Seat cover coming off
/ Seat cover coming off #1
RaydaKub
Rochester, MN
Kubota BX2230
My BX seat cover has just let go on one side. Has anyone tried to fix these? What holds the cover in place? There is that strip around the edge, but does that just pinch the vinyl in place? I was looking at some of the threads for replacement seats and they look mighty nice, but I don't know if they would fit a BX. There so much advice in this community, I'm hoping somebody has a cheap & dirty way to get this back in shape. Thanks fellas.
/ Seat cover coming off #2
If the foam and metal are still in good shape, take it to a vinyl repair shop. That will be less than a new seat.
/ Seat cover coming off #3
I used Gorilla Glue on my Deere 4400 seat when it separated from the seat pan (metal). If that's what happened to your seat, give it a try. Since there's no good way to clamp the seat covering to the pan, I used a 50 lb bag of sand to hold it in place for a day or so while it cured.
Once you repair the seat, I suggest you look for a seat cover. There's nice ones for Deere seats on eBay. I'm sure you can find something similar for your Kubota.
/ Seat cover coming off #4
About four years ago Kubota had a replacement seat offering for the awful B/BX forward sloping seats.The normal deal at the time $27 and your old seat for the new version.Last year,our local dealer and Messicks still had the replacement seats for $99.Could be an option for you.I'ts a good seat!I also recall seeing a decent looking Kubota replacement seat at the new TSC here at about $110.Good Luck!
/ Seat cover coming off #6
Is your BX still under warranty? I have a 2011- L3200 and the seat cover just decided to seperate from the foam and kinda looked like it just bubbled out from the frame. Called my dealer and told him what it was doing and they replaced the seat for free because I was still within my 2 year factory warranty. Your tractor picture looks like a newer model, so I just wanted to throw my 2 cents in. :)
Is your BX still under warranty? :)
Don't I wish! :laughing: I bought it off eBay with 591 hours on it last fall. They were guessing by the serial number it's a 2004 model. I've put over 50 hours on it since then and it just started the last 2 times I had it out, but already the right side is almost wide open. Gotta see If Menard's or HD has the Gorilla super glue Roy suggested.
/ Seat cover coming off #8
In the same situation with my B7610 seat. When I purchased mine last month, also an 04, the front edge of the seat and across the top in the middle were loose. Finally, when I found out a new seat from Kubota is $238, I used black "Gaffer" tape. This stuff is stickyer and stronger than duct tape and does NOT leave a residue when you remove it.............Anyway, 20 hours later and it is still holding...........
Anyone found a replacement seat for the BX or B series?????????.....................God bless.........Dennis
/ Seat cover coming off #9
Any idea of the model number for the Kubota seat or the TSC??????????..............THANKS.........God bless...................Dennis
/ Seat cover coming off #10
Dennis,I looked at my invoice from last year and the Kubota part number was B1013.Seems odd as Kubota part numbers are usually 10 digit.Call a few dealers and ask about the replacement seat.The TSC seat number is 1012108,sells for $119.95 locally.Fits six different bolt patterns.Hope you find something affordable!
Well I've put up with it long enough. I pulled the edge off the pan from the bottom of the side all the way up to the middle top. I used pliers stretch and pull the material far enough to wrap around the pan and used 3 vice grips to hold it in place. I the loosened one vice grips at a time and put Roy's Gorilla Glue on the pan and clamped it back down. I repeated this 4 more times because I had to keep the vice grips no more than about an inch apart. After I got the material glued, I put a stream of glue all along the edge and put edge back on. I used the vice grips and several clamps to pinch this down until the glue set. It might not be perfect, but it will probably last a couple years. At least I hope it will. Thanks Roy!
/ Seat cover coming off #12
Raydakub sometimes you just got to do what ever it takes before it drives you nuts. By the sound of it, it should outlast the machine.
Thanks, but I'm hoping for a year tops and then I can show she-who-must-be-obeyed that it let go again and now I have no other option but to get a replacement seat. Probably with arm rests. :)
/ Seat cover coming off #14
In the interim, get one of the Deere seat covers. Try eBay first as you'll find the prices considerably lower then at a dealer. NONE of those seat covers fit as tightly as they look in the pictures, but they fit decently and they will protect the OEM seat from the elements.
That's just it though, Roy. If I have repaired it once and it goes again, then it must truly be time to replace it. Any seat cover will just make it last longer. This is the forward slope Kubota seat. I would like to replace it anyway, but I gotta have proof that it needs it, and 1 repair is all the proof I think I'll need. I just hope I didn't use TOO MUCH glue! :wink:
/ Seat cover coming off #16
When you finally break though that vacuous void, known as your wife's way of thinking, try out the Tractor Supply seat that is available for the BX and B's............Around $100 but MUCH cheaper than Messick's Kubota replacement......YES, it eliminates the forward sloping/non -existant back support of the original........God bless.........Dennis
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A61165)
2016 Volvo VNL...
EXECUTIVE SERIES AIR DAM (A62131)
EXECUTIVE SERIES...
2018 F550 Bucket Truck (A63118)
2018 F550 Bucket...
2022 Big Tex Trailer Trailer, VIN # 16V3F4822N6178218 (A61165)
2022 Big Tex...
(INOP) NISSAN MU1F2A25LV WAREHOUSE FORKLIFT (A62130)
(INOP) NISSAN...
