Backhoe swings right, but not left
/ Backhoe swings right, but not left #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
This problem just happened on our 2008 M59 with 340 easy hours. Most of it's use is to lend a hand moving dirt and rocks here on our mountain land.....along with plowing snow with the bucket in the winter. One operator, regular maintenance, and although it lives outside, it does get an old tarp draped over the operator's compartment when parked. All in all, I'd have to say it leads a pretty soft life for a construction type machine.
So far that's worked out well for both of us. But yesterday an odd thing happened with the backhoe swing. I was moving small rocks off the road with the bucket and thumb - light, easy work - and all of a sudden the boom just stopped swinging to the left. No noise, no warning and no load at the time. The swing just stopped working. It had just swung about half way to the right and then wouldn't come back left for nothing. With a little experimentation is turns out that it will swing to the right as nicely as always, but push the LH backhoe control lever control to the left to make the boom swing left and nothing happens at all. No change in engine RPM or anything. My first thought was that it had to be something simple. Probably just one of the connections between the hand lever and the BH valve rack had come loose. But the lever fells correct, and a quick look at the valve rack under that plastic cover shows nothing amiss there. Crawling underneath shows no leaks or damaged hoses. The hydraulic fluid is properly full.
After a little more experimentation it turns out that if the control lever is put in the left swing position a person on the ground can push the boom to the left fairly easily. So nothing is binding in the pivot or cylinder. All other backhoe movements - including the swing to the right - seem to work normally and with full power.
So does this mean the problem is in the valve? Somehow that just doesn't seem right when I can see that the control is working the valve slider normally and with what looks to be full motion....or at least I'm supposing it's moving full motion. Is there some sort of control or swing lever override that I'm overlooking? Has anyone else had this happen on a backhoe? What could it be?
Thanks, rScotty
/ Backhoe swings right, but not left #2
Sounds like a bad seal in the swing cylinder. Remove the cylinder and rebuild or take it to a hydraulic repair shop.
That might be it. But maybe not. I was thinking it would move just a little bit at full RPM and no load even with a bad seal? Still, worth a check.
OOps...as I look at the BH and the shop manual this morning it turns out that there are two swing cylinders mounted as a handed pair and they are both powered in both directions. So as one is extending under power the other one is retracting under power. One cylinder ought to be more than enough to swing it.
It seems unlikely to me that both of those cylinders would go out at the same moment...and blow their internal seals in exactly opposite ways.
That sounded good until I see there are two powered cylinders. This M59 has a pretty sophisticated backhoe.
thanks, rScotty
/ Backhoe swings right, but not left #4
it is either one of the cylinders or the valve. is what i would assume.
if you have the shop manual for the backhoe. see if there any sort of "check valves" or mechnizism in the valve body itself. maybe one is messed up. or perhaps something caught up in the valve body keeping a check valve open. check valve could be simply a spring and a little ball, to small flat plates, to actual flapping check valve.
the 2 cylinders for swing. see if they are plumbed in series or parallel. maybe being able to disconnect one cylinder. and use a hose to by pass it. might give detail of which cylinder might have went bad.
any chance did hyd oil get to low, and allowed air into the system. and you just have not ran things long enough to work the air out of the hoses and cylinders?
if you have shop manual see if you can find a plumbing schematic/diagram that shows direction fluid is suppose to flow in. perhaps you might be able to narrow something down.
/ Backhoe swings right, but not left #5
Unless this is an election year thing, my assumption (based on both powered both ways) is that they are piped in parallel on the same spool.
Lets use RE for Rod end and PE for piston end. L is left and R is right.
Suppose swinging right takes pressure to L-PE and R-RE. So long as the piston cups are good there, it goes right (and the other ports are just going to tank.)
Now suppose on swinging left we send pressure to L-RE and R-PE. If we are in parallel like my guess, if either one of those piston cups can pass the fluid easily, the unit may not move, but instead the fluid goes to the path of least resistance.
If I am right, and I probably am not...what with no diagram and all, one could remove the hose from L-PE and check for massive flow or from R-RE and check for massive flow, and none should exist since there is no movement. But if it is leaking through the cups directionally, fluid will be flowing, and that will tell you which cylinder is bad, and which cup is bad.
Hope this helps...it is an assumption based on what you said...powered both ways, both cylinders.
I can't see them being piped in series really...possible, but it seems unlikely.
