BX25 Full Cage Rollbar
/ BX25 Full Cage Rollbar
I APPLAUDE your posts NHMitch... ( and others.......... )
Thank YOU all...
THAT is what I call PASSION "."
I have a factory "ROPS" on my BX25. Kubota Co. sells a canopy #1133 I
believe that attaches to said ROPS and I would bet that attaching said
does not void any warranties to the OE ROPS system. It is quite the
substancial system...if I remember correctly, FWIW.
Maybe I titled this post wrong, maybe not, but my intentions are to start
thinking about adding a pair of "A" pillars+ possibly joining w/ the 1133
canopy bracket. If I flush out a lurker, or other, w/ pics, who has done it
prior, so I might learn from their "been there done that" knowledge THAT
would be great, alas to date I see nothing built to the standards "I" seek.
I remember that 1133 bracket as being substancial, built just like the
rops it is "if I remember correctly". From there a pair of "A" pillars down
to the FEL rear supports and afix w/ bracketry, again, no welds, no
drilling, just attach to... I will probably make it w/ an "X" or "H" system,
maybe both. I am POSATIVE I can enhance the safety aspect of the
BX25, I hope not for a huge wad of cash as well. I need to fall upon the
right ROPS system, again the OE ROPS may be the ticket. So if anyone
is reading this and if you have a BX25 ROPS you took off I might be
a buyer...
It will need a few things for added support. I may "X" the A Pillars and
throw in a horizontal bar just above the dash, or maybe both...
To date I have not seen anything built for a BX25 that get's my approval.
Nada, Zilch Zip... I have seen a few men make there idea of
a cage, not to my standars is all, they did good, I want to do better...
The end all may be finding a stock BX25 ROPS and modifying it into an
"A" pillar stiuation, used in conjuction w/ the OE unmodified ROPS and
canopy bracket, I mean w/o so much a even painting the OE ROPS, let
alone welding to it.
I think it can be done w/ simple bolt on bracketry. No welding to frame or
voiding any warranties. I saw what can happen personally and trust me,
"something" will be Waaaaaaaaaaaaaaaaaaaaayyyyyy better then nothing
for ROP and FOP AND side swiping branches...
I wish I were made of money, I am not so I have to do mountains of
research on stuff before I implement said ideas, and eventually I will do
something, when all the stars are aligned, it will happen, it WILL work.
Right now I need to make sure the wife has anough cash and the model
number for the canopy I seek seeings how my BD is coming up :thumbsup:
PS & FWIW; I refuse to buy into the train of thought that I
should bow to the Harvard or Yale taught designer / engineer at large and
go w/o, simply because they do not make what I want and indeed is
needed, buy my readings, wanted by a lot more folks than just me.
OK WHO WANTS TO MAIL ME AN OE BX25 ROPS! I'll pay shipping! :D
/ BX25 Full Cage Rollbar #42
I think building your own canopy out of 1/8" aluminum with 3/4" of polystyrene bonded to it and maybe 1/8" plywood under that would be way better than the factory fiberglass canopy.
The problem I have with factory canopies is that they can't handle being rammed into a tree!
/ BX25 Full Cage Rollbar #44
Maybe I need an orange canopy on my John deere then!
/ BX25 Full Cage Rollbar #45
I wonder how a section from the floor of an old pickup bed liner would work, or a piece cut from a pickup cap/cover/canopy.
With appropriate frame, of course.
Bruce
/ BX25 Full Cage Rollbar #46
Bcp, it would work fine. I chose bright aluminum for heat rejection. I don't like the black factory canopies for that reason. They also act like a loudspeaker with minimal insulation. I was also going to put an asphalt sound dampener under the alum.
/ BX25 Full Cage Rollbar #47
"Honestly I think a lot of the perception of the magical powers of factory installed ROPS comes from the backwoods hicks who think they can build a ROPS of FOPS out of electrical conduit and JBWeld."
Uh-oh. Time to re-think my new ROPS plan.:D
/ BX25 Full Cage Rollbar #48
I just rented w Jd 35d mini ex and the roof panel was caulked to the round roll cage. It had some dimples in it for stiffness and wasn't too bad sounding. Of course the engine was under my butt with rear facing exhaust too!
