Why turn 4wd off?
/ Why turn 4wd off? #1
joshuabardwell
Elite Member
Knoxville, TN
Bobcat CT225
I've been reading a bunch of threads on here about safe (and unsafe!) tractor operation. One of the things I've read about and personally experienced is how useful 4wd is when going down hills nose-first. I don't have very many big flat spots on my property, and I'm often using the loader, so I pretty much leave the tractor in 4wd all the time.
At first, I thought it was like my truck, and the diffs locked when it was in 4wd, so you couldn't use it on pavement. But then I realized it's got a separate diff-lock lever, so that must not be the case. So that leaves me wondering? What's the down-side of 4wd? Why not just leave it on all the time and enjoy the benefits?
/ Why turn 4wd off? #2
the biggest downside is that on a dry surface or pavement, the front wheels can not slip when making turns.. if they cant slip it puts strain on the front differential - as each wheel needs to turn at different speeds in turns
As long as the surface is slick, or soft enough you could leave it in 4x4 all the time..
Brian
/ Why turn 4wd off? #3
I agree with Brian and would only add or suggest to disengage 4wd on pavement / asphalt otherwise leave it in 4wd especially down hill in grass or gravel or other slick or loose surface.
/ Why turn 4wd off?
How can I determine definitively whether the diff on the front wheels locks in 4wd mode? I've taken some tight turns and I've never noticed the wheels slipping. I know the diff on the rear wheels isn't locked unless I press the diff lock lever, as I have used it to get out of a muddy situation where one wheel kept slipping.
The tractor is a Bobcat CT225, BTW.
/ Why turn 4wd off? #5
I leave my tractor in 4wd all the time. On my property I never know when I will need the extra traction. I do know that it's better to already BE in 4wd than try to put it in 4wd when you need it. I almost never drive on pavement or concrete.
/ Why turn 4wd off? #6
The front differential never locks, there is no lock mechanism on our CUT size tractors. there is no center differential on most of our CUTS either (some do have, but not many) On Hard surfaces (asphalt, or concrete) when making turns there can be binding (torque windup) between the front and rear. This results in tire wear, for sure and some extra strain on the front differential. But the danger of going down a steep hill in 2WD with a load in the bucket is very real, even on pavement if it has some loose gravel on it, the rear tires can and will break traction, resulting in a runaway if the hill is steep enough, and there is enough gravel, or going down a grassy slope, or anything that reduces traction. Having a heavy ballast on the back will help prevent this, but don't count on it. 4WD is your friend to prevent this. Been there and done that and have survived. What ever the heck you do, drop the bucket, drop the ballast, keep the steering wheel straight, don't swerve or you will surely overturn. Several guys on here can testify what happens when you swerve to miss something.
James K0UA
/ Why turn 4wd off? #7
One reason not to leave it on is that the shaft from the rear to front will be rotating all the time. That will cause the oil seals to wear out faster than they would otherwise.
/ Why turn 4wd off? #8
When your front and rear tires are at the size for which your tractor was designed (presumably when the tires are new), the front and rear axles turn at a coordinated rate so they both cover the same amount of ground in a given time.
But when you turn, the front and rears travel a different distance, requiring one or the other (guess which) to skid a bit to make up the difference. That's not much of an issue on gravel, grass, or other soft surface. But it is on pavement.
I leave my tractor in 4wd all the time except when I run on pavement, especially when I have to turn on pavement, like when I'm cleaning the ditch along the paved road with the FEL. All the pavement around here is fairly level, so the issues cited by others don't come into play.
Terry
/ Why turn 4wd off? #9
Scenario: you have a load of sand, gravel, mulch, etc. delivered and it's dumped on a concrete surface. You push your FEL bucket into the pile hard to load the bucket completely. You're in 4WD while you push hard until the forward motion is stopped. Loud noise from the front end. That's your transfer case and/or front axle(s) turning to trash. In 4WD all four wheels need to be able to break traction when you stall the tractor's forward motion as in this case. So--load the bucket while in 2WD. Switch to 4WD for transporting the load.
/ Why turn 4wd off? #10
The shaft rotates all the time whether you are in 2WD or 4wd, When in 4WD it is under power from the rear and applying power to the front differential. When in 2WD the shaft is in rotation from the front differential and while disconnected from the rear the connection point is in the rear not the front.. There are no hubs automatic or manual to disconnect the front differential like in your typical 4wd part time truck or SUV. So the shaft rotates all the time regardless.
James K0UA
/ Why turn 4wd off? #11
We frequently drive on pavement (inlaws have a paved driveway), so our tractors are always going in and out of 4wd.
Aaron Z
/ Why turn 4wd off? #12
Okay thanks for the correction. I'll be using 4WD more often now rather than trying to conserve the oil seals.
/ Why turn 4wd off? #13
I leave mine in 4wd most of the time as I have steep hills and dirt/gravel everywhere,no asphalt unless I road it to the in-laws, then its 2wd.......
/ Why turn 4wd off? #14
The front wheels over run the rears by 5 to 10% so on hard surfaces it will cause wear if the wheels cant slip. They are designed to pull in soft ground.
http://www.firestoneag.com/webres/File/Tire-Info/TireInfo-LeadLag.pdf
This is a pretty good explination, although I didn't spend a lot of time researching.
We never run in 4x4 unless we need it, if you are carrying enough in the front bucket to lift the rear tires even on a hill you need ballast.
/ Why turn 4wd off? #15
you can always tell a tractor that has some hrs on it that has has most of them in 4wd, the front tires will be well worn compared to the rears. I also do not engage 4wd unless I need it. while in 4wd, going straight, the frontend is overdriven but when you try to turn the overdrive on the frontend isn't enough and the frontend "pushes". I can turn several feet shorter in 2wd vs 4wd.
/ Why turn 4wd off? #16
On cuts the front tires always wear fast. Even in 2wd you will use about 3-5 sets of front tires per set of rears. Most of cut owners won't wear out the rears.
/ Why turn 4wd off? #17
Some very interesting posts, but sometimes it seems we tend to over think things. I have operated tractors in a way guaranteed by some to cause catastrophic failure yet in over 50 years have yet to break anything in the drive train or blow an engine.
"In theory, there is no difference between theory and practice. But in practice, there is." - Yogi Berra
/ Why turn 4wd off? #18
I think you are correct, however your comments makes me think of two things.
1. If we didn't over think things here we would probably end up reading the newspaper more thouroughly with our extra time and that could be really depresssing instead of fun like reading about tractors and stuff.
2. I don't think I would loan you my tractor.:laughing:
/ Why turn 4wd off? #19
:) ... Yes. We apparently have experience with tractors of competent strength design for their entire functional envelope. There are obviously some that are not, since there are enuf substantiated reports of failure, sometimes repeated, to bear it out. For the sake of suitable machinery I hope those cases are more "unlucky" than ours are lucky.
larry
/ Why turn 4wd off? #20
Has that happened to you?
Anyone?
One of my first "workouts" I was moving sand from a concrete surface in 4WD all the time, no problemo.
3 years later can I expect my drive to be trashed?
/edit but I've a Kubota
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
PORTA POTTY (A68842)
2025 16in Tooth Bucket Mini Excavator Attachment (A66734)
2025 16in Tooth...
2016 John Deere 3039R 38HP 4WD Utility Loader Tractor (A66734)
2016 John Deere...
Unused 2023 USA Attachments Quick Coupler Excavator Attachment (A66734)
Unused 2023 USA...
2016 CATERPILLAR 305E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