I have seen cups that are highly directional, and the pressure reinforces them. I have also seen a piston ring deal that is not directional at all as best I can tell. I don't know which you have, and this was all a shot in the dark telling you what I would look at were I you.
Edit: My junk has two cylinders, and each is powered one way, so a regular valve can control mine, and let oil out of one sides piston, and put oil in the other cylinders piston. So, both cylinders have one hose each, and the rod end is ported to air, so each is single acting. I assume by what you said, you have four total hoses for those cylinders. I assumed further that only one spool controls them both, and one piston is paralleled with one rod side, and other piston paired with the opposite rod side.
/ Backhoe swings right, but not left #6
right cylinder not working. find a way to bypass control to cylinder to see if it works. if it does,its the valve , if not ,cylinder.
/ Backhoe swings right, but not left #7
I haven't checked the shop manual, but if both swing cylinders are powered during a swing - they must be otherwise the unpowered one would work against the swing - then the valve is more likely the problem since the problem is directional. In any case this one probably requires return to a dealer to fix the problem. This is unfortunate, but you may only need to return the backhoe if it can be removed.
I haven't yet removed the backhoe on my M59, but I did succeed in removing the pins yesterday. They were surprisingly easy to remove, once I lifted the back end enough. More on that later. I am just getting back to work on the tractor in preparation for heading up to work on my place in Colorado this weekend.
Please followup, as any M59 issues are of great interest for those of us who have one.
/ Backhoe swings right, but not left #8
I think this is on the money. My guess would be the valve as you would be able to find some movement or at least hear something trying to work with the valve working. A simple look at the valves may reveal that something as simple as a sheared pin is there in the linkage that doesn't allow the valve to open/close. If this is the case it would be a very simple repair. Otherwise, I'd take it into the shop. Hopefully your still under warrantee.
And yes - I would imagine all you'd need to drop off is the backhoe. Assuming you can get it on a trailer and they can get it off!
Please followup,
PROBLEM FIXED!!
Well, I guess we'll never know exactly what the problem was, but with a little bit of help the problem appears to have fixed itself.
Maybe this self-healing is a Kubota feature?
Here's how it went.....
Yesterday morning I read up in the shop manual and then took my coffee to the barn to visually go over as much of the M59 hydraulic system as I could find....and found nothing to change. Even the oil still looked good.
I was kinda hoping for an overnight miracle, but just like yesterday the BH boom still wouldn't power-swing in one direction. But also just like yesterday, it could still be swung back the other way by hand if the control valve was held open. All other systems and controls still worked normally.
I'd rather do my own work than involve the dealer. Even though it would be an nice drive over there and he does have one very good...maybe even excellent mechanic. But I've always believed that the best work is always done by a concerned owner....and like it or not; that's me.
So...what I did was decide to get some more information. It occurred to me that I could tilt the tractor by putting down just one of the backhoe support legs. And with the tractor tilted, I could swing the boom one way under power and let gravity swing it back the other way. I don't know what I thought I was doing, but it seemed like a good way to get some more information. Surely better than doing nothing at all. And a whole lot better than disconnecting random hydraulic hoses, parts, and pieces... :)
It turns out there wasn't quite enough tilt for gravity to swing the boom by itself so I had to lightly bounce the boom with the boom cylinders to get the gravity swing to happen.
And I swung it that way three of four times just sort of sipping coffee and thinking what to do now? When ALL OF SUDDEN THE POWER SWING started working again in BOTH DIRECTIONS. With no noise, no warning,....not even a hiccup or apology. Just as smoothly and controllable as it's always been.
I used it the rest of the day and it was perfect; nice weather, nice tractor....
So what happened??
rScotty
/ Backhoe swings right, but not left #10
PROBLEM FIXED!!
So what happened??
rScotty
I really don't know what happened, but I am guessing a cup seal caught the flow and thereby got reinforced.
But I really don't even know if it has cup seals in the cylinders. I don't know how it is piped. I don't know if it is in parallel (one piston side in parallel with the rod of the other cylinder, etc.) I used to tell folks that telling me what they don't know is not helping...so I will heed my own advice and stop right there.
I was wondering if I was talking out of my hat with my analysis, but I have found a hydraulic diagram that supports my theory buy searching "backhoe hydraulic diagram" on Google.
HYDRAULIC SYSTEM DIAGRAM (SERIAL NUMBERS 319995 THRU 342573 ONLY)
Compare that diagram to my comments earlier, and do tell us if it matches yours (vis a vis the swing cylinders only), if you don't mind.
