in your rat barrier (perimeter) Fiber + Rerob = darn near bullet proof. Don't forget to cut control joints in the slab. Here in Iowa most of the plants have a 3 yard minimum without a small load charge. I'm Not sure what they are out east ,
   / shed slab
update shed has grown ,its now going to be 14x24 .permit is 71 dollars.im digging down 3 feet for footing .footing are 8 height x12 wide .on top of that 8 inch block.im looking at 6 inches above grade .walls 2x4 roof 2x6 with 4 if not 6 inch slab 1/2 rebar every 16 inches with fiber
   / shed slab #30
Good stuff!
but:
Rafters will be 2x6? What is your snow load like in NY?
Wrooster
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
Kawasaki Mule 3010 UTV (A49461)
Kawasaki Mule 3010...
2013 MACK PINNACLE (A50854)
2013 MACK PINNACLE...
2007 TRANSCRAFT 40X96 FLATBED (A50854)
2007 TRANSCRAFT...
71066 (A49346)
71066 (A49346)
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
