Replacing engine on old troybilt horse
/ Replacing engine on old troybilt horse #1
bswindell
Mt Pleaant, IA
ford 600 jd 5003 troybilt horse
could uses some advise on new engine to replace old 6hp tecumseh I want to be able to use throttle cable I kind of concerned about the engines I've see with the throttle on the front of the engine
/ Replacing engine on old troybilt horse #2
So are you replacing the engine entirely? You can pick up engines at Harborfreight or even go to a Lawnmower repair place and see what they have laying around. The throttle cables with levers you can pick up at some hardware stores or Ebay for cheap.
/ Replacing engine on old troybilt horse #3
The 6.5 HP cheapo HF engine is a perfect replacement, but you'll lose the throttle cable, though I'm sure it won't be hard to staple one to it.
If you look in a few DIY magazines you can sometimes find a $99 coupon. I installed the exact engine on mine and it works a treat! You will need to add a few washers to adjust for the reverse disc alignment.
Thanks for the help
/ Replacing engine on old troybilt horse #5
You could go all Tim Allen and put a nice Kohler 20hp on there and really get the dirt flying. :thumbsup:
/ Replacing engine on old troybilt horse #6
I found a used front tine tiller at a yard sale that looked great with a nice new looking Briggs engine on it. I bought the tiller for $100 and it took me and my son less than an hour to have it running with the new engine. It pretty much bolted right on. The tiller works great now. I think it is a 6 HP, but I would have to walk all the way out to the shed to check for sure.
/ Replacing engine on old troybilt horse #7
This one is a HF engine that I put on my Horse, all that was needed were a couple shims to line up the engine pulley and transmission pulley.
http://www.harborfreight.com/predator-212-cc-ohv-horizontal-shaft-gas-engine-certified-for-all-states-except-california-68120.html
/ Replacing engine on old troybilt horse #9
There are a couple threads on this if you search. Some guys used the Honda engine as well.
/ Replacing engine on old troybilt horse #10
The cheapo chinese engine is a Honda, just without the sticker. Even spare parts match up to Honda.
/ Replacing engine on old troybilt horse #11
I had replaced a motor for my grandfather on his TB Horse about 15 years ago, is was a snap, but he had ordered the replacement directly from TB and paid out the rear . IIRC it was about a 1 hour job, but it was an Identical engine so everything was easy. I know that doest address your cabling question, but from what the other guys said, you can likely get retro fit parts for the gas throttle.
/ Replacing engine on old troybilt horse #12
The cheap chinese engine from HF may be a Honda knock off, but it wouldn't be a Honda. They may have made it so some Honda parts interchange. if you don't want to patronize the Chinese knock off industry (I don't) you can find old front tine rototillers with functioning engines on craigslist that will match up, but check the bolt pattern and shaft size/type closely. Many of those will match up with the throttle cable as well. I would rather put money in a local person's pocket who is clearing out their garage than the Chinese. Whatever engine you put on, make sure you check the oil with the engine level per manufacture's recommendation. The way a Troy Bilt sits, it has the engine at quite an angle, particularly if the depth is set to till deep. Tecumseh engines had their oil fill tube to the rear and if you checked the oil without leveling the engine or at least setting the depth to shallow, you could be way too low on oil even if the oil level indicated normal. I think running low on oil is what attributed to many Tecumseh Troy Bilts throwing rods. Again, this will apply to any engine you install. If the fill tube is to the front, you could add too much oil which can be bad as well.
Many name brand manufactures now have engines made in china now to exact standards. This doesn't apply to knock offs.
/ Replacing engine on old troybilt horse #13
The cheap chinese engine from HF may be a Honda knock off, but it wouldn't be a Honda. They may have made it so some Honda parts interchange. if you don't want patronize the Chinese knock off industry (I don't) you can find old front tine rototillers with functioning engines on craigslist that will match up, but check the bolt pattern and shaft size/type closely. Many of those will match up with the throttle cable as well. I would rather money in a local person's pocket who is clearing out their garage than the Chinese. Whatever engine you put on, make sure you check the oil with the engine level per manufacture's recommendation. The way a Troy Bilt sits, it has the engine at quite an angle, particularly if the depth is set to till deep. Tecumseh engines had their oil fill tube to the rear and if you checked the oil without leveling the engine or at least setting the depth to shallow, you could be way too low on oil even if the oil level indicated normal. I think running low on oil is what attributed to many Tecumseh Troy Bilts throwing rods. Again, this will apply to any engine you install. If the fill tube is to the front, you could add too much oil which can be bad as well.
Great point!:thumbsup:
/ Replacing engine on old troybilt horse #14
This spring I put a TSC. Honda on my tiller. it was labeled a tiller type and had the throttle control cable attachment.
Getting old and like the easy pull and start every time engine is 50 X better that original where it was yank and pull and do again before starting then would run 15 feet and stall out.
Would recomend this for a tiller engine.
ken
/ Replacing engine on old troybilt horse #15
Hondas do start well, I will agree to that. Not all do, but most will start in one or two pulls. But I have a Briggs IC 8hp on a BCS rear tine tiller that always starts in 4 pulls, never more, never less. That is nice too.
/ Replacing engine on old troybilt horse #16
The Generac engine on my Dixie Chopper says "MADE IN THE USA". Only problem is, from parts that were made from where?
/ Replacing engine on old troybilt horse #17
I have a 8hp troy bilt Horse that I am in the process of removing the engine. Never having removed an engine from a Tiller, I have reached a stopping point. I have removed 3 screws that mount the motor on the frame base plate , another two screws that are near the handle extension and loosened the screws that are contained within the belt housing. I dont have any documentation, so I am progressing slowly. Any ideas and techniques would be greatly appreciated. In addtion, does anyone know if the Harbor freight motor is a "plug and play"?
thx
jt
/ Replacing engine on old troybilt horse #18
Motor should be plug and play if the output shaft is on the same side and diameter. The motor height should be close to the same so that your belts will tighten up correctly. Disconnect your throttle linkage and the motor bolts should be about it. Take some pictures to help remind yourself how it came apart.
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
