Question for slope mower guys with duals
   / Question for slope mower guys with duals
i have run my PT with one half of the duals reversed when i knew i had to do lots of backing up in muddy conditions. For that, it definitely helps. Chains help a lot more.
Ken
That may be the configuration to try -- inside lugs reversed, then chain up the outside ones when I'm on the hillsides clearing the overgrowth...
   / Question for slope mower guys with duals #13
I had a Gravely with the 12 hp single cylinder Kohler. The engine put a lot of vibration into the machine and and even with the steering brake it was a bear with dual wheels--tending to jerk first one way and then the other. Going to single wheels made it a lot more managable and a lot less tendency to jerk left and right--but of course reduced the slope it was stable on.
That was when I was much younger and now I am very happy to work my steep slopes with a PT 1845.
Thanks, Bob. Good to hear the first hand experience... this is certainly not a replacement for my PT, which I plan to use anywhere I feel like I can safely operate it....
It's simply to use where I can't/won't use the PT... one of the reasons for deciding on this old Gravely is that it is an affordable experiment to see if/how it will work for me.
A PT slope mower is something I can only dream about, at this point...
   / Question for slope mower guys with duals #15
Your Gravely should be better than my model L Gravely, I only had 30 inch brush hog and no brakes and a lot less weight. Going up hills there was not enough weight in front and you had to lift up on handlebars to keep mower deck on the ground.
There is a used slope mower on Power Tracs web site probably not too far from you in NC with mower and snow plow for $11,000.
I saw that, but when I add in the equivalent set of implements that I already have in the T-8 size, I'd be pushing $18K-20K. Right now, I have just slightly more than 1/2 that tied up in my 425 package, even after all my mods.
I wish I could, I wish I could...
   / Question for slope mower guys with duals #17
Dear KentT,
Not to belabor the issue, but I have lots of slopes with no runout on the bottom. Yes, I mow carefully, but usually I mow down, back up the mowed area, and cut fresh again. If I can, I'll cut a swath along the top/bottom to give me working room, but it isn't always possible. You could use the Gravely for edges and the PT for the center.
Again, chains made a huge difference for me in terms of control. When I brush cut, I have lots of sappy weeds that make the slopes very slick once they are cut, as well as being 25-30 degrees.
Have you thought of adding calcium chloride to the Gravely? It would add mass that might make it more stable, as well as keeping the traction up.
All the best,
Peter
Dear KentT,
All the best,
Peter
The dual wheel adapters for the Gravely that are on there are cast-iron, which adds considerable weight -- not exactly sure how much.
attachment.php
These old design 2-piece wheel rims require tubes, which complicates adding fluid (in comparison to tubeless). I may experiment with trying to pump windshield washer fluid in, under pressure, since I modified an old 3 gallon pump sprayer to do that long ago. It's just time consuming. I generally try to avoid calcium chloride, even though it is heavier -- I've seen too many old machines with severe rust. However, a 4.80x8 tire 16" tall just won't hold enough fluid to add a lot of weight, anyway. I'd guess it would add no more than 10-12 lbs or so, at a little less than 8 lbs per gallon.
I am looking at chains for my PT though... with the wheel motors that I'm putting on it, if I reverse the wheels, the track will be about a foot wider than stock. So, I don't especially want duals - just the wide stance. I'm concerned that with the low weight of the PT-425 (in comparison to slope mowers) that if I went duals the tire lugs might never dig in on the slopes. Is there such a thing as too much floatation?
I've even thought of mounting up some lightweight 25x12x12 ATV tires that I have lying around and mount them on the outside of the 26x12x12 lugs to serve as "outriggers" just in case it starts to tip, especially if articulated during a turn. Being shorter, they wouldn't contact the ground normally, reducing flotation, but would serve only the "outrigger" type of role...
With that said, I don't want to operate the PT a lot on side-slopes since the Kohler engine is only rated to 25 degrees. Going up and down the slopes isn't a problem, I don't think, but going around hillsides above 25 degrees I could experience oil starvation...
Thanks, everyone for helping me "brainstorm" some approaches to all this..
   / Question for slope mower guys with duals #19
fabricate a set of steel wheels similar to the ones used on the pay-loaders at the landfill , they traverse just about anywhere on the mounds with the pay-loaders, I originally thought they were implemented to avoid flat tires but the operator claimed they help with traction I am sure experience helps significantly
2006 Chevrolet Impala Sedan (A55853)
2006 Chevrolet...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2012 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2017 John Deere 1025R Tractor - 626 Engine Hours (A55315)
2017 John Deere...
2003 Big Tex 10PI...
2022 JOHN DEERE 624P WHEEL LOADER (A52709)
2022 JOHN DEERE...
