Beat Juice -- does it freeze?
/ Beat Juice -- does it freeze? #1
emcvay
Pasco WA
Mahindra 5010 w/FEL
Something I was thinking about the other day was whether or not beat juice freezes? We can get temps in the -30s in the coldest part of winter and I'd hate to get up to the property only to find the tractor with exploded tires from frozen beat juice! lol :eek:
/ Beat Juice -- does it freeze? #2
The rim Guard web-site states freeze resistant to -35F. Don't know if it would freeze solid or just get slushy at that point. Doubt it cause your tires to explode unless you had them plumb full with no air pockets. Normal fill level is around 75% full so you always have an air pocket in the tire for expansion and allow some tire deflection when going over bumps etc...
Roy
/ Beat Juice -- does it freeze? #3
It is my understanding it will not freeze solid, will get slushy though.
Thanks guys. Being a total newb it was just a thought I had last night.
/ Beat Juice -- does it freeze? #5
I feel for some of you guys, when it is cold enough to freeze Rimguard my equipment is going to sit.
/ Beat Juice -- does it freeze? #6
I've been running RimGuard for over 5 years now. Our winters don't get that cold, but -10 F with -30 wind chill is not uncommon and I do a ton of snow removal. I have had no problem with my tires getting slushy or anything. Over all it is a great product. Most weight per gal. by far! I could see it getting slushy if it was static i.e. sitting out overnight exposed to the wind and cold around -45 f. I wouldn't want to be out at all if it was cold enough to freeze solid while moving. That would have to be pretty extreme.
/ Beat Juice -- does it freeze? #7
Yes, yes it does. And when it freezes solid, and it does, the tires are a bit out of balance.
Having said that, they were trying it to see if it froze.
/ Beat Juice -- does it freeze? #8
I think the whole topic is sorta bogus. Beet juice, like virtually every other material in the universe, will freeze, and it will freeze solid. The question should really be at what temperature it freezes, how does it behave as the temperature drops, and will I ever see that temperature where I use my tractor.
If it doesn't freeze until -45 F, most of us won't care (AKwelder excepted). Wind chill will not affect this, only the temp.
I did have to work in -56 once back in 1983, but there was no way we could get the tractor to turn over, muchless start, so frozen fluid in the tires was not a concern.
/ Beat Juice -- does it freeze? #9
Somehow jenkinsph- I doubt it would get that cold in NM.....
I have rimguard in NYS cold weather up to -15 close to -20 and no issues. Everything can freeze, given if it get cold enough like more then -35 but it's in a tire thats rubber so it will expand tire. first. I really, really dont think it will ever explode as ice forms slowly. If your temps gets colder then say -50 and then rupture the metal rim, you won't even see the leak till it warms up - like months later.
Sounds like a silly question now but I was just remembering some water cans that 'exploded' a couple winters ago (before I got smart and emptied them sooner)....basically it's an expression for any item that freezes and in doing so splits the walls/lid of whatever it was freezing inside of.
/ Beat Juice -- does it freeze? #11
Feb 2011 we reached -28 degrees and held there for overnights for a few days, very cold for this area.
/ Beat Juice -- does it freeze? #12
Well their own data on the RimGuard site says it does freeze, but at a much lower temp than most people will ever be concerned with. We get some cold ones here in Upstate NY but it usually doesn't sustain it for a really long time. I assume it would take quite a while at it's freeze temp before it would freeze a tire solid. With a -25 or so overnight temp I doubt it would be an issue unless it didn't warm up the next morning. :shocked:
If I remember correctly; water also freezes different than most liquids in that it can vary from complete liquid to complete solid with only a few degrees of change. Most liquids have a slushy phase where it wont freeze solid without a large sustained drop in temp.
Water also acts different as it freezes than most other liquids. Most continue to shrink as they get colder, but water only shrinks as it starts to freeze and then expands as the molecules form into ice with an expanded crystalline structure. That is why ice floats even though it's water... It takes up more space and displaces more water than its original weight. So I wouldn't use plain water in your tires unless you live where you KNOW it will never freeze.
Anyways, the beet juice is supposed to be the best replacement for Calcium but it's expensive. It would be interesting to see a demo of testing on it at different temps and see how it reacts.
We are likely going to use -20 windshield washer fluid since it's much cheaper and can be installed ourselves. It is not as heavy as the RimGuard though and that's too bad, but the cost savings is significant.
I wonder if you could mix washer fluid with an antifreeze that would lower its freeze temp even more. Anyone know of something that would be compatible with the washer fluid?
Later Glen
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
