belt comes off LT1042
/ belt comes off LT1042 #1
bamaman01
Member
Section Al
cub LT1042
Now when I mow and lower deck gauge to lowest position the belt comes off after a short time. However, when I mow in position up from lowest it will not come off. I did notice that the idler pulley has a dip around the top edge, possibly that is what is going on. I know there is someone out there can tell me.
Thanks In Advance
/ belt comes off LT1042 #2
When I had this issue, I found that the bolt through the center of the pulley was loose.
/ belt comes off LT1042 #3
Thanks In Advance
The second pully from the left on the top of the mower deck, as you are sitting on the mower, may need to be tightened. The bolt to tighten runs from the top of the second pully to the bottom of the mower deck. You may have to scrape away dirt, mud, and grass from under the deck to locate the nut as it will spin as you tighten the bolt from the top. Good luck...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
TRAIL KING T/A DETACH (A67714)
TRAIL KING T/A...
1396 (A65054)
1396 (A65054)
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
