GT2550 PTO Problem
/ GT2550 PTO Problem #1
GRB
Member
Mount Airy, Maryland
2005 Cub GT 2550
Good Afternoon,
I have a 2006 GT 2550 with 350 hours on it. I did some regular maintenance yesterday (change oil, clean pre-filter, grease, switch out blades for newly sharpened, washed, etc.) This morning, I went out to mow and the PTO suddenly now comes on, runs for a minute or two and then shuts off. Pull it on again and it will run for a minute or so, then shut off. I thought maybe I got some water in the switch, so I pulled it and hit it with some De-Oxit, but the issue remains.
Sound like just coincidence that the PTO would fail or did I get something way to wet when I washed it yesterday?
Thanks for any input.
/ GT2550 PTO Problem #2
would first chk battery - a marginal batt will let that happen.
M/W, lose the hose or pressure water wash thing - L&G tractors don't like it - they are not designed/built to withstand the corrosion that happens at elect connections/switches/etc. Better to use comressed air or an electric leafblower after each cutting session.. then just a damp rag only on body as needed.
Thanks for the response. I finally figured it out this evening. The relay for the PTO up under the dash was factory wire-tied to the wiring harness with the open end up, so evidently I got water in there while washing the tractor. I took it apart and it was definitely wet. Dried it out, used some De-oxit and viola...Runs like a champ.
I normally just use compressed air to clean it, but I had been mowing a couple of days after rain and it had gunk stuck all over it. Learned a good lesson, guess I will make sure I don't get it wet under the hood next time.
/ GT2550 PTO Problem #4
Hope you do not mind , the box on the back of your mower could you get a closer photo please :thumbsup:
Tracter, here you go. It is just a Stack-On tool box from Tractor Supply and couple of pieces of angle iron bolted to the frame rails.
/ GT2550 PTO Problem #6
Looks good that deserves a double thumbsup :thumbsup::thumbsup:
/ GT2550 PTO Problem #7
Good find GRB!
Thanks for posting the follow-up on that. I do recall having to tidy up a lot of the wiring on my 2005 model year 2544. The bundle(s) of relay pigtails on mine originally looked like someone got a running start and stomped them in.
Joel
UNUSED ATS CMR1280 ELE.CEMENT MIXER (A62131)
UNUSED ATS CMR1280...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2017 Ram 5500 Bucket Truck (A63118)
2017 Ram 5500...
UNUSED KUBOTA BRUSH GUARD (A62130)
UNUSED KUBOTA...
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
2013 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A61568)
2013 International...
