We gotta eat too!
/ We gotta eat too! #1
Rustyiron
Super Member
Lakes Region, Maine
M 9540 Kubota
Threw this togher for the "camp", nuthin' wrong with weenies on a stick, but sometimes you need more! Found a suitable pc. of granite for the base & drilled a 1" hole to accept the 1" rod for the vertical rod that it all hangs and swivels on for height adjustment. I need to find a good old fashioned coffee percolator for some good camp coffee, that is if it's not beerthirty.
/ We gotta eat too! #3
Very cool...fun stuff. I have done the same thing and stuck a water pipe
up thru it for a hose bib...:)
/ We gotta eat too! #4
It certainly appears to be the perfect place to relax, eat, and watch the sunset. Excellent way to end the day. :thumbsup:
/ We gotta eat too! #6
I just bought this one a couple months ago, works real well.
[ame=http://www.amazon.com/gp/product/B001XUS4IQ/]Stansport Percolator[/ame]
/ We gotta eat too! #7
Last I set up a camp the wife was about to eat the last bite, the sweet bit, the bite you savor, THAN ONE bite that measures and defines all prior bites bites, of a hot dog.
Then a chip munch jumped up on the table and snatched it off her paper plate. I know I could have won 10K on funniest videos just for the look on her face.
/ We gotta eat too! #8
Here is a cooker we use on the 4th of July. Doors on both sides so racks can slide either direction, PID controled damper on wood box maintains temp within 3 degrees. Shown here with 4 briskets, 6 chickens, 10#s of sausage, 20#s of squash and zucchini, 60 ears of corn, 60 bake potatoes and 6 loaves of bread.
/ We gotta eat too! #9
Man you guys are making me hungry !! Good innovation!
/ We gotta eat too! #10
I want to know more about the PID controller!!
/ We gotta eat too! #13
IMO your jeopardizing your health. Do research into leeching of aluminum from pots and pans going into the body. If it is Alum it got tossed years ago in our home.
Thank you for your concern but I'm fine with the risks.
/ We gotta eat too! #14
It's a proportional controler that senses the temp and rate of change and makes adjustments on the damper. Looks something like this (the one I use on my bullet casting machine).
The damper itself is an old power window motor that is connected to a stainless 1/4 28tpi all thread that moves a slide back and forth much like the slide on a motorcycle carb.
/ We gotta eat too! #15
The smoker is also self starting (So its ready to go by the time I get up). Load with wood the night before and connect battery and propane tank. Uses standard automotive spark plugs and coil with a 12v solenoid for the gas. Once the smoker is up to temp it shuts off.
/ We gotta eat too! #16
Ya'll have some pretty slick cooking devices. :thumbsup:
/ We gotta eat too! #17
I have a simple rock fire ring at the farm "picnic grounds"! Sometimes fry up some smoked sausage w/onions peppers & tators or maybe grille some pork steaks or "country style ribs".
Second pic was at last Fall's "Garden Trail Ride". ~~ grnspot
/ We gotta eat too!
Now that is one heck of a cooker! It looks more like a smoker, I would not think that it would be suitable for bread? Who does not love fresh bread but how does it not get smokey? I just discovered a meat smoking forum (MSF)and a small smoker is on my build list. I just started poking around there and asking some questions. Another cool (outdoor) thing that I've been reading on are wood fired bread/pizza ovens.
/ We gotta eat too! #19
Foil keeps the smoke out.
I do have some forced air wood fed (hard wood only) pellet smokers that you can cook bread and pizzas on with out wrapping them up and they are better than an electric or gas fired oven.
/ We gotta eat too!
Now from what I've learned, it looks like yours is what is called a reverse flow? For a more even heating.
Gradall no crank no start (A61568)
Gradall no crank...
John Deere 7320 (A62180)
John Deere 7320...
FORD DIRT SCOOP (A62131)
FORD DIRT SCOOP...
iDrive TDS-2010H...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Arrow Quip EF10 Two Bow Alley Kit (A64047)
Arrow Quip EF10...