Hey, Thanks for that hydraulic system diagram. What is that one for?
As for the series versus parallel swing cylinders. The M59 is similar to what you referenced. Near as I can tell, the M59 works the same way in that the piston side and rod sides of opposite cylinders are pressurized at the same time. Doing it that way doubles the force, moderates the flow, and probably makes it smoother....but does make it difficult to visualize how the swing could only be powered in only one direction no matter what happens with the cylinders.
I'm not that familiar with fancy construction equipment hydraulic systems, just with the older open circuit tractor type. In comparison with the basic one in that diagram you referenced, the M59 is much more complex. It is more sophisticated than anything hydraulic I've ever dealt with.
The backhoe controls alone have 8 or 10 hi-tech dual stage adjustable & expensive relief valves (all identical) which I've ever seen on a backhoe control. One for each motion. Plus several load checks for things like the stabilizer legs.
Instead of using a single big hydraulic pump with flow proportioning circuits, the M59 has completely separate additional hydraulic pumps for different hydraulic circuits - looks like three in all. Not counting the HST tranny. The swing system has its own separate hydraulic pump. All this complexity and mine doesn't even have the accessory rear hydraulic outlets. I'm glad for that! Just has the optional bucket thumb - which of course has its own control and associated relief valves.
They sure didn't spare themselves any complexity on the backhoe operation. In their defense, I'll say that the controls do have a very good "touch".
Thanks for all the help, rScotty
/ Backhoe swings right, but not left #12
rscotty.
is there any way you can post a copy of the schematic for this BH. If this uses pressure compensated controls or load sense control one of the sense lines could have stuck open and then by the repeated use flushed itself out. If the load sense line does not connect or send a signal to the pump you will not build any pressure above standby. Not sure how much pressure it takes to move the swing on a back hoe.
Roy
/ Backhoe swings right, but not left #13
Wow it DOES sound complicated. I am not sure what that diagram I posted was for, I only meant it to be for talking purposes as an example of the swing circuit I was imagining...just wanted some proof to myself that such a circuit even existed.
But for talking purposes...imagine that when one direction is powered, due to the parallel path, only one cup on one side of one cylinder needs to leak badly, and all the flow will go there, and the thing may not move. But in the other direction, the other cup side is used for each cylinder, and it moves just fine.
I'm not saying that is what was wrong...it works now...but we WERE looking for ideas about what could be wrong, and how to know which cylinder it is, etc. If you look at the diagram again, a man could simply switch the hoses at the valve, and if the thing then swings the OTHER direction but not the previous (that used to work fine) then it is not the cylinders, but in the valving.
All I am doing is trying to help sort testing methods to diagnose the problem should it recur.
Your valving does sound complicated, but I wonder if it is not pretty conventional, but maybe with some flow control adjustments added, etc.
Did you misspeak when you said it has a separate pump for the swing...did you mean a separate pump for the entire backhoe, or did you truly mean a separate pump for swinging the boom?
/ Backhoe swings right, but not left #14
Kubota Tractor Corporation - Parts List
typed in "M59" clicked search
list came up, and only showed "BT1200 / BT1200V" as optional backhoe for M59, clicked that new window opened up.
it is showing both swing cylinders running in parallel. diagram showing a Tee adapter on both cylinders for how hoses run.
looking at diagrams a little more. would the "nut" on end of the rod. that goes into the cylinder tube, possibly come loose enough to let the seals, leak oil around them? more of a load on swing cylinders more of a leak and possibly causing seals to bunch up letting leak happen non stop? perhaps working the backhoe left and right to swing it. was enough to re-seat the seals.
and then come next time when a bigger load is placed on the cylinder and it happens again...?
looking a bit more at diagrams, more so at the valve / spool that controls the swing of the backhoe. is it possible, for one of the 0-rings on the rod that moves up and down through spool/valve to roll off some how, and is now re-seated? perhaps the 2 bolts that hold the main rod in the valve. came a little loose allowing some additional play within the valve/spool. letting hyd oil to by pass. vs letting oil goto correct path to swing the backhoe?
/ Backhoe swings right, but not left #15
The M59 does have a separate swing pump. The main hydraulic pump powers the boom/dipper/bucket (and loader etc.). The main hydraulic pump has a separate section for the power steering, hence the tractor essentially has three hydraulic pumps.
It could be that there was foreign matter in the valve, preventing it from fully opening in one direction. Moving the lever and swinging the boom back and forth may have eventually cleared it out, allowing normal flow.
