A New Rule?
/ A New Rule? #1
Mark Page
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
On many occassions I have wanted to respond to a thread only to find out I'm not sure of the horse power of the tractor being referred to. I find this especialy true with Kubotas. So, instead of mentioning just the model throw in the horsepower too.
For example, If I mentioned my Massey 2615 you'd have no idea whether it could handle a 6ft. snow blower or not. However, If I mentioned my 49 horse Massey 2615 you'd know how to respond.
Just a thought.
So will my Model Q123 Gazornaplat handle a 15 ft batwing?
/ A New Rule? #3
Mark it's great idea, but doubt you'll get much voluntary participation.
I happen to have a Ford 4000 tractor. I learned years ago to say I have a 1967, 3cyl, Ford 4000 when asking questions about this tractor. People will just have look up the subject model numbers before replying or reply with questions about size and HP.
Wedge
/ A New Rule? #4
Just a thought.
Yes, yes it will and quite well I might add; had one for years just like that.:laughing:
I concur with Wedge; good idea, but I doubt it will work and I have to admit I am as guilty of this as anyone else. I usually just have to check Tractor Data to find out the HP and such on tractors. Matter of fact, I don't even know how much HP our Case 995 has and would have to look it up.:eek:
/ A New Rule? #5
But a 25 hp tractor from 50 years ago was twice the weight and size of a modern 25 hp tractor, and can do lots more work.
Bruce
/ A New Rule? #6
Bruce
Then maybe go by PTO HP, we have some old tractors 50+ years old and they seem comparable to modern tractors in the tye of cutters they will spin, but not in field work; guess it depends on what you are doing. A full description of draw bar, PTO HP, weight gearing etc. could get pretty involved.
/ A New Rule? #7
Its a great idea will save alot of folks having to do the tractordata thing but most will just say if you dont know anything about the tractor anyways why are you trying to give advice on what size of shredder/mower it can handle:D
TripleR can probaly remember my question about the Kubota 5040(46pto;)) will it handle a 15ft batwing?
/ A New Rule? #8
Sure do and think I "may" have gotten that one wrong.:eek:
/ A New Rule? #9
:laughing: I dont think you were against it TripleR,I would have to go back and read it but there wasnt very many saying it would. I know I was set straight on here that when you post HP for your tractor ENGINE doesnt count,it has to be PTO. It just dont take alot of KUBOTA to pull one:D
/ A New Rule? #10
Hard to tell, my memory often leaves a lot to be desired. I think someone even advised against an M8540 once for a bat wing.
/ A New Rule? #11
It would be nice if all you had to do is move the mouse pointer over the tractor model and data such as weight, PTO HP, years built would magicaly appear. :D
/ A New Rule? #12
hitting a site like tractor data will give you basic semi-reliable info on about 98% of tractors out int he last 100 ys...
takes seconds to look.. that's all..
/ A New Rule? #13
A skilled writer would weave that information into his post to better communicate his point and define his questions but some of us only took English in high school because it was required and Lisa Lou sat one row over and looked soDAMgood in those denim miniskirts.
I agree that if you don't know the tractor mentioned off the top of your head you might not be the best reader to offer advice about it but, for those that are reading trying to learn about tractors before they buy them it would be easier to have the OP stick that info in the first line and save fifty visits to tractor data.com.
You could put it into a facts bracket (JD5045E/45/39/6500) etc. but new readers would have to have it explained to them and some of the nit picky people might have quite a time debating the proper way to post those numbers and which numbers to count. Base machine vs as ballasted vs including loader and back hoe weight vs including ballast box on 3PH. and on and on.
/ A New Rule? #15
:confused:
Imagine the puzzlement on my face the first time I suggested to a teenager that he look up something in a reference book like an encyclopedia and he replied that he would just "Google it"!!
It is a great thing but not as all knowing as they think it is.
/ A New Rule? #16
. but instead of berating a user asking a question who may be new himself.. is it really so hard to lookup a tractor and perhaps learn soemthing in the process?
besides.. tisco probably likes the traffic.. :)
/ A New Rule?
Somehow I knew this would go over like a lead balloon.
Engine or PTO HP will tell you more about a machine than any other single pc of info, IMHO.
/ A New Rule? #18
No, it's a good idea. For some reason, where I grew up, a tractor's model number wasn't nearly as referenced as its engine size. Rather, when you asked someone what kind of tractor they had, they'd reply "It's about a 60hp John Deere" or "It's a 100hp Case" and so on. They wouldn't necessarily mention the model but rather the engine power of the tractor in describing it to you. If someone had a "four wheel drive" tractor......then you automatically knew it was a big ag tractor with at least 200hp.
I agree referencing PTO HP would be great as that is the standard that tractors are graded by. However, as mentioned above, with today's tractors and all of the variations in weights and sizes as compared to 30-40 years ago, that can be a little misleading too.
/ A New Rule? #19
We need a code to go with the new rule. The code would be similar to that used for fertilizer (and with good reason).
1st # - HP
2nd # - PTO HP
3rd# - Base machine
4th # - ballasted
5th # - including loader and back hoe weight
6th # - including ballast box on 3PH
As an example, my l3240 would be listed thusly:
32-26.5-3240-3450-5120-5970
Much simpler than looking it up on TratorData, eh?
Oh - BTW, I remember Lisa Lou, wasn't she from the Islets of Langerhans?
/ A New Rule? #20
We can easily add it to our profile.
see below
(2) UNUSED 12-16.5 TIRES ONLY (A64280)
(2) UNUSED 12-16.5...
ATTENTION PLEASE READ (A64119)
ATTENTION PLEASE...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
2013 Ford F-150 Crew Cab Pickup Truck (A61573)
2013 Ford F-150...
