toolbox and worklight for bx2360
/ toolbox and worklight for bx2360 #1
94BULLITT
Super Member
USA
yes
This is my second time trying to post. I was ready to hit the button to post and lost my electricity again so now I am on my phone. I have a bx2360 and I want to put a toolbox on it. Has anyone added one to theirs? Where does the dealer installed light go and is the wiring on the tractor?
/ toolbox and worklight for bx2360 #2
It is not a BX2360 but maybe you can use a variation of the idea. I sandwiched the ROPS between two pieces of angle to make a shelf for my saw box. Most lights I have seen are mounted on a bracket attached to the ROPS cross bar. I like the ones that use 2" square U-bolts. Look under the rear fenders for wiring. Might be there. Thats where mine is.
If you search toolbox or lights you will get lots of clever ideas and info.
/ toolbox and worklight for bx2360 #3
This is what I did on my BX25. The basket cost me a $1 from the Dollar Store. I simply drilled some holes in the bottom for drainage, added a piece of composite deck to level it; then zip-tied it to the pin on the loader.
/ toolbox and worklight for bx2360 #4
As far as the factory rear light,I purchased one a few years ago when I had my BX25.I was very disappointed with it and eventually threw it in the garbage as I bought it from the dealer with the understanding that I could not return it.The light output was very poor,I tried changing the ground but it made no difference.As for the kit,it wasn't much and seemed low quality,not what I expected from Kubota.As for the plug in,it is taped up inside the wiring harness at the left rear of the tractor.If you search on here you should find a photo of it.If I was to put a light on my BX2360,I would go with LED.They have a low power draw but put out a lot of light.I put three on my 3240 and am very pleased with them.
Unfortunately The toplink and lift arms come up into that area. I saw an older bx that had a box there but there is not enough room to do that on this one.
That gave me an idea. i may be able to mount a small box where the loader mount bolts onto the tractor.
I did not want to spend 60 or 70 bucks on a light from kubota. The light on the bobcat I had was $17. I'll try looking for the wiring. I may go with led but they are harder to find at a reasonable price with a switch built in. I had 2 led's clamped on the rollbar of my bobcat I may put the on the bx for some extra forward lighting. I check the leds on a trailer clearance light and you can run 10 of the power of what 1 incandescent takes.
