valves
/ valves #1
LMan1967
Gold Member
Kudzu, Alabama
MF 1643
whats the difference between a 'float detent valve' and a 'double acting valve?'
/ valves #2
Double acting valve: Moving the lever in one direction supplies oil from the pump to the rod end to retract the cylinder. Moving the lever in the opposite direction supplies oil from the pump to the cap end of the cylinder.
Float detent: Has the same features as the double acting acting valve with the addition of a fourth position that requires you to push the lever past a spring loaded detent to get to "Float" and usually also locks the spool in this position. Float connects both cylinder ports to tank so the cylinder can "Float" depending on the external forces being applied to it.
Roy
/ valves
Ah. Thanks.
Is one preferred over the other? Kubota gives the option...
/ valves #4
Ah. Thanks.
For using a FEL the float is a nice feature. Allows you to back drag to level surfaces. Some people use it for plowing snow also. Allows the bucket to follow the ground with you the operator having to make corrections constantly.
Roy
/ valves #5
A float detent is nice on a rear remote for use with a hydraulic top link. The float position can help a lot when grading with a box blade.
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A64194)
John Deere 12in...
Great Dane Van Trailer (A63689)
Great Dane Van...
2002 Pace American of Texas T/A 26FT Enclosed Trailer (A61573)
2002 Pace American...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
