Question for slope mower guys with duals
/ Question for slope mower guys with duals #1
KentT
Elite Member
Sevierville, TN
1993 Power Trac 1430 w/Kubota diesel engine
Have you tried running one set of tires with the ag tires' lugs reversed, for traction backwards, or do you run them all the same? What were the results?
Just bought a Gravely walk-behind with duals and all turfs, and will be putting ags on it, and just wondering what would be the best setup to try first...
I need traction forward and reverse, but most of all I need the lugs to prevent sliding sideways on those steep TN hills, and which direction the lugs are pointed doesn't matter in that regard...
TIA
/ Question for slope mower guys with duals #2
This is not about tires, but brakes.
As an alternative to the brakes you have now, here is an idea I have had for a long time.
A high pressure gate valve in each leg of the wheel motor circuit, and when applied, it would stop all flow to the wheel motors .
For instant on, a one button switch to each solenoid valve could be use to provide instant braking.
The larger PT have spring activated braking in the wheel motors. It then takes a certain psi for the brakes to release.
/ Question for slope mower guys with duals #3
On my 1845 I have r-4 tires (industrial tread) and I have them installed in the forward traction mode, ag tires I don't think it would make much difference in side slipping which way they were on.. I had an old Gravely with dual ag tires and it would hold on the hills but was difficult to control on steep side slopes hard to walk on without slipping and also you had to keep the tractor pointing up hill slightly, I really don't think it would make much difference in which way the tires were mounted. It was really a bear to use.
/ Question for slope mower guys with duals #4
TIA
I've often wondered the exact same question. And a PT is just about the ultimate forwards/backwards capable machine. However, we do spend most of our time going forwards, so that's why the treads are probably always forwards on dual-wheeled machines.
Road wear is probably not a problem for us as we are almost always off road.
I was thinking if you have duals, you have twice as much traction.... except you also have twice as much flotation, so that would offset some of the weight you need for traction, which could be a factor going up and donw hills. On cross-slopes, duals would really help with tipping, but again, I think you would lose some traction, gain flotation, and have a tendancy to slip sideways down hill.
Perhaps with duals set forward and backward as you describe, you may have some cross-slope advantages and maybe some hill holding advantages up and down.
Pure speculation on my part, of course.
The only way to do it is test it out. See which one works best.
/ Question for slope mower guys with duals #5
Just my two cents worth, but chains revolutionized my slope mowing with my 1445.
Prior to having chains the weight of the mower would tend to drag the front of the mower/tractor downslope. The cure was to mow at an angle with the mower a little higher up the slope compared to the tractor.
I used the diamond pattern chains recommended here.
With chains, no slipping, and I can mow (uphill/downhill) much steeper slopes than I could without chains.
All the best,
Peter
TIA
/ Question for slope mower guys with duals #6
I have my insides pointed forward, and my outsides pointed back.
Here is what I think but take it with a grain of salt.
Direction make a bit of difference but because the pt is so light the treads never engage like a normal tractor. Ultra low tire pressure is what is called for to handle slopes sideways. I put chains on my pt and will never take them off again. They make a huge difference in traction, BUT I feel with chains I have lost a small amount of sideways slope traction. I tend to slip more above 30 degrees than before.
Carl
/ Question for slope mower guys with duals #8
i have run my PT with one half of the duals reversed when i knew i had to do lots of backing up in muddy conditions. For that, it definitely helps. Chains help a lot more.
Ken
JJ, I'm talking about a Gravely walk-behind tractor with brakes, not my PT...
I'm aware of the issues on the PT...
This old 5260 I just bought has a steering brake, which I hope will help control that crabbing issue and make it much more usable on hillsides, without having to man-handle it to keep it pointed in the right direction. It's a low hours (400-600 estimated) 1989 model that had the engine upgraded in the late-nineties with a Kohler Magnum 12HP. Here's pics, if you're interested:
Gravely 5260 with replacement Kohler Magnum
I'm getting it because there are some places I'll need to maintain have no runout at the bottom, nor anywhere to turn at the top -- so mowing up and down is a challenge. I need to mow the sideslope.
Plus, I'll need to mow the sideslopes on my hillside lawn. I've already found a 30" weed/brush mower for it, in addition to the 50" finish mower that came with it. Once cleaned back up, I'll try to maintain it in slow-motion with a sicklebar...
Luckily that area is small in comparison to the rest of the mess... such as the hillside above this service road, below the trees.
