At Home In The Woods
/ At Home In The Woods #4,161
Our squash plants are producing squash now. They apparently got pollinated.
Both lawnmowers are not working now. When I tried to start our Kubota riding mower, it clicked twice but did nothing more. After charging the battery, the behavior was still the same. The Kubota store said a starter would cost $420. The mower is probably 15 years old. The problem could be a solenoid or something else.
I guess I need to shop for a mower. I have heard that some of the new mowers will not mow in reverse gear because of safety features. I don't think I could live with that feature.
Obed, in the beginning, squash plants produce mostly male blooms. After the plant matures, it starts producing both male blooms and female blooms with the tiny squash behind them. That's the way squash do for every type I've ever planted.
On the mower, what type/model is it? Kubotas are notorious for having bad key starter switches (ignition switches). To make sure the starter is good, all you need is a short loop of wire to go between the big battery cable connection and the solenoid terminal. Touch both terminals while holding the wire in place. It will spark slightly and then turn over just fine if the starter is okay and the key switch is the problem. I did a whole thread in the Kubota lawn/garden forum about that problem and my fix of adding a start switch to my mower, a G1800.
/ At Home In The Woods #4,162
Keep in mind thats probly a Kubota starter. Look on ebay i bet you can buy one for less than $150 in an aftermarket.
Also it sounds like a solonoid to me?? So unless its all in one you may be able to swap solonoids. you really need to find one of us that is colse to you and can run buy diagnose and show you how to perform simple repairs. you will save thousands in a few years. In return for some cold drinks (dont really like beer but a good coke or Mt dew work) or dinner cooked, or send the wife over to do some of my chores i hate, basically the stuff i see her doing!!! Oh if she cleans we always need the house cleaned. I would fix and buy the parts for you stuff in return for X (based upon parts price and labor time)number of house cleanings!!
/ At Home In The Woods #4,163
Or the way i do it to eliminate the key and solonoid is to hook battery cables to a known good battery, like in a car. Then hook the positive to the + bolt on the starter itself, then hook the negative to the neg battery post or a good frame ground on mower. Watch out cause as soon as you do this it will try and start.
The riding mower problem turned out to be a bad cable connection at the battery. After my in-house small-engine repair girl figured that out and fixed it we mowed the lawn and property entrance. After I finished mowing the property entrance, I turned on the mower headlights and the mower immediately died and wouldn't restart. The next day my repair repair girl figured out the propblem was a bad fuse and got the mower running again.
The back porch is starting to look like a porch. The decking under the porch roof is almost all installed except for the outer board that goes around the posts on one side of the deck. The boards on the deck are just lying there. They are not installed. Other responsibilities and the 90+ degree temps we've been having have slowed the porch progress the past two or three weeks. It's tough to make myself work on the porch after work on these incredibly hot days. This weekend the forecast is for 100F temps.
Well Challenges/Question
Watering the garden has been a challenge. Our well has kept up with our normal household needs without any problems, even during this extremely dry period we are having. However, we have found that with 3 water sprinklers running simultaneously, we can only water the garden for about 20 minutes. If we leave the garden water running much longer, water will start trickling from the springlers instead of spraying. Inside the house, the water faucets will either not work or just pour out a minimal flow rate. When we turn off the water to the garden, the water faucets in the house will quickly and often immediately start working like normal.
We are now watering the garden using 3 sprinklers twice a day for 15 or 20 minutes each time. We use a kitchen timer to remind us to turn off the garden water.
This situation caught me by surprise because the well digger told us when he dug the well that we had a very good flow rate. I do not remember the flow rate number he told us. I had thought we could water the garden as much as we wanted but that doesn't appear to be the case.
I am curious what experiences you guys have had regarding using a well to water your garden, grass, animals, etc.
Thanks in advance,
Obed
/ At Home In The Woods #4,167
Obed,
What kind of well pump do you have?Size and volume....
What is the pressure tank size?
What about the working pressure on the pump tank?
Where in relation to the pressure tank are the taps to the waterhoses?
I had a similar problem trying to t off 3 hoses from a single faucet..stupid me!
How deep is your well?
How far away from the house?
What size water line from the well to the house?
Does the line drop in size going to the faucets outside as compared to the in house fixtures?
I know all of this is likely on the thread somewhere but I'm using my iPhone to answer....
I'm sure others will have more questions.
This will be a good start....
RT
/ At Home In The Woods #4,168
Thanks in advance,
Obed
Your pulling water faster then it can replenish by using that many sprinklers. You could switch to where you turn on each sprinkler one or two at a time and see if that works better. My well is 5' deep and during the dry summer I start pulling air if I run out 400 gallons. Shut down and it fills back up.
/ At Home In The Woods #4,169
Thanks in advance,
Obed
Obed
I have run into the same problem when running one sprinkler too long. I got around the problem with a hose faucet water timer from Lowes or Home Depot that is operated by a 9 volt battery. You can set it to come on at a certain time during the day and for a specified length of time. I can also push the manual use button and get it to go on for 30 minutes before it shuts off. The cost was reasonable, too long ago for me to remember exact cost. It eliminated the low water problem for me.
