Trouble getting Walmart to replace my (N)Everstart battery
/ Trouble getting Walmart to replace my (N)Everstart battery #61
Aaron Z
so if you were at a Walmart Auto (SERVICE) center... amazing they don't, won't,
or can't service a battery on a van.
As for NOT honoring a prorate agreement, over 48 months on a 108 month prorated battery, if it were to happen with receipt-
I'm sure many states Attorney Generals might like to hear more about that.
Maybe without receipt could catch their attention also if the prorate agreement does not require a receipt but defers to the build date of the battery for the remainder of prorate period.
/ Trouble getting Walmart to replace my (N)Everstart battery #62
Aaron Z
I was at 2 of them. One was willing to replace the engine compartment battery but didn't have a lift that would let them lift the van to get at the frame rail battery and didnt want to try it without one. The other one (where I think we had the batteries replaced back in 2008) flat out refused to work on a full size van.
Dad has the receipt but I didn't have it with me, so we will see what happens with the receipt.
Aaron Z
/ Trouble getting Walmart to replace my (N)Everstart battery #63
they use a digital load tester. measures un loaded voltage, loaded voltage, and timed voltage drop at load. it's not a huge unit.. I assume it's a duty cycle controlled load.. and it's a short duration test. after the test it spits out a computer print out. that determines if it passes / fails, and if it is warnty or not.
A carbon pile load tester is the only tester that can determine if a battery is defective. Does Wal-Mart have these in there Service Department or something else? All batteries I have had checked with one either failed or passed the first test, no multipile tests required. Did have a vehicle with a electrical problem that would drain a battery after setting overnight or during the day in a parking lot. Cost an arm and leg to finally locate and repair at dealership.
Carbon Pile Load Tester:Arco Battery Load Tester
2025 Pabreak 84in. Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak 84in...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2001 CHEVROLET C8500 FLATBED TRUCK (A62130)
2001 CHEVROLET...
Pallet of Chain Slings (A61166)
Pallet of Chain...
