Buying Advice Deciding between L3800 and JD3320
/ Deciding between L3800 and JD3320 #1
chicklin
Columbia, MO
None....yet
I live on 10 acres and plan to use the tractor for landscaping, road maintenance, snow clearing, digging, spreading, brush-hogging, possibly finish-mowing (more on that later), food plots and just general odd-jobs around the place. I've also got a hunting farm (154 acres) a couple hours away where I may use it occassionaly, as well. I've come across two options at the local dealer that are intriguing:
New
Kubota L3800 HST
LA524FL Loader
Ag tires (because it doesn't come with a finish mower, but R4 is an option), tires filled
$19,200, 0%, 60 months financing available
Used
2005 (I think) JD3320 HST
500 hours
R4 tires
300CX Loader
72" under-belly finish mower
$18,600, financing through local bank at 4.99%
So, here's the dilemma. The JD will cost more per month and overall due to the financing (about $20 difference), but from what I've read is a different class of tractor and includes the under-belly mower. Having the mower helps make up the difference, but I'm not entirely sure I'll use it. I've got maybe 2 acres of lawn, but some of it is fenced and there's a few trees here and there, so I'm concerned about the nimbleness of the 3320. It is flat, though, which is a plus.
The Kubota, however, is brand new and includes Mfgr warranty and I won't pay a dime in interest. But, no mower and for basically the same price is less tractor. Plus, I'll get to take the hit on the re-sale since it's new whereas the JD has already taken the initial bump. The JD package new is $28k.
Thoughts? I'm leaning towards the JD at this point, but I'm sure the Kubota can do everything I want it to do. Either one is most likely overkill, but that's kind of how I do things, anyway.
For reference, I've currently got a Ford Jubilee that I've been using for brush-hogging and that's about it. So, anything in this class is going to be worlds better.
Also, is the HP difference between the Kubota (38) and the JD (33) going to be noticeable? Are HP ratings apples to apples or does it vary across mfgrs?
/ Deciding between L3800 and JD3320 #3
Another option would be an L3200. I recently replaced my B7500 with an L3200 HST / FEL / filled R4's and the 32 (31.9?) HP are plenty for me - 11 more than I had with the B7500. The deal included a 6' Landpride RFM and the package was less than the L3800 you wre quoted on. So far it's been used to mow, move dirt and pull a borrowed 6'(?) disc.It now has a little over 25 hours on it and most were moving dirt to bury a 1,000 gallon LP gas tank. Had the tank people set a below ground tank on a bed of sand on the ground at the base of a bank, then went to relocating material from another part of the property to extend the bank and bury it. It has the right combination of HP, size and nimbleness to keep a smile on my face. After spending over 1,000 hours on the B, the larger platform of the L and suspension seat are so much more comfy for my big old body.
Yep, they've got an L3200 with loader for $17,600. Again, about $20 per month difference.
/ Deciding between L3800 and JD3320 #5
My father used to say "Son, when you buy something used you're buying someone else's problem". Buy the Kubota.
/ Deciding between L3800 and JD3320 #6
I just bought a L3200 HST with a loader, Landpride brush cutter and a box blade for $18k. I think you can do better on your price.
/ Deciding between L3800 and JD3320 #7
The Deere seems a bit pricy.... 16k would my top dollar. I would spec 40hp, cab, loader, and buy attachments as needed. Color would be green due to the dependability / resale value / parts availability and operating features. I would include a New Holland Boomer in this as well but they are in production revision. I know little about the latest model manufacture changes. One should consider resale value because it may come a time you will want to recover most of your investment, sometimes timely. Areas of course differ but where I live deere is at the top of the hill. Just my opinion, good luck with your search.
You're probably right. The prices I listed were list/asking price. I haven't done any haggling, yet.
/ Deciding between L3800 and JD3320 #9
I bought a L3800DT last winter. Great tractor, very pleased. It has exceeded my expectations.
Kubota has been dead nuts reliable for me since 1984. :thumbsup:
Any concerns about not having an underbelly finish mower option?
Anyone have any comments on rear-finish mower vs. underbelly? For RFM, pull behind or 3-pt mount? Neither is a requirement, but if I can get rid of my riding mower in the process, so much the better.
I'll search the forums, but any pointers would be helpful.
/ Deciding between L3800 and JD3320 #11
Had a 5' belly mower when we first moved in back in 1989/90. Went with a 5' 3-point around 1992 with the first little 4WD diesel. Bought a new 5' 3-point with the B7500 in 2002, and now a 6' 3-point with the L3200. I prefer RFM's or I wouldn't keep getting them. To say I never whacked anything with it would be a lie, but I recall bumping a few things with the belly mower as well. I like being able to swing it under trees/shrubs and being able to back up to the creek bank on occasion. There's also some adjustment on where it tracks, so you can keep the tractor a few more inches away from rolling into the creek.
/ Deciding between L3800 and JD3320 #12
No concerns at all! Personally, I feel the L3800 is too big to be a lawn mower with mid mount mower. I use a 5' and 6' rotary mower on mine, as I have all tractors before this one.
Well, I went and drove both machines today and they are both great, but the JD feels like a completely different tractor. It just feels heavier, smoother and more stable and has a few more bells and whistles. It includes the MMM and I got him to throw in a new box blade. Still deciding on whether or not to pull the trigger, but it just feels like a better deal, even being used.
/ Deciding between L3800 and JD3320 #14
Can I ask where you purchased it. I'm interested in the same setup.
/ Deciding between L3800 and JD3320 #15
I debated the same. Rfm vs mmm vs dedicated rider. Went with dedicated rider for general lawn mowing and a L3400 with brush hog for the pastures. No regrets in fact its worked out much better. The 3400 would have beat my lawn to death..
I've got a small 42" riding mower now and I've gotten by with it just fine, but it also stopped raining about 2 months ago, so this summer is not a good gauge. I think if I do the deal, I'll mow up around the house with the small mower and then do the large, open spaces with the JD. I wanted to be able to get rid of the rider, but I just don't think it's going to be practical.
/ Deciding between L3800 and JD3320 #18
I agree 100% with your decision of keeping the rider and mowing the field with the tractor. Best of both worlds.
I used to mow 7 acres with a rear finish mower on 2 different tractors.. the place looked like a park after a while, but I always kept a 42 incher for around the house.. just much easier to get around things. As noted the RFM is easy to get under overhanging trees, by backing up under them.
James K0UA
James K0UA
So, I think you're saying I need a rider (preferably ZT), a tractor with both MMM and RFM, a brush hog, box blade, straight blade, auger, back hoe, loader, pallet forks, plow, disc, harrow and wood splitter, right? I'll pass that along to the boss and let her know it's required.
/ Deciding between L3800 and JD3320 #20
You forgot the grapple and wood chipper:):thumbsup:
James K0UA
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
Year: 2015 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 Door C... (A61568)
Year: 2015 Make...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2014 Mercedes-Benz C250 Sedan (A61569)
2014 Mercedes-Benz...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
