3 point pto post hole digger
/ 3 point pto post hole digger #1
ron45
Gold Member
N.M.
Kioti LK3054XS
What are the issues please, that determine which post hole digger will work with koiti? Pretty new to tractor lore.
/ 3 point pto post hole digger #2
Pretty much any will work as long as it matches the category of your 3P hitch. If you are buying new one get down force kit.
/ 3 point pto post hole digger #3
Can't say I know much about PHDs, and you've peaked my curiosity. What is a down force kit?
/ 3 point pto post hole digger #4
[ame=http://www.youtube.com/watch?v=1tTS85XreCI]hydraulic downforc kit on post hole digger - YouTube[/ame]
[ame]http://www.youtube.com/watch?v=hqbSa4XNRww[/ame]
/ 3 point pto post hole digger #5
Cool, thanks for sharing.
Thanks Red, looks like you did a nice job on the welds. The the mod to the auger makes a bunch of sense. You pretty much have to be digging is perfect soil with one of these things don't you? I imagine rocks and roots will pretty much shut things down or damage the equipment. But I have no experience with these things. So I could be wrong on that. What kind of pitch did you use on that tooth. Looked like a single bevel. Looks like a 45 maybe. Good quality on the vid. Steady image and sharp focus. Looks like some of your `training' is pretty far along.
/ 3 point pto post hole digger #7
I run a 12" auger on mine without a downforce kit. I guess if you were a contractor it would speed the process up a bit. I have quite rocky ground in places.
Things to consider.
1. What size auger you want.
2. Do you need tungsten teeth on it. (for rocky ground)
I wish I had a smaller auger sometimes but most of the posts I put in are corner posts so I need the large auger. It is also better when planting trees as well.
/ 3 point pto post hole digger #8
The PHD in the movie is not mine. I found it on YouTube to show what down force kit is. I don't have it and hate it. We have mostly clay with very little top soil. The auger will not drill through the grass because the grass wraps over the edge then slide in the shallow hole. I have to lift the auger up, hop down from the tractor, use some tool to clean the cutting edge and attempt to drill little deeper. It takes about two lifts and cleaning to get the hole started. Then it works fine. I am done with drilling for now but I plan on installation of the kit when I need the PHD next time. So if your soil type is clay or any other fine grain soil do yourself a favor. Get down force kit.
/ 3 point pto post hole digger #9
It's a lot more expensive, but a SSQA front hydraulic PHD is really the cats A$s. All the down force you'd like, reverse, and easy to position. My dealer rents them and told me once you used one, you'll never use anything else.
red' `ken, thanks very much I haven't seen the front mounted version. We certainly have plenty of clay and rock on our place so I need to get really informed about this subject. I hope I can see a few in action around here before I have to purchase one. I will probably have to look for something used. Because once I get the 8 or 10 holes I need it will set for quite a while. That how it seems to me. And thanks so much for adding to my kioti education. Hey Red' got pics of you home made backhoe in the photo gallery. I'd love to see it.
/ 3 point pto post hole digger #11
I have a Bush Hog 2102 post hole digger. It doesn't have the down force option but the digger is set up so that the down force option can be a bolt on addition.
That's good to know, the more models and options I know the easiier it will be to find the right one. Thaks very much.
/ 3 point pto post hole digger #13
3pt hitches coming in different categories, 0,1,2,3 if you are having to ask, i am going to assume you have a small tractor which will most likely be cat 1,
a riding lawn mower might have cat 0
if you were a farmer or like, you might have a bigger tractor that may have cat 2 (category 2) 3 pt hitch
3pt hitches on all tractors exception riding lawn mowers, are all spec'ed out to same size and like. the only difference might come up is HP at the PTO
you might want a "slip clutch" that goes between tractor PTO and PHD gear box. so if you do snag something that stops the PHD dead in its track, the slip clutch will let the tractor PTO shaft keep spinning, but let the PHD auger stop spinning. other words the slip clutch protects the tractors PTO shaft.
