Care to Guess what this was? :D
   / Care to Guess what this was? :D #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
I'll bet many of you know what this used to be.
What should I do with it now?
:D
David
   / Care to Guess what this was? :D #2
OK, David, I give up. What is (was) it?
   / Care to Guess what this was? :D #3
:D
David
Well I can tell you what I did with mine:
I carefully straightned it back straight as an arrow.. I then took a 2 lb hammer to the bracket which was bent down, and got it back square. I then screwed the pipe lower guide back in and used some blue locktight on the threads, and after all was tight, I took an automatic center punch and put 3 dimples in the joint between the upper and lower guides.. That sucker is not going to unscrew again!
James K0UA
   / Care to Guess what this was? :D #5
David....Looks like a fuel line ? hard to tell...if so , did it get hooked on something and pull off ?
You guys don't own a Kioti.:) this seems to be a common problem here lately with the DK series of Kioti machines.. I would tell you what it is, but I think David wants to have some more fun with the guessing game. But if you had a Kioti DK.. you would recognize it.. It is not critical to its operation but it can come in handy.
James K0UA
   / Care to Guess what this was? :D #6
Gotta keep those brackets tight on those machines.
   / Care to Guess what this was? :D #7
At this point you have enough seat time to not even need that thing!
   / Care to Guess what this was? :D #8
Looks like the bucket level indicator. The one on my tractor is always coming loose and I have to re-adjust it. Guess it is time for some Loctite.
   / Care to Guess what this was? :D #9
I'm guessing bucket position indicator?
   / Care to Guess what this was? :D #10
My DK is a older, so its a little differant.
I just bought a peice of 5/16" rod for a few bucks and made a new one.
71059 (A49346)
71059 (A49346)
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A50397)
2024 BCL...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