Rick
/ At Home In The Woods #4,170
Thanks in advance,
Obed
Obed,
Living in an area that during extended periods of drought sees people doing laundry at laundromats rather than using their own wells, when we built 10 years ago we went with the "you should never have to consider the fact you're on a well", mostly because we have horses. Could have drilled a second well for the stables but decided against it. Depth, 385 feet, cased down 200 feet, high volume pump, 18 gals/min flow and 400 gals of water in the well. We run sprinklers all day in times such as the area is experiencing now, minimal rain. Talking with my wife there are people whose wells are 120-150 foot deep complaining of similar situations to what you're experiencing, thankfully it doesn't seem to happen every year, seems the cycle in this neck of the woods is every 3-5 years we've experienced winters with minimal snowfall and dryer than normal Springs.
Best of luck to you. Beautiful property you and your wife have there!
Obed,
RT
What kind of well pump do you have?Size and volume.... Grundfos SP4" 10S15-21 4" 1.5 HP, 220 V, 4 cu. meter/hr (17.6 gpm) up to 450' deep.
What is the pressure tank size? 44 gal
What about the working pressure on the pump tank? Pump turns on at 40 PSI and turns off at 60 PSI
Where in relation to the pressure tank are the taps to the waterhoses? Well - 100' of 1" pipe - pressure tank in the basement - 200' of 1" pipe - garden spigot - 100' of water hose with 3 sprinklers hooked in series
How deep is your well? A little over 300'. Pump is set at 280' deep.
How far away from the house? 100'
What size water line from the well to the house? 1"
Does the line drop in size going to the faucets outside as compared to the in house fixtures? House has 3/4" copper piping running the length of the house with 1/2" piping running off the main line to the inside house fixtures.
Thanks,
Obed
/ At Home In The Woods #4,173
Obed,
How many hose bibbs do you have outside?
Somehow I missed the fact that all three sprinklers in series.
I did what you did and someone explained what he called the parasitic effect divided hydraulic pressure reduction.
When I said English please...
He said you can't get the same pressure out three 1/2 pipes when you only feed it with a shared 1/2 inch feed in series...
I split mine from 3 faucets and wow! It worked!!
/ At Home In The Woods #4,174
We don't sprinkle our current lawn in washington but in Wyoming we did. You don't specify what kind of sprinkler you have but 3 average sprinklers is going to drain the system. Also, IMO, you are way overwatering. In southern California we water twice a week for a half hour and that covers us well. Also, watering a lawn, IMO, outside of the 430 am to 630 am window is wasting water....
/ At Home In The Woods #4,175
Everybody is saying the same thing I would - you need a timer. one for sprinklers and one for garden. Water the garden first thing at night after the last "wash of things inside the house" like 11pm. in middle of night set the sprinklers after couple hours or so to give the well time to replenish. Sometimes when we are in a drought situation and water table drops, we have to make do with what we got. Just spreading out the water usage will do it for you.
/ At Home In The Woods #4,176
OBED you are drawing down the storage in the well a little over 1 gallon per foot if its 6"
at 17.6 gpm from the pump I think you are exceeding that flow with the sprinklers if they are the impulse ones I would set up one over a tarp on a hill and funnel it in to a 5 gallon bucket. and time it to see how much you are flowing at one time.
this rain bird link rain bird
might help to calculate flow
the key is the orifice size as to how much water is flowing
Product Description :
Impact Sprinkler, NPT 1/2 In, Material of Construction Brass, Stainless Steel Spring, Adjustable Pattern, Pressure 20 To 50 PSI, Flow Rate 3.4 To 5.0 GPM, Spacing 50 Ft, Radius of Throw 20 To 41 Ft
Professional Underground Sprinkler-Impact Head by RAIN BIRD - Irrigation and Sprinkler Timers by Zoro Tools Industrial Supplies
tom
We are not watering the lawn, only the garden. We have 3 hose bib's around the house, one at the well, and one at the garden 200 ft from the house. We have 3 sprinklers in series in the garden hooked to the garden spigot. Watering the garden twice a day for 15 minutes does not appear to be over using the well. We have to remember to turn off the water though. We will get a timer if we can find one that will turn on for 15 minutes twice a day.
Eventually I plan to install a home automation system and will use it to control the watering of the garden. I just need infinite anoints of time for all my projects!
tony Cecil said:
How are the tomatoes? tony
Tony,
They are doing fine. We have picked 5 or 6 so far.
This week we are hoping to get some sweet corn from a farmer from whom a family member has bought corn during previous years. My wife will cut it up, cream it, and freeze it.
Obed
/ At Home In The Woods #4,180
Obed, what was the GPM and the static water level depth of your well when they drilled it?
You said it's a 300' well w/ pump @ 280, so in other words, how many feet of water is on top of the pump?
I just talked to the well driller yesterday. He is going to stop by and give me his "guestement" on depth for my location. We have all water witched the area with coat hangers and so far everyone gets a strong "hit" in the same general area of about a 20' circle. I had never done witching before, but there is a force present....whether it is underground water remains to be seen.
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2011 CHRYSLER 300 SEDAN (A62130)
2011 CHRYSLER 300...
2002 INTERNATIONAL 4700 4X2 LANDSCAPING TRUCK (A59908)
2002 INTERNATIONAL...
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
