Thanx for the input lutt. Were down to less than 3 weeks and I should
have the canopy and serious thought / design will begin.
Another reverse engineer option is to visit a few ATV/UTV dealers and check out the Polaris/Yamaha/Kawasaki....brands that have all the various ROPS design as OEM certified product. The steel gauge you select can be reversed per vehicle weight comparison...just a thought
Now having suggested this I have also seen if they work via YouTube - Broadcast Yourself. as there are a few destructive but unintentional crashes of MOVING vehicles. For a slow moving/stationary vehicle with an unknown falling load that may have to be compensated for. eg If a large tree limb falls horizontal vs vertical. Slight difference in surface pressure. Most if not all high impact auto systems use triangulation cross technique, again something to consider overhead for a vertical or concentrated weight fall. Something like an X shape across the roof welded to the vertical supports.
Good luck.
Yea...shouldn't be too awfully hard to attach to the tractor. I have a
few ideas but till I have that canopy in hand I wait on most designing.
Were down to 13 days and I hit 54 /BD and I should have the 1133
canopy in hand.
I have built a few different roll bar parts. I own a tubing bender w/ hydraulic.
I have BEND TECH software as well.
I have some 1.75" tube in stock "if" I go that route. I still
have not rulled out getting a second BX25 ROPS and hangin' it off
the FEL uprights...I can draw in CAD so I can do a lot. Not going to
hurry...
I do remember that 1133 canapy as having a substancial support system.
I really can't wait to have it in hand.
If I had to make one suggestion for this whole project - it would be to spend some time studying Inspectors in the race world look at weld quality and tubing thickness. The SCCA rule books specify holes drilled thru tubing so the inspectors can check the wall thickness...............
Triangulation is important. If you are creative you could triangulate the thing pretty nicely without infringing on the convenience and access points.
