StanR
Gold Member
The time has come to bury some water and electric lines. I got the electric and the actual lines covered.
My googled and found almost zero on the well manifold.
All the water lines will be poly... starting with 1.25 then to 1 then to 3/4 inch
I have 100 ft 1.25 300 ft of 1 and 200 feet of 3/4
I have going to have 3 zones, 2 hose bibs at the well, and want room for expansion.
I cut the pieces for a dry run and need suggestions for improvement.
The pvc will start at the shut off value..
This is my first mock up... but not sure I need the unions. I do want to be able to shut off each zone if needed
I left the spaced between connections incase something is needed later.
I have not decided how to do the tso hose bibs.. but on the way to lowes.
Also any preference on screw clamps or oetiker clamps. I have heard the oetiker clamps are prefered.
Thanks for you help. The trenching will start Thursday about 7 am... going down 24 inches.