Ken
That may be the configuration to try -- inside lugs reversed, then chain up the outside ones when I'm on the hillsides clearing the overgrowth...
/ Question for slope mower guys with duals #13
I had a Gravely with the 12 hp single cylinder Kohler. The engine put a lot of vibration into the machine and and even with the steering brake it was a bear with dual wheels--tending to jerk first one way and then the other. Going to single wheels made it a lot more managable and a lot less tendency to jerk left and right--but of course reduced the slope it was stable on.
That was when I was much younger and now I am very happy to work my steep slopes with a PT 1845.
Thanks, Bob. Good to hear the first hand experience... this is certainly not a replacement for my PT, which I plan to use anywhere I feel like I can safely operate it....
It's simply to use where I can't/won't use the PT... one of the reasons for deciding on this old Gravely is that it is an affordable experiment to see if/how it will work for me.
A PT slope mower is something I can only dream about, at this point...
/ Question for slope mower guys with duals #15
Your Gravely should be better than my model L Gravely, I only had 30 inch brush hog and no brakes and a lot less weight. Going up hills there was not enough weight in front and you had to lift up on handlebars to keep mower deck on the ground.
There is a used slope mower on Power Tracs web site probably not too far from you in NC with mower and snow plow for $11,000.
I saw that, but when I add in the equivalent set of implements that I already have in the T-8 size, I'd be pushing $18K-20K. Right now, I have just slightly more than 1/2 that tied up in my 425 package, even after all my mods.
I wish I could, I wish I could...
/ Question for slope mower guys with duals #17
Dear KentT,
Not to belabor the issue, but I have lots of slopes with no runout on the bottom. Yes, I mow carefully, but usually I mow down, back up the mowed area, and cut fresh again. If I can, I'll cut a swath along the top/bottom to give me working room, but it isn't always possible. You could use the Gravely for edges and the PT for the center.
Again, chains made a huge difference for me in terms of control. When I brush cut, I have lots of sappy weeds that make the slopes very slick once they are cut, as well as being 25-30 degrees.
Have you thought of adding calcium chloride to the Gravely? It would add mass that might make it more stable, as well as keeping the traction up.
All the best,
Peter
Dear KentT,
All the best,
Peter
The dual wheel adapters for the Gravely that are on there are cast-iron, which adds considerable weight -- not exactly sure how much.
attachment.php
These old design 2-piece wheel rims require tubes, which complicates adding fluid (in comparison to tubeless). I may experiment with trying to pump windshield washer fluid in, under pressure, since I modified an old 3 gallon pump sprayer to do that long ago. It's just time consuming. I generally try to avoid calcium chloride, even though it is heavier -- I've seen too many old machines with severe rust. However, a 4.80x8 tire 16" tall just won't hold enough fluid to add a lot of weight, anyway. I'd guess it would add no more than 10-12 lbs or so, at a little less than 8 lbs per gallon.
I am looking at chains for my PT though... with the wheel motors that I'm putting on it, if I reverse the wheels, the track will be about a foot wider than stock. So, I don't especially want duals - just the wide stance. I'm concerned that with the low weight of the PT-425 (in comparison to slope mowers) that if I went duals the tire lugs might never dig in on the slopes. Is there such a thing as too much floatation?
I've even thought of mounting up some lightweight 25x12x12 ATV tires that I have lying around and mount them on the outside of the 26x12x12 lugs to serve as "outriggers" just in case it starts to tip, especially if articulated during a turn. Being shorter, they wouldn't contact the ground normally, reducing flotation, but would serve only the "outrigger" type of role...
With that said, I don't want to operate the PT a lot on side-slopes since the Kohler engine is only rated to 25 degrees. Going up and down the slopes isn't a problem, I don't think, but going around hillsides above 25 degrees I could experience oil starvation...
Thanks, everyone for helping me "brainstorm" some approaches to all this..
/ Question for slope mower guys with duals #19
fabricate a set of steel wheels similar to the ones used on the pay-loaders at the landfill , they traverse just about anywhere on the mounds with the pay-loaders, I originally thought they were implemented to avoid flat tires but the operator claimed they help with traction I am sure experience helps significantly
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
2025 44in. HWG44 Hydraulic Mini Log Grapple Skid Steer Attachment (A59228)
2025 44in. HWG44...
Kubota M6 131 HP
Kubota M6 131 HP
