Grapple 48" WildKat grapple on order
   / 48" WildKat grapple on order #11
Not to scare you but have you checked out this thread? Seems like wildkat mean "economy" when they say it. It appears their upper frame is made out of 1/8" material. This may or may not be fine with your L3400. Just something to keep in mind.
Broke my grapple ( Am I the only one?) - Page 3 - TractorByNet.com
It is weak with the 1/8 inch at that stress point, but he got it fixed. Just a little time with a welder friend and it's better than new.:thumbsup:
James K0UA
i picked up my grapple today, got it home and unloaded safely. i am really excited to use this thing can't wait until i get the rest of the parts to make this go. i was able to find a QA coupler locally at a dealer i don't usually work with, they are willing to take one of a tractor on their lot and backfill with a new one so i don't have to wait a couple weeks for one to come from georgia. i was a bit worried because this one is off a newer tractor and none of the part #'s match up with what i was expecting (L2216 vs L2230A) but i measured and it looks like a perfect fit though so 2 parts down 1 to go - last is the hydraulics. i was leaning towards the kit from wr long but from what i have read some of those are acting as a diverter on some tractors so don't want to spend the extra $$ on the 3rd function if it's not really 3rd function. i have priced the fasse and rankin kits but not decided which way to go. i think i want to have hoses built specfic to my specs since i don't want have extra hose to deal with. anyway here are some pics of the grapple!
i installed the QA adapter today (L2216) on my L3400 and discovered there is a pretty big gap between the pins on the QA and the bottom plate. the difference is approximately 3/8" on the right side and 1/4" on the left side. also noticed 1/4" between the bottom of the QA and the plate. i am guessing this amount of play is not normal and needs to be corrected. i was planning on welding some stock to fill the gap's so the fit is more solid, is this something to be expected with just these low priced grapples or is it common among skid steer style attachments? i would expect some amount of tolerance is expected but 3/8" seems pretty big. i don't want the thing to pop off so plan to fix it before i use it..
   / 48" WildKat grapple on order #14
you are corrrect to fix it, there should be no play at all. It should be under tension as the beveled vertical spring loaded pins come down into the slots they should make good contact under spring pressure as the lever breaks over. There have been several reports of the gap, easy to fix and if you don't fix it , you run the risk of it popping off and usually pops off of one side and twists your QA adaptor torque tube.
James K0UA
James K0UA
So how much further should the gap be closed beyond the point of contacting the pin?
   / 48" WildKat grapple on order #16
I had the same issue. I called Connie and she sent me shim plates to weld in. Mine is perfect now. I am surprised they are still having this issue. She told me that some other customers had the same problem and they sent him shims out.
thanks i will contact them to have some shipped out.
i also noticed about a 3/8" gap between the bottom of the QA plate (horiztonal) and the grapple, is this normal or should it be shimmed as well? seems there would be up/down movement when lowering to ground and lifting off ground.. or does the pin shim take care of this as well?
   / 48" WildKat grapple on order #18
I guess I thought that was what you were talking about. Here is the thread where I posted picures of mine. I had a 3/8" gap between the QA plate and the grapple.
http://www.tractorbynet.com/forums/...ple-research-tentative-conclusion-what-9.html
   / 48" WildKat grapple on order #19
Big, my econo had the dreded gap also. If you don't shim it you will have no latch effect with your quick coupler. the pins have no preload to "cam over" and it can come unhooked. I just used 1/4" plate and adjusted both sides to give me about 5" of preload on the handle. It now fits tighter than my bucket. I also added 20" of bucket on each side of the grapple and use it as my firewood hauler!! It is good for about 3/4 of a face cord! I have had no problem with the 3/8" gap but I also extended the plates over past the pin to lessen the gap to 1/4". I could have used 3/8" thick plate but it would have been tight. I have about 20 hours on the grapple with 0 movement or wear. CJ
ok, i need to look at it again, am thinking it will take care of that gap as well.
i just got off the phone with connie and she is shipping out 2 of the coupler plates which should take care of this problem.
2013 Jeep Wrangler 4X4 SUV (A55853)
2013 Jeep Wrangler...
White Metal Roof Panels (A55758)
White Metal Roof...
2007 Ford Focus Hatchback (A55853)
2007 Ford Focus...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 Ford F550 Chassis (A55973)
2018 Ford F550...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