I thought about that, but came to the conclusion that it was unlikely for any leak to be able to pass fluid faster than the pump could supply it at full rev.....so my "rule to thumb" for leaking problems is no movement at low rpm, but that at high enough rpm there will be some movement. What do you think?
IF you look at the diagram again, a man could simply switch the hoses at the valve, and if the thing then swings the OTHER direction but not the previous (that used to work fine) then it is not the cylinders, but in the valving.
Ahhh!!..That's a very good idea. I've done the swapping things across before, but missed that it would work on this system. It is a good way to diagnose.
Yes, and what I was trying to say is that the complexity seems to be more in the application than in the design. Hydraulically, it is a typical constant displacement open-circuit design. Complexity is usually reserved for closed circuit designs with their pressure accumulators and variable flow rate pumps. But the individual parts in the M59 system show a lot of care. Even things like the relief valves are quite complicated. My old American-made hydraulic control valves all had a relief valve that was basically a shimmed spring which pushed a steel ball bearing against a hole. This Kubota relief valve is a giant step more sophisticated..
Yes, the swing has it's own completely separate pump from the boom and bucket functions. There's the that complexity again. You can P1 and P2 in some of the picture below from the shop manual.
I uploaded some nice pictures that Oldnslo asked about. This is an interesting hydraulics discussion. Take a look at the modern M59 workshop manual versus some of the old hand-drawn workshop drawings (Yanmar)!!
rScotty
/ Backhoe swings right, but not left #17
rScotty
I will look at it more tonight, but so far, it is interesting that both pumps contribute to most functions(wrong), but only the one pump does the boom swing(right). Whether a piston leak could consume all flow depends on the actual flow of that pump...but I would not be surprised either way since booms need to swing fairly slowly, else a person could extend a full scoop way out and really make a heck of a crowbar out of a full extended hoe arm...a man might be able to twist off a stabilizer or do all sorts of crazy stuff if that boom start whipping side to side (edit: and the reliefs would protect the system, but not stop the momentum.)
Some of the additional complexity is a relief valve for each circuit. The reliefs could participate in a problem, and could participate in the problem you were having. Switching the lines can still be diagnostic, but I will have to consider it a bit further...since there are free flow back checks associated with the reliefs, and I haven't figured out what they enable. I have seen them before, but I always have to apply their appearance to the actual function of the apparatus to see what they help. They could allow free wheeling, etc.
It is complicated, but I bet that thing is pretty sweet too.
Later tonight, I may have to print those drawings out and mark on them to begin to understand all of the possibilities, but folks good at hydraulics are probably snickering at me. I hope so...a good chuckle is always a good thing.
Edit..nope, I'm wrong...the swing doesn't contribute to anything else, that is a tank line. I don't know what to make of the check, since it free flows from tank to the cylinders, but blocks the ports otherwise..allowing only the relief to function. It could be a start up thing or a means to be sure that if the boom is pushed sideways so hard that that it cracks the relief, the other side can have makeup oil from tank to avoid sucking in air at the seal, or water or cause cavitation. I think we can ignore those checks completely unless faulty. Switching the hoses is valid, and will not harm anything, but the diagnosis is blurred...since it need not be a cylinder, but could be the relief too or the check stuck open due to debris. If I figure something else out I will post, but looking at it more tonight may not reveal new info since I think I now have it mostly figured.
/ Backhoe swings right, but not left #18
rscotty,
Thanks for posting the schematics. Would suspect one of the reliefs got stuck open. These relief valves are there to protect from shock or surges caused by the sudden stopping of a swing function. The inertia of the boom and bucket can cause intense pressure spikes. The check valves in the RV's are to allow the cylinders to draw in oil (prevent cavitation) while moving under vacuum in the above scenario.
The reason for a separate pump for swing is for consistent motion regardless of the other functions on BH. This is a safety concern when operating around people or buildings.
Roy
/ Backhoe swings right, but not left #19
rscotty,
Roy
Agreed..thanks...I liked looking at what the cool hydraulics setups look like. I know why mine is so jerky, and now I know how they make them less jerky.
oldnslo...thanks for the info about the separate pump being about safety due to consistent movement of the swing. I had not thought of that, and it is good to know.
/ Backhoe swings right, but not left #20
Just to cover all bases...are the hydraulic fluids full...is it due for a filter change...did you recently replace anything that could have allowed air into the system?
MarkV
