Tires R4s chewing up lawn
/ R4s chewing up lawn #1
logankelly
winona mn
jd2520
Any of you owners experience your lawn getting chewed up by the tread design of the R4s?
/ R4s chewing up lawn #2
My current tractor has turfs. However, my old 790 had R-4's.
As long as I stayed off the lawn (slopes and uneven) when it was wet (even from a heavy dew), there was no problem.
Now, the weight of the tractor did leave impressions in the grass after mowing, but they were gone in a day or so.
Wet grass...then I'd get the problems, even when I selected 4WD.
/ R4s chewing up lawn #4
I dont mow with my B21 but the only time it chews up the lawn is hard or tight turns with the front tires.
The R4's overall are a good soltution for woods/rocks/lawn whereas the R1s are good for traction they will indent the lawn especially if soft/wet.
I dont have experience with turf on a larger tractor the only turf tires are on my cub cadet and ZTR and they can tear up a lawn as well if stopping or turning too quickly.
/ R4s chewing up lawn #5
Hello;
When we were buying our 3320 it had R-4's and we had the same concerns, tearing up stuff. Went and had a talk with a pal who was running a 750 with turfs. He said they were great. working his fields, snow plowing anything he wanted to do.
So I had the dealer switch to Turf's. First time I ran it in snow I knew I made a big mistake. One revolution and the trerad loads up with snow and spin, spin, spin.
The 3320 cab unit we have on order will have R-4's.
I'sure there are users that love Turfs for everythng and anything.
thanks, nicholas
/ R4s chewing up lawn #6
Hello;
thanks, nicholas
Nothing wrong with turfs in the right usage...and, it's pretty easy to install tire chains on them.
/ R4s chewing up lawn #7
ya turfs are way better in snow and ice than r4's. good luck your not gonna like an r4 for snow and ice after having turfs i don't think
/ R4s chewing up lawn #8
Interesting thread. I am currently waiting for my new 2720 w/R4 to be delivered. It's primary duty will be snow removal with 54" front blower and 72" rear blade. No mowing but occasional grass/yard travelling. The dealer seemed to agree that R4's were the way to go. I do plan to run chains on the rear during the winter.
My experienced is limited to a 2WD 30HP Ford farm tractor with R1's, iron wheel weights and chains.
/ R4s chewing up lawn #9
R-4's don't tear up my lawn, but then I don't mow with R-4's. Occasional driving on the lawn with them is better than with R-1 ag tires, but no residual marks left on the grass.
Turf tires are for turf.
R-4's are for industrial use like dirt work on rock, etc. and where FEL loader work is done.
/ R4s chewing up lawn #10
I've never used R-4's, but I've been very happy with my turfs. I have a set of chains for them if I really need extra traction and can say that they will, without a doubt, dig a hole in the dirt anytime I want. I short, with chains, they really dig in!
I automatically chain-up for the winter and usually remove the chains as soon as the snow is gone. The vast majority of my summer projects are just fine with the available traction afforded by turfs. If I need more traction, which is rare, the chains are always hanging in the garage, and are on in 10 min.
Tires will always be a compromise of sorts, no matter what you get, and depending on what you're doing, but I've found a compromise I can contentedly live with for a long time.
Joe
/ R4s chewing up lawn #11
Everything is a compromise one way or the other, I have R4's and have had for the last several tractors, but they can and will tear up lawn if it is too wet, and you turn too tight.. Plan ahead to make a minimum of turns and 2wd is better than 4wd as you don't want any tire scuffing. Of course if you are trying to push over a tree in your yard, well then all bets are off, anything that invites tire spinning is going to tear heck out of your lawn. R1's tear the heck out of most lawns quick in any case. and Although I have never owned any turfs on a tractor, I am sure they are probably the best on "turf" I am guessing that is why they call them that.:) The ideal tractor will be an Anti gravity machine that floats over the ground, and carry's a big load in the FEL, and suspends a mower too.:)
But I haven't seen any of those for sale yet. So in the meantime we have to choose a compromise do everything well tire . Or have different rims and tires for different jobs. Or different tractors.:eek:
James K0UA
/ R4s chewing up lawn #12
When my R4s were overinflated the increased ground pressure of the contact patch bit more deeply into the lawn. Now that my rear tires are down to 8.5 psi, and the fronts at 17.5, the bite is wider, more superficial and less destructive.
/ R4s chewing up lawn #13
R4's were not designed for mowing lawns. They are a comprise between R1's and turf tires. If the primary use of your tractor is mowing the lawn then you should switch to turf tires.
/ R4s chewing up lawn #14
turf tires REALLY shine on lawn and in snow. If thats the primary than thats the only way to go. R4's shine for loader work or any type of dirt work. R4's are as good as garbage for snow or ice without chains.
/ R4s chewing up lawn #15
Wow, I should have read this before I mowed with my R4's for the last 4 years. The only time they make any marks the ground is too soft to be mowing with any tires. If you are getting marks, slow down when turning or wait for it to dry out. I even have 4 70 lb weights on the front of my 4310.
/ R4s chewing up lawn #16
mfreund said:
Wow, I should have read this before I mowed with my R4's for the last 4 years. The only time they make any marks the ground is too soft to be mowing with any tires. If you are getting marks, slow down when turning or wait for it to dry out....
Same here, but I am just on the second year of using the tractor instead of riding mower. It also helps to avoid tight turns and making too many passes to do a perfect job. I use a push mower to trim around edges, trees, etc.
/ R4s chewing up lawn #17
I use a 322 lawn tractor and Round up for my trimming :thumbsup:
/ R4s chewing up lawn #18
Neighbors all had R4s back east. They never had any issues mowing providing it want wet, and never had trouble plowing snow. Turfs remind me of radials van tires, probably great on hard surfaces like a yard, absolutely can not see where they would be worth a plug nickel in any snow without chains.
/ R4s chewing up lawn #19
I mow with R4's and don't have a problem with them. They didn't work very well in the snow though. Even in 4WD. I ended up buying chains.
/ R4s chewing up lawn #20
I have had R4s on my last three tractors and have had no problems with yard damage as long as I use common sense when I mow and allow the wet yard to dry out some. In fact, the tractors I had before that all had turfs and my lawn looks as good now as it did then. I haven't had any problems pushing snow with the R4s either and I don't have chains like I did with the turf tire equipped tractors. If I had steep hills to mow or plow then I would guess I might have problems. I think terrain would have a major input into which type of tire should be used. What works for me may not work for you.
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63118)
2008 Ford F-250...
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
