3032E FWD
/ 3032E FWD #1
Steve IA
Clarke Co. Iowa
Ford 8N 1949, JD 3032e 2010
If I raise the front wheels off the ground with the FEL, and engage the FWD and put it in gear (HST) should the front wheels be powered even if the back wheels are not moving?
I suspect my fwd isn't working, but don't know how else to test it.
Thanks
Steve
/ 3032E FWD #3
Thanks
Steve
Try this:
Move your tractor to a good sized tree...do this in 2WD first.
Dump the bucket (top flange and cutting edge should be against the tree) and move against the tree...BTW, look for any broken or suspicious looking limbs!!
We don't want to kill you during the test!!
Once against the tree, add a little RPM. Your rear tires should start spinning.
Back away from the tree and select 4WD, then move against the tree as before.
You should see one or both front tires turning as well as the rears.
This test shouldn't take you more then a few seconds to determine if your 4WD is working. Don't use enough speed or RPM to damage your bucket.
/ 3032E FWD #4
Or take it out on a hard surfaced road and make a sharp low speed turn left or right. It will let you know if the front axle is engaged or not. It gets pretty ticked off, jumps up and down, squeals and barks under such circumstances.
2021 WACKER NEUSON LIGHT TOWER (A63569)
2021 WACKER NEUSON...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2018 John Deere 544K-II Wheel Loader (A63109)
2018 John Deere...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
BOB TAIL KILL TANK (A63569)
BOB TAIL KILL TANK...
2016 GENERAC MMG025IF4-01 MOBILE POWER (A59910)
2016 GENERAC...
