Differential Lock Usage
/ Differential Lock Usage #1
Beltzington
Appling, Georgia
JD 3720
Yesterday I was rotary-cutting my property and I noticed I was using the differential lock pedal instead of 4WD for getting out of a loss of traction situation. I guess I started using this method because it is quicker for me to step on the pedal as opposed to reaching down to engage 4WD. I'm interested in your opinions on which method results in more/less wear and tear on the tractor. For discussion let's leave out the option of keeping it in 4WD all the time and assume not all the engagements will be perfect and some grinding may occur. TIA
/ Differential Lock Usage #2
Well here are my thoughts on the matter: If I knew I was in an area that I was liable to get stuck or "be delayed" I would put it in 4WD. But if you don't for see the problem before hand, it is OK to use differential lock. Just remember it is best to engage differential lock, at a very low speed of tire movement. It is kind of a slam bang type of thing.. you don't want to be spinning and hit the lever. You do need a little movement or they will not lock in. I have heard a lot of stories of guys tearing them up.. I have used them for years on different tractors and never had a problem.. Another thing you can do, is run in 2WD and with your split brakes unlocked, and when you start to spin one wheel just tap the corresponding brake pedal for that wheel. and it will slow it down, and allow the spider gear to have something to push against and get the slow wheel rolling again.. this you can do with a little more spin speed on a tire as it is not a hard bang type of engagement like the differential lock is. But again if I KNEW, it was liable to be "delayed" I would put it in 4WD for those sections I was working in. There you go.. advice, worth every penny of what you paid for it:)
James K0UA
/ Differential Lock Usage #3
KOUA has it 100 percent right. Stepping on the diff lock pedal with a wheel turning will stress the locking mechanism, as will throwing it into 4WD with a wheel spinning. Your stressing different parts but if you snap off a tooth of either one you have a broken tractor with an expensive fix so which part you broke makes little difference. Feathering the brake of the spinning wheel works well as you can steer better then having both rears locked together. I've used diff lock on a 2WD tractor to the point of people thinking it was 4WD but I always let her come to a full stop before stepping on the pedal or stepped on it before venturing forward into the slime.
/ Differential Lock Usage #4
As for me, in near 1,000 operating hours I have used the diff lock maybe four or five times and each time was when I was on snow and ice and needed to be sure all four wheels were turning. OP does not tell us what speed he was operating his tractor at or if he has a gear or HST tranny. I have never engaged the lock on my Deere unless rear tires were barely turning. For me with HST and electronic 4wd engagement if I have a loss of rear traction I prefer to engage 4wd and not use diff lock.
Depending on what Op's tractor is I don't know what method would create more stress and wear.
/ Differential Lock Usage #5
As for me, in near 1,000 operating hours I have used the diff lock maybe four or five times and each time was when I was on snow and ice and needed to be sure all four wheels were turning. .
You may have had all four wheels turning but very few rigs have all four wheels pulling. Back in WW1 they had trucks from FWD corp. that were 4WD all the time and ALL Wheel drive when you engaged the lever. Off road enthusiasts customize their "Jeeps" with front lockers but most 4X4 rigs have one front wheel and one rear wheel pulling in normal operation and the diff lock only locks the rear axle together. A lot of the newer cars have variable traction control AWD that puts power to whatever wheel can use it but you probably don't have that on your tractor yet.
/ Differential Lock Usage #6
I can't ever remember the diff lock on my MF helping out in snow.
/ Differential Lock Usage #7
I just raise the three point on the rotary cutter until the tires grab. And then lower the three point back down. I have 4WD and a differential lock. Used them both. For me it's just easier to raise the rotary cutter until the tires grab and then lower it back down.
/ Differential Lock Usage #8
Agree totally, usually for me it is the cutter that is hanging me up and picking it up is better than using force to drag it and maybe tearing up something
/ Differential Lock Usage #9
They build small tractors with four wheel drive because two wheel drive is not sufficient to keep us from getting stuck with what we put our tractors through. Four wheel drive CUTs were first developed in Japan to use in rice paddies because similiar sized 2 wheel tractors (like Ford 8Ns) wouldn't steer in that environment. Since I come from mud land, I always have the 4X engaged. The differential lock is an afterthought.
