Small red triangle on tach???
/ Small red triangle on tach??? #1
kwg
Member
Addison WI
2012 Kiotie CK35 HST
What is the the small red triangle on the tach for? Is that the max rpm or the rpm that should be used with implements?
/ Small red triangle on tach??? #2
It is the RPM you need to set the engine to run a PTO driven implement to make that PTO shaft turn at 540 RPM. Most PTO driven implements were designed to be run at 540 RPM. Not saying you cant run them a little slower, and I often do for various reasons.
James K0UA
Thanks.......I just got the tractor and don't want to screw anything up....:ashamed:
/ Small red triangle on tach??? #4
Best practice it to throttle down to idle speed then engage the PTO for your shaft driven implement, then throttle up to the 540 mark (depending on your tractor that could be anywhere from 2200 to close to 3000 rpm) and then got to work with your implement. When you want to stop, slowly throttle down, then disengage your PTO control. There are many different ways to engage the PTO, read your manual, some use the clutch, others are electrical/hydraulic etc. Let us know if we can help in any way.
James K0UA
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2022 EZ-GO ELITE...
2021 LUCON MRT3500 SPOOL TRAILER (A63276)
2021 LUCON MRT3500...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A64553)
Pallet of...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