NOTE TO ABOVE! most PHD i see normally have a "shear bolt" were the auger bit (drill bit) attaches to the gear box. this removing need for a slip clutch. if you hit something that causes auger bit to stop dead in its tracks, the shear bolt will be cut in half. the shear bolt protects the "gear box" and the tractor PTO shaft. Shear bolts are not run of the mill bolt you can pickup at some hardware store. and pending on PHD you get may require a specific grade of metal the bolt is made out of, to be a shear bolt. ((to strong of metal and shear bolt does not get cut)), ((too week of metal, and you end up going through sheer bolts left and right))
a generic cheap 3pt PHD with no down force kit. does have some problem with small tree roots. and rocks. and keep them from digging any further down. and you may need to pickup the PHD and then drop it down. to get the auger bit to grab ahold and keep on digging down.
you do not need "super fast RPMS" slow and easy works good for me.
the "down force kit" for myself on farm, would be awesome to have, dealing with so many different types of dirt, from muddy dirt, to hard compacted dirt, to dirt that has rocks and tree roots in it. to other. though i have gotten away for now without needing down force kit, buy taking some 8x8x16 concrete blocks and wiring them firmly onto the PHD. so the blocks never get in way of PTO shaft or auger bit.
warning to above, be carefull of a PHD, you can get into some pretty deadly situations with a PHD, due to the PTO shaft and auger bit are so much out in the open and no type of real good shield to protect someone from getting wrapped around the PTO shaft or auger bit.
/ 3 point pto post hole digger #14
I prefer this kind of teeth on the augers. This is a Bush Hog auger. I have two augers. A 9" and a 12". These teeth cut through sod without walking when starting a hole.
/ 3 point pto post hole digger #15
I didn't build it but bought it for cost of parts from the original builder. After trying to use it first time I decided to modify it. I added two more wheels, and ballast weight on the rear. It already paid for itself but it is broken right now due to sheared boom pivot pin. When I get some time I will take it apart and increase the size of the pin from 1" to 1.5" and do few more small repairs.
I bought it to dig a ditch across a slope to increase watershed for our pond but we used it to dig holes for tree planting also.
Hey boggen, whistle pig! I didn't see your posts first time around. Thanks for your help and time. I'm getting smarter about these things a few times a day thanks to all of you!
/ 3 point pto post hole digger #17
Post hole diggers are not high tech. They basically all work the same way. I bought just enough post hole digger to make it easier for me to put in 2,800 feet of Red Brand No-climb horse fence. I put this fence in five years ago. It's still taught as a banjo string. About 100 dug holes. When I got the hang of it my best day was 13 holes in an eight day. Dug, lined up, concreted, and tamped. I am not a pro about setting fence. But I am better than a few.
/ 3 point pto post hole digger #18
remember to double check, and see if the PTO shaft needs to be cut down for PHD you get and tractor PHD will be on.
it also really does help to have a second person. ya they may have there thumb up there butt most of the time while digging the holes. but having that second person can quickly let ya know if ya need to adjust to keep PHD straight as you dig holes. and they will most likely have a better vantage point to see down the line of fence, to make sure you keep a nice straight line.
have a regular manual Post hole digger. so you can clean out bottom of holes. the tractor PHD does major work, but you bound to end up with more dirt falling back in hole after it was dug. and need to manually remove the dirt.
when it comes to putting posts into the holes. pending on size and weight of posts, second person comes in handy, just to move from trailer or truck and to the hole. while one person holds other person can take look down fence line to get current post lined up. or if hole needs to be made a little bigger.
have a role of tape and a level, and just tape level to post. to help you get it level, without messing around trying to figure out were level went or picking level up and down. note sure name of the level. but use a level that "bends" 90 degrees so i can straight the post up in both directions. without any sort of repositioning of the level.
when it comes to hand tamping the dirt around the post, to compact the dirt. having second person does help. one person takes half side of post while other takes the other half. and you just alternate between each other tamping the dirt with single tamper. it gives both of you breaks as other person tamps.
you can do it one person, but you end up doing extra leg work, having that second person really does help out a lot.
as far as stretching fence, and then nailing fence / attaching fence to posts. any extra help i am favor of. it is a lot of pounding, and a lot of twisting of wire around T posts.
Better than me that's for sure. Your sig. line reads like paraphrased verses from the Veda or the Bhagavad Gita. Good advice no matter the source. May your tractor run forever.
Ron
I hear you on the second person, however she won't think of herself that way.... [;^)>
Her and I built our adobe together.
Ron
PORTA POTTY (A67714)
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2013 Mazda 3 Sedan (A66738)
2013 Mazda 3 Sedan...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2012 CATERPILLAR AP1000E ASPHALT PAVER (A65056)
2012 CATERPILLAR...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
