Need advice on pole barn cost--
/ Need advice on pole barn cost-- #1
Western NY
MF 596 FEL
Hi,
I'm building a pole barn to work on and store my tractor, cornplanter etc. -- Sick of working on this stuff on my gravel driveway!
Anyways, I have a quote from a reputable guy in my area:
Main part of barn: 40*40*14
Lean to sides: 15*40 on each side (one side enclosed with concrete, the other outside with gravel)
Upstairs over main part of barn will be 16 ft wide by 40 long reachable by staircase with flooring for storage etc.
One man door.
One overhead door 12*18 on one end and a 12*14 overhead door on the other end--both insulated.
Some anti-condensation pannels on the interior roof, but otherwise no insulation.
Cost includes concrete: 40*55=2200sf inside and 800sf pad across front of barn, so total concrete: 3000sf 5 inches thick.
Does not include excavation, gravel, electric or any plumbing.
Metal is galvalume 29 gage.
posts are laminated.
Quote from Contractor: $42,000 This is $15/sf for the area that has a roof over it (that is, the main barn plus both the inside leantoo and the outside leantoo are includded in the "square footage"/cost figure.
What do you guys think of this quote.
Thanks in advance!
Bob:)
/ Need advice on pole barn cost-- #2
I can't help you on the quote much, but seriously consider insulation throughout. When I build the Quonset I only insulated the living quarters not the shop side.....big mistake.
/ Need advice on pole barn cost-- #3
Actually that don't sound too bad for having it built but there probably is a little wiggle room and I would try to get them to throw in the sub grading for the pad and then it would be right on target. That way if they do the site work they will be more careful and get the grade work done correctly and the proper compaction of the sub base materials to a proper level because they will be responsible for the finish product. Sometimes contractors like to separate the finish product from the sub base preparations so if the concrete cracks of a portion of the building settles they have an out. They can say they didn't do the sub base so it's not their fault that the concrete has a million cracks in it or there is a 4" fall from one side to the other a few months after the floor is poured.
I'm doing one now that is about the same size as what you are planing. I have done pretty much everything myself and I have the roof and siding done, my plumbing is roughed in, the floor is ready for concrete with 1" foam board, vapor barrier, rebar, and pex tube installed for my floor heat and I am about 3/4's way done with my electrical work. Right now I am working on putting in wall studs around the exterior walls to hold my insulation and to have a place to nail my inside wall panels to. I plan on putting up medal siding for the inside walls up to 8' and from there to the 14' ceiling height will be osb all painted white. To date I have all the framing materials needed about 90% of the electrical and plumbing supplies bought and paid for plus about 80% of the parts needed for my heat system already bought and installed. Concrete will be my next biggest expense at around $5000.00 and insulation next will cost me around $3500. Hopefully I will be able to get some more cheap siding panels from my pole barn building buddy to do the inside walls and if I do it will really help.
So far I have right at $27,000.00 in the project and about $5000.00 of that was to rebuild part of two walls that got wiped out when a tree fell through the front and side wall during last years hurricane. I had hoped I could build it for around $32,000.00 finished but that was before I decided to add floor heat and an addition or two. It started out to be 32X40 but now with the two side and back additions it is 55X40 with a 20X20' off the back end all under roof.
/ Need advice on pole barn cost-- #4
mx842.... got any pics? Sounds perfect for what I need to do, too (eventually).
/ Need advice on pole barn cost-- #5
Yeah about a million of them...I thought I had some of them posted in my photo album here but I guess not. If I can find the time I'll put some up.
****, I see we don't have a photo album here oh well I guess it's about time to update my pole barn smashed to pieces thread, it's been awhile since I did so.
/ Need advice on pole barn cost-- #6
I think the price is high. But geography matters. My buddy had a 30x40 built. One double garage door. One entry door. Insulated ceiling. On slab. Fully wired with 100 Amp service; lights and outlets everywhere. His cost for everything (including excavation and stone) about $20K. This was about 4 years ago in WV.
I got a quote about 6 months ago for a 20x30, on stone floor: $8500 similar door/insulation arrangement.
/ Need advice on pole barn cost-- #7
Where in the world are you located? There are either some really hungry builders where you are or somebody is fudging on the numbers somewhere. You can find kits around for buildings the size you mentioned (20x30) in the $8500.00 range but that doesn't include anything but the shell delivered to your door in a pile and you have to put it up yourself or have someone do it for you but good luck on getting someone to do it for you for nutin'.
/ Need advice on pole barn cost-- #8
Concrete pads run $9.71 a sq ft around here for 4"...forming and materials only. Then you've got to build the structure!!
For my region, your quote looks great.
/ Need advice on pole barn cost-- #9
I was quoted $6200 for a kit, 20x30 back in the spring from armour metals (no stone). As for my buddy's $20K, WV can be cheap especially 3 or 4 years ago when every contruction crew was hurting for work (and many still are). And my pal does drive a hard bargain.
I ended up going with a closed side heavy duty carport, 20 x 25 x 9 open ends for $2500 fully constructed. I excavated and bought my own gravel. I'm really pleased with the carport too. Not a full enclosure, but meets my needs for much less money. I think I could have gotten it with closed ends with a garage door for about $4000 fully constructed.
/ Need advice on pole barn cost-- #10
Just wanted to point out that I couldn't get near my buddy's price either, especially with concrete. I know he got a deal and I'm envious everytime I go to visit. And I'm sure NY is much different than WV. BTW, I'm in Maryland and a pretty good bargain shopper myself. Shopped long and hard to get the $8500 price. This is what I ended up with for $2500.
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
2014 POLAR TANK CRUDE TRAILER (A60736)
2014 POLAR TANK...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
36"x10' Stacks of Sheet Metal (A60463)
36"x10' Stacks of...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
