Care to Guess what this was? :D
   / Care to Guess what this was? :D #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I'll bet many of you know what this used to be.
What should I do with it now?
:D
David
   / Care to Guess what this was? :D #2
OK, David, I give up. What is (was) it?
   / Care to Guess what this was? :D #3
:D
David
Well I can tell you what I did with mine:
I carefully straightned it back straight as an arrow.. I then took a 2 lb hammer to the bracket which was bent down, and got it back square. I then screwed the pipe lower guide back in and used some blue locktight on the threads, and after all was tight, I took an automatic center punch and put 3 dimples in the joint between the upper and lower guides.. That sucker is not going to unscrew again!
James K0UA
   / Care to Guess what this was? :D #5
David....Looks like a fuel line ? hard to tell...if so , did it get hooked on something and pull off ?
You guys don't own a Kioti.:) this seems to be a common problem here lately with the DK series of Kioti machines.. I would tell you what it is, but I think David wants to have some more fun with the guessing game. But if you had a Kioti DK.. you would recognize it.. It is not critical to its operation but it can come in handy.
James K0UA
   / Care to Guess what this was? :D #6
Gotta keep those brackets tight on those machines.
   / Care to Guess what this was? :D #7
At this point you have enough seat time to not even need that thing!
   / Care to Guess what this was? :D #8
Looks like the bucket level indicator. The one on my tractor is always coming loose and I have to re-adjust it. Guess it is time for some Loctite.
   / Care to Guess what this was? :D #9
I'm guessing bucket position indicator?
   / Care to Guess what this was? :D #10
My DK is a older, so its a little differant.
I just bought a peice of 5/16" rod for a few bucks and made a new one.
2012 Chevrolet Malibu Sedan (A50324)
2012 Chevrolet...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