/ BX25 Full Cage Rollbar #49
Some one may have said something about already,but you could get some ideas on cage construction by looking at tractorhouse online,just google tractorhouse, and search for tractors with forestry package, there are a few in the magazine version I have right now. Or you may google forestry package on a tractor. I know the local electric coop has them for bushhogging right a ways under power lines. I was cleaning up a fencerow with the backhoe one time and had a deadfall fall on the cab. So the concern for protection from rollover and debris is understood. Hope this helps. LUTT
Thanx for the input lutt. Were down to less than 3 weeks and I should
have the canopy and serious thought / design will begin.
/ BX25 Full Cage Rollbar #51
Sounds great. I'll build one too after my grapple bucket project is done.
/ BX25 Full Cage Rollbar #52
/ BX25 Full Cage Rollbar #53
Another reverse engineer option is to visit a few ATV/UTV dealers and check out the Polaris/Yamaha/Kawasaki....brands that have all the various ROPS design as OEM certified product. The steel gauge you select can be reversed per vehicle weight comparison...just a thought
Now having suggested this I have also seen if they work via YouTube - Broadcast Yourself. as there are a few destructive but unintentional crashes of MOVING vehicles. For a slow moving/stationary vehicle with an unknown falling load that may have to be compensated for. eg If a large tree limb falls horizontal vs vertical. Slight difference in surface pressure. Most if not all high impact auto systems use triangulation cross technique, again something to consider overhead for a vertical or concentrated weight fall. Something like an X shape across the roof welded to the vertical supports.
Good luck.
/ BX25 Full Cage Rollbar #54
Thinking about the high impact vertical load, maybe a cone style roof design that will deflect the overhead moving object to the side rather a flat roof design that must sustain all force and hopefully hold up??
/ BX25 Full Cage Rollbar #55
Good luck.
If I had to make one suggestion for this whole project - it would be to spend some time studying how rollcages are designed for race cars. These cages are designed to handle the forces of an automobile - at high speed - making impact at any angle. I would think that following the general design tips you would use for an automotive rollcage would work just fine for a rollcage on your tractor that is designed to protect you from rollover (at relatively low speed) - and falling tree limbs.
The biggest thing you're going to have to try to figure out - is how to attach the rollcage successfully to the frame of the tractor so that it doesn't rip off somehow like the ROPS in that earlier post where the tractor flipped over backwards.
I have a tubing bender - and have built a couple of cages for street cars that built (hot rods) . For a rollcage for your tractor I would start looking at suppliers of cages for cars that have pre-bent tubing and all the other assorted brackets and reinforcements etc. that are generally used. If you can find a supplier of pre-bent tubing (rollcage tubing in general is 2" or 1 3/4" DOM ) . The DOM part is important - the welded tubing can crack and split on impact which compromises the safety of the cage.
Inspectors in the race world look at weld quality and tubing thickness. The SCCA rule books specify holes drilled thru tubing so the inspectors can check the wall thickness.
Triangulation is important. If you are creative you could triangulate the thing pretty nicely without infringing on the convenience and access points.
Yea...shouldn't be too awfully hard to attach to the tractor. I have a
few ideas but till I have that canopy in hand I wait on most designing.
Were down to 13 days and I hit 54 /BD and I should have the 1133
canopy in hand.
I have built a few different roll bar parts. I own a tubing bender w/ hydraulic.
I have BEND TECH software as well.
I have some 1.75" tube in stock "if" I go that route. I still
have not rulled out getting a second BX25 ROPS and hangin' it off
the FEL uprights...I can draw in CAD so I can do a lot. Not going to
hurry...
I do remember that 1133 canapy as having a substancial support system.
I really can't wait to have it in hand.
/ BX25 Full Cage Rollbar #59
canopy in hand.
hurry...
Sounds like you have it under control!
/ BX25 Full Cage Rollbar #60
If I had to make one suggestion for this whole project - it would be to spend some time studying Inspectors in the race world look at weld quality and tubing thickness. The SCCA rule books specify holes drilled thru tubing so the inspectors can check the wall thickness...............
Good point, and also one item that is continually overlooked on a rollover situation is the occupant restaint system PLUS cage netting to prevent arms, hands being thrown outside the gage and potentially being crushed...or worse. Watching those side by side UTV rollovers on youtube just goes to show you how fast and unexpected things can happen.
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
1993 Ford LS9000 Tri-Axle Dump Truck (A61573)
1993 Ford LS9000...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
