Rotary Cutter Please help with mower noise
/ Please help with mower noise #1
Djrose
Cedar rapidsiowa
Kubota l3400
Hello,
I have a problem with my landpride rotary mower and am stuck. It started to make a "clunk" sound while mowing at an angle. Kinda sounded like the blade was hitting something. I stopped mowing checked blades they are both fine. Checked to see of there was anything under the blades or the metal pan, nothing. I made sure mower was level side to side and front to back. Everything is tight. Blades tight but will move when I manually turn them. Greased everything. It worked ok for one mowing. Next time I started it it started to clunk again. I turned it off and then tried to engage pto again and it made a grinding sound. I removed mower completely. Engaged pto again with nothing attached and no sound. I checked oil level in motor it is ok. Shear bolt is intact. The universal joint looks ok. No breaks or nicks anywhere. I do not know what else to check. Does anyone have any ideas? I am completely lost and have just basic knowledge. We live far out and taking it in would be very expensive.
Thank you for your help.
/ Please help with mower noise #2
Candidly,
it sounds as if you have a broken tooth in the gearbox, drain all the oil out and see if you have any large pieces of metal
in the oil or if the drain plug has a magnet it should have a piece of the gear tooth that is attached to it.
Hello,
Thank you very much. I will give that a try.if it is a broken tooth then will I need a new gearbox?
Hello,
Cutter is five years old. It is a landpride rotary cutter used mainly for rough cutting.
/ Please help with mower noise #6
You might also should check the driveshaft where it slides in and out. I had one that had a lot of play and it made a noise. I was doing as you are and checking everything and found that was the problem. Mine is not a Land Pride mower.
/ Please help with mower noise #8
What angle are you talking about? For example, are the tractor and mower being "folded" at the bottom of a hill? (Tractor on level ground at bottom of hill and mower still on the hill) I have heard what I assume is noise from PTO joints complaining about the angle when egtting to that position at the base of a hill with my RFM's .
I also had a PTO shaft rub a rotary cutter when the angle went the other way after the back of the cutter dropped low.
/ Please help with mower noise #9
Exactly, I think that is what caused my driveshaft to develope play inside the slide.
Djrose, as there are a number of ways to get a "Cluncking noise" hope you narrow it down soon, cause if its anything like around here if I miss any cutting the woods will take over.:)
Hello,
Thanks for all of the replies.
The mower makes the sound when I try to engage it in level ground now. At first it was just on hill. I do mow where the cutter is at an odd angle rot tractor when going up and down hills. Is that bad? Is there a better way to cut the grass on hills? I HATE weed whacking.
Yes, things do grow fast here but right now it is so hot and dry that the only thing growing are the weeds. Not exactly what I want to grow.
Thanks again for all the suggestions. I am going to try them today. I have discovered that sitting on the mower and crying does absolutely no good.:)
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
John Deere 4040 Tractor (A64047)
John Deere 4040...
KBH Tender Trailer (A63689)
KBH Tender Trailer...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A65563)
2016 Volvo VNL...
Wood Fence Post (A62613)
Wood Fence Post...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