Follow these four steps when using your tractor off a roadway: 1) Always use four wheel drive on rough ground, particularly when using an implement, or on hills, or if you have to be in low gear just to make the terrain. You have more pulling force in 4x, or put another, way less wasted horsepower since more of it is engaged with the ground. 2) If you have a hesitation, raise the implement. 3) if that doesn't work to get you going then stop, engage the diferrential lock and try again. Be sure you can afford to go only STRAIGHT forward or backward, otherwise try the brake trick alluded to previously. 4) If still stuck try to back out using the FEL to push you. If after that you're still stuck, then consider a winch, wrecker, Cat, a new tractor, or logs chained to the back rims, in that order.
Finally DO NOT be afraid that you will wear out your four wheel/front wheel drive. I will last a s long as your tractor does - usually longer than you will keep it anyway. (That said, turn off the 4X on roads and in the barn cleaning stalls to save front tire wear.)
Mf
/ Differential Lock Usage #10
Your tractor engine/transmission can put out a certain amount of power. In 2wd it is designed to put 50% to each wheel. Start spinning one, press the diff lock, and it has the capability of putting 100% of the power to that single tire. No problem for the engine or transmission - they are designed for 100% power. The axle gears and bearings are not. That is why the diff lock is usually a hold to keep engaged - so operators don't overuse the diff lock. 4wd will split the power distribution for about 25% to each wheel depending on traction. So running in 4wd will generally reduce the load and increase the life off all components beyond the transmission. That is assuming you are in conditions where some slippage is allowed - most anything off of a paved road. Not sure about your tractor controls. Mine all allow front wheels to be engaged and remain engaged until I select otherwise. Diff locks on all of mine require me to hold them engaged. My operator manuals also say to engage the diff lock only when the machine is stopped. Front wheels can be engaged at any time. I think that is a pretty good indicator of how the manufacturer feels about them.
/ Differential Lock Usage #11
I occasionally use the diff lock on my Deere 4100 when blowing snow. Just enough hill and ice that 4WD isn't enough. I've never been stuck in snow - yet.
/ Differential Lock Usage #12
I wouldn't worry about it too much. Those of us who've used 2WD for years only had the option of locking the diff.
Thanks for all the replies, most of my traction issues are caused by washouts and other very short term terrain conditions usually resolved within a few feet. While 4WD is the obvious option, tight turns required in these same areas results in binding of the front diff which isn't good on the driveline either. While this same condition exist using the rear diff locker, because it is closer the pivot point, I don't feel the same strain on the tractor.
Funny I did not think of trying differential braking as I had designed a similar mechanism for my Jeep's rear emergency brake. I will definitely be trying this next time out. Raising the deck also makes good sense.
This is why I like this forum, as I get older I try working smarter and being able to hear your experiences is priceless. Please keep them coming.
/ Differential Lock Usage #14
left and right back rear brakes. diff lock, are important to me!
4WD. is nice! but 2WD and above. i can get out of a good amount situations.
though i do rely on the FEL (front end loader) to push or pull my rear out of some sticky guey situations.
when all else fails, i brake the backhoe out, to drag my rear out.
when everything fails. then i end up acting like a monkey, operating FEL, Backhoe, DIFF lock, or split brakes all at once. it may take me a little time, but will get it unstuck.
one thing that bugs me on some tractors. is split brakes are same foot as gas pedal. and there is not enough room to stick both feet wearing boots on. onto gas and brake pedals.
2WD, i prefer, more of the time, i end up over using per say the split brake pedals, for tighter turns. and controlling wheel spin.
but there are times, when trying to hit left or right brake pedals to control wheel spin is overkill. and easier to just press DIFF lock. so both rear wheels spin.
4WD, causes a larger turn, that i just do not like. though in muddy conditions if i have 4WD i will use it. so wheels are less likely to spin out.
Challenger 35/45/55 Parts and Operation Manuals (A63117)
Challenger...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
UNUSED SDLANCH PULL TYPE WOOD CHIPPER (A64281)
UNUSED SDLANCH...
