Tiller for BX...
/ Tiller for BX... #1
samofsweden
Gold Member
Kubota Bx24, 2007
Hi. I bought a new chinese tiller on a internet acution. Well I know what you think...and I think the same;)
I should mention that I never tilled before. My plan was to till new land, after removing trees big, stones etc. Insted of filling up with new earth I use my tiller to get the earth movable. Areas of this kind usally contain hidden stones under the surface. On my tiller I havnt found any breakpin, instead I have broke the chain twice...:mad: this happens when the tiller hit a big stone.
So maybe their isnt any breakpins on tillers or my tiller is....well....chinese (bad copy)?
What happens if you run into a big stone with an orginal kubota tiller?
/ Tiller for BX... #2
I am pretty sure there is a shear pin somewhere. If you really cant find it, perhaps you should install a slip clutch on the tiller pto. Its no fun to break open your BX hydrotransmission to fix the pto shaft/clutches/gears inside.
/ Tiller for BX...
Radioman, ok will look ever closer if I can find a shear pin...
The first chain (chinese) lasted for 10 minuts. The second ones of good quality lasted for 20 minuts... The shearpin should have broke by that time?
The slip clutch, is that something which sits on the pto shaft between the tiller and the tractor?
/ Tiller for BX...
Radioman,
Just had a look...no shearpin found:confused:
/ Tiller for BX... #5
A slip clutch will mount between the PTO shaft and the tiller. You can buy a new PTO shaft with one installed. Just curious is the pto shaft mounted to the tiller gear box with a spline shaft or shaft with a key and bolt or just a bolt. If just a bolt that bolt should shear. Be sure someone didn't put a grade 8 bolt there or something. Also at that point pull the bolt and make sure the shaft will spin on the shaft and isn't rusted solid.
/ Tiller for BX... #6
Oldtractorfixer is totally right. Get a PTO with slip clutch to absorb any hard knocks. I have vast experience with Chinese product and I know that one brand I used to sell always turned up with no shear protection anywhere on the tiller. That's no good for a tiller. So thats probably why you are having trouble. Get a new PTO with shear protection or slip clutch. Slip clutch can be expensive but cheaper than fixing damage that will happen with no shear / slip protection in your tiller.
/ Tiller for BX... #7
Here is a pix of my slip clutch mounted under the safety cover
/ Tiller for BX...
Johnvan,oldtractorfixer,radioman thanks for your help!
Ok will check out an pto shaft with slipclutch. Need to buy a new chain to the tiller first...
Thanks again.
/Sam
/ Tiller for BX... #9
Thanks again.
/Sam
Just out of curiosity, how much did you "save" by purchasing this tiller versus a known-quality brand (e.g. Land Pride)?
The reason I ask is that the slip-clutch PTO shaft will not be inexpensive (typically around US$400 or so), and you have already broken two chains (with attendant tiller downtime as well).
Wrooster
/ Tiller for BX... #10
I was also wondering this :)
I hope it was cheap so that you can cover the PTO etc.
/ Tiller for BX... #11
As everyone else says.... just add a slip clutch. Apparently, they don't have rocks in China ??? :confused::confused:
If your tiller has a standard six spline @ the tiller end, you can buy a slip clutch that goes on just as your tiller-end PTO shaft does..... then, just slip the PTO shaft onto the slip clutch (after you adjust the length of the PTO shaft).
PTO Slip Clutch, 1-3/8 in. 6 in. Spline Shaft - 0271211 | Tractor Supply Company
Do a search here on TBN for the correct process on adjusting your slip clutch once it is installed.
/ Tiller for BX...
Wrooster
I bought the tiller at a webb-auction, it was around 1/3 of the listed price.
I knew it wasnt a good quaility tiller, and I not in need of tiller alot, just handy to have one in case of...
I havnt had time to check out how much a slip-clutch ptoshaft cost here in Sweden. But I keep you updated.
/ Tiller for BX... #13
Not to hijack, but my XB tiller came with a slip clutch PTO. As much as I could see in the illustrations, the slip clutch installs on the tiller side. Does it matter?
207277 (A52708)
207277 (A52708)
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
