New guy-New tractor
/ New guy-New tractor #1
Srb08
Pendleton, mo
Mahindra 4530
Hello from mid Mo.
I presently own a 2615 and am probably going to trade up to a 4530 next week. Any words of wisdom or caution from the group?
The 2615 has been a great tractor and I really hate to part with it but I need something a little larger.
Thanks in advance for any feedback.
Steve
/ New guy-New tractor #2
Welcome aboard. Best wishes. You will probably receive more assistance by posting in the Mahindra forum here on TBN. Just a thought?
/ New guy-New tractor #3
Only advice would be go as big as you can afford comfortably. I have a 5530 and can say that it is a strong basic machine.
When I bought my 2615, I thought it would be the perfect tractor for my needs. For the majority of what I do it's fine. I have a mile of driveway through rocky, hilly and wooded terrain that I maintain. The 2615 is too light for this work. I was planning on trading up to a 4530 but have also looked at an 8560. I thought the weight of the 4530 would be sufficient to pull a 7' blade. Because of the large rock in the ground and the steep grades, a box blade just doesn't work.
I thought I had my decision made but after reading here, I'm leaning toward the "more is better" school of thought.
I want to buy enough machine but don't want to go too far overboard.
/ New guy-New tractor #5
If you are at all interested in a cab then forget the 30 series, nobody makes one for it - OEM or Aftermarket. Something to consider if you do any snow removal with it. I have been very happy with my 5530. It has plenty of power and enough weight to put that power to the ground. Although the 8560 cab is a very nice machine, I may have to upgrade in 5-6 years after I am done building on the property. Good luck!
/ New guy-New tractor #6
I love my 8560 they only problem is that I did not get a cab.... Now I wished I would of:ashamed: I am getting a 80 acre ranch back to what it used to be and the 8560 was the right tractor for the job:thumbsup:
/ New guy-New tractor #7
Just my :2cents: here. If you don't want to spend a lot of time working on your road, you will need weight and horse power and the right implements for the task at hand.
You need a tractor with 50 or more HP.
That tractor with loader and any other ballast needs to weigh over 7,000lbs.
You should have a LPGB (land plane grader blade) to do the majority of the road maintenance.
You should have a rear blade for any ditching or reshaping of the road.
A box blade is nice to have when larger amounts of material need to be moved.
A landscape rake is nice to have to do finishing touch up on the road.
These implements need to match the capabilities of the tractor, definitly not less and it is better if they are not a lot over sized.
I maintain over 2 miles of roads, I have all of this stuff. It can be done with a smaller tractor, just takes a lot longer. If I could only have one of the 4 implements to maintain the road, it would be the LPGB hands down.
If it were me, I would be looking at the 5035 and up.
Good luck with your decision, have fun looking, let us know if you have any other questions. ;)
/ New guy-New tractor #8
I just bought the 5035 and I love it so far I went from a 32 hp JD to the 5035 Mahindra and I made the correct move.
Thanks for all of the feedback.
I'm going to see the dealer tomorrow morning. Hopefully we can work out a deal.
Best,
Steve
Test drove the 4530 today. I like the tractor but was unable to figure out the ipto. The dealer was unable to explain what it was for and how to use it properly. We even read the owners manual and were still confused.
I would appreciate any info from anyone who can help.
Thanks,
Steve
/ New guy-New tractor #11
Steve,
The ipto is easy, the long handle is just a clutch, pull it foward and lock it in position ( like holding down clutch pedal) now reach back to the shift handle located just behind the ipto handle and put it in gear. Now move the ipto handle back and the pto will be running. To stop the pto, clutch it with the ipto handle. Turn it on and off while you are using your pto powered implement and when you are not using it shift it out of a gear and put the ipto handle back so you are not holding the throw out bearing against the clutch. Really a more realiable system than the larger 30 series that have gone to the one lever system if operated correctly.
Dave
Dave:
Many thanks, simple concept and you explained it very well.
I guess you can expect some confusion when the guy writing the manual for the US doesn't speak english as his/her primary language.
Best,
Steve
/ New guy-New tractor #13
I'd love to have one of the rollover box blades, anything else is a wast of $$$ when it comes to a rollover.
2nd on the list is a land plane. I agree with mtveiwranch.
david
The dealer dropped off the 4530 and picked up my 2615. Temp guage does not work on the 4530 and the steering seems pretty loose. Hopefully, the dealer will take care of these issues. Other than these two things, the tractor seems OK. Hopefully, these are the only problems I will encounter.
Anyone else have these types of problems or others at delivery?
What makes you think the steering is loose?
With the steering wheel centered, the tractor will not track exactly straight. Sometimes it tracks slightly to the left and sometimes slightly right.
/ New guy-New tractor #17
That is the nature of the beast, being it is 100% hydraulic steering. Don't pay attention to your steering wheel position, just drive it straight.
/ New guy-New tractor #18
I have a 5530 and can tell you the steering is fine, as Galen pointed out it is a different system then in a car. As far as the temp gauge goes, it does take a bit before it moves. I would have to say these 30 series are built with a good cooling system. They are able to do hard work in high heat because of this, as an ag utility tractor should. You have stepped into a much heavier class of machine. They are meant to work all day without hesitation.
I hope this helps and enjoy your new beast of a tractor. You will be amazed at the amount of work it will do and still ask for more!
Thanks for the reassurance concerning the steering.
I drove the tractor about a mile from where I unloaded it, to the barn. Outside temp was 100. The temp gauge never moved.
I did find that I can't whip the 4530 around like I did the 2615.
I think I'm going to like this machine, just a bit of a learning curve with the move to a much heavier tractor.
Best
Steve
I finally had a chance to put the 4530 to work today. I hooked up my 7' grader blade and went to work on my road. Was working on a rather rough section of the road when I felt a little jolt and heard a pop. Looked behind me and my blade had been folded back on one side. I caught the top of a large rock with the end of the blade. The tractor didn't seem to notice that it was hooked on a rock the size of a small car, it just kept on going. The blade was a brand new king kutter I had bought last winter to use clearing snow with my 2615. Since the winter was so mild, I never needed to use it.
I guess it's time to consider heavier implements.
On a different note, I did notice that the bucket angle would drop and I had to occasionally rotate it back up. I did the same thing with my 2615 but didn't need to adjust the angle nearly as often.
So far, I'm pretty impressed with the 4530.
Best,
Steve
