Bx replacement
/ Bx replacement #1
Loudo
Bundaberg Queensland Aus.
Kubota BX2230
I have finally been given permission by She who must be obeyed to look at replacing my BX2230. She said if I give up smoking I can look for a new tractor,so give up the smokes:D I would like a bigger Kubota but the local dealer is an a#*@^hole, doesnt want to know unless I am a member of the heavy checkbook set or a big cane grower. If I wanted 150+hp no worries but anything else,well..:mad: forget it. I haven't contacted other dealers yet but will do. Any and all suggestions will be much appreciated.
/ Bx replacement #3
Kubota B3030. Has all the "extras" on it. I get a warm fuzzy feeling just looking the telescoping links.:ashamed:
/ Bx replacement
My original Kubota dealer was great but when we moved and I went to the local dealer the reception was very cool, they wouldn't even return my phone calls !!!!!!! so go further afield and hopefully get some satisfaction, or go to another brand of tractor.
/ Bx replacement
Gudday Artisan, have been just over a week without those bloody sucksticks, been a bit tough but I am getting there with wifey's help she giving up as well.
/ Bx replacement #9
I have a Kubota B3300SU tractor/loader package. Thirty-three engine hp / twenty-five PTO hp. The "B" series is Kubota's next larger increment and the B3300 is the largest machine in the "B" category. The B3300SU does NOT have a mid-PTO point, which is primarily for lawn mowers. Instead you get more HP in a larger frame, category 1 / 3-Pt and increased ground clearance. The B3300SU packages the tractor and Kubota's LA504 together at a competitive price.
It would be pretty simple to price this all-up package with other Kubota distributors.
If you are seeking 50% more power and FEL capability this may be a the package for you. The only "extras" I have are the factory Drawbar@$49 and Ken's bolt-on Grab Hooks mounted on the bucket. I have been very happy with my B3300SU @ 262 hours.
Kubota Tractor Corporation - Tractors | B Series | B3300SU
(Thank you for the correction, "bp fick" following post.)
/ Bx replacement #10
Actually, most "B" models do indeed come with mid-PTO and mid mount mowing decks. There are a few, such as the 3300 that do not, of course.
/ Bx replacement #11
Hey Aussie, If they don't even return your calls, they are not reliable. I would not even deal with jerks like that. Why not try another dealer... too far away? Heck, you may just want to try another brand then. Good luck.
/ Bx replacement
Looks like you are right gumshu, even though I like kubota, what's the point if I can't get service etc. We have JD and case IH, I haven't contacted them as yet but will do so this week,could be interesting,will keep you posted. Thank you all for your support re the ciggies,so far so good, but it's been a bit tough but I'm NOT giving in to it, a new tractor will be much more fun than those bloody things.
/ Bx replacement #13
Loudo, you seem to be willing to look at other brands, so it is mainly a matter of matching a tractor to your needs. What dealers are within a reasonable distance from you and what are the things you use your tractor for?
I started off years ago wanting to upgrade from my Farmtrac to either a Green or Japanese Orange tractor. After my own research and wading thru the information I found here in TBN, I went to the other Orange a few weeks ago. For what it's worth, I'm very pleased with it so far in terms of it's capabilities, ease of use, features, and dealer.
May not be a choice you are interested in, but half the fun of getting a new Tractor is checking out what's available and planting your rear-end in the seats for a test drive. Good luck on your "hunt" :thumbsup:
/ Bx replacement #15
..... though I like kubota, what's the point if I can't get service etc. We have JD and case IH, I haven't contacted them as yet .
If you're looking at JD2000(larger) series , be aware that
front wheel drive engagement problems are still unresolved ; do your
research. You don't have to buy local . Just because you may do so
doesn't mean you'll get served well .
David Evans Group Kubota
980 Nambour Connection Road
NAMBOUR QLD 4560
Phone: (07) 5476 1166
Fax: (07) 5476 1026 Mark is the manager.
Email: bruce.ensing@deg.com.au This lot of mine are keen.
They're opening in Gympie.
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2007 Toyota RAV4 SUV (A61574)
2007 Toyota RAV4...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
